coutleef
Reged: 02/21/08
Loc: Saint-Donat, Québec, Canada
Re: Minimizing SCT vignetting while maximizing FOV... new [Re: bilgebay]
      #5819777 - 04/24/13 01:14 PM
I solved that problem by using a 2 inch WO diagonal for SCTs, not using a focal reducer and using a 40mm pentax XW for wider views. When i want to go wider withoutnvignetting, i use my 100 mm semiapo
Re: Minimizing SCT vignetting while maximizing FOV... new [Re: Eddgie]
      #5820213 - 04/24/13 04:48 PM
Thanks Ed. I'll PM you in a sec for Ken's article.
In the meantime, any opinion on whether in (1.25" VB) + (1.25" diagonal) mode it makes a difference if the diagonal uses a prism rather than a mirror?
Thanks for taking the time to provide the well-thought-out, well-articulated analysis of the question.
Eddgie
Reged: 02/01/06
Re: Minimizing SCT vignetting while maximizing FOV... [Re: jrbarnett]
      #5820509 - 04/24/13 07:03 PM
Just an opinion... The difference between the light paths of the the two types in 1.25 is not meaningful. Maybe not the case in 2" but I could not tell you for sure.
15 registered and 15 anonymous users are browsing this forum.
