Bogglman
Reged: 03/28/13
Loc: Sunny San Diego, CA
Newer Coronado PST with older SM40 double stack?! new
      #5808614 - 04/19/13 12:52 PM
Hi all, I have a newer Mexican made PST and have a US made SM40 double stack which doesn't thread onto the newer PST. They both have different thread pitches. Anyone have a go at this before or if someone knows the thread type of the PST and SM40?
Howlt
Reged: 02/14/07
Re: Newer Coronado PST with older SM40 double stack?! new [Re: Bogglman]
      #5817396 - 04/23/13 12:51 PM
I asked a Meade rep at NEAF if the threads were the same on the new filters because I have an older PST and was wondering if I could doublestack with a new filter. He said the 40mm, 60mm, and the 90mm were the same and that I wouldn't have to worry about matching filters "like they did in the old days" since the new filters rotate.
Bogglman
Reged: 03/28/13
Re: Newer Coronado PST with older SM40 double stack?! new [Re: Howlt]
      #5817752 - 04/23/13 03:10 PM
He's possibly correct. But if you want to use the t-max tuner from the USA era it will not thread onto the PST. Simply screwing on another filter onto the PST tube will yield minimal results. Must be able to tweak while you peek
marktownley
Reged: 08/19/08
Loc: West Midlands, UK
Re: Newer Coronado PST with older SM40 double stack?! [Re: Bogglman]
      #5821299 - 04/25/13 04:42 AM
I think it is a 55-52mm step down ring that you will need, which if you get of fleabay or somewhere like that are really cheap. I would recommend a metal one not plastic.
Bogglman
Reged: 03/28/13
Re: Newer Coronado PST with older SM40 double stack?! new [Re: marktownley]
      #5823530 - 04/26/13 02:32 AM
Thanks Mark ! I went to a few local places and none could help... I'll have go at the step down ring.
BYoesle
Reged: 06/12/04
Loc: Goldendale, Washington USA
      #5823882 - 04/26/13 09:30 AM
If that doesn't work I've had good results from http://www.preciseparts.com
Bogglman
Reged: 03/28/13
Re: Newer Coronado PST with older SM40 double stack?! new [Re: BYoesle]
      #5843780 - 05/06/13 03:03 PM
Step down rings were a no go. It appears to be a thread pitch issue. A 49mm will only give 1/2 turn then tighten.. Almost like the new PST is standard thread?!
Eclipse
Reged: 03/24/09
Loc: Solada EspaƱa
      #5877695 - 05/22/13 10:21 AM
I was a little concerned when I first read this thread. Being the owner of a US -made PST and having recently ordered the latest - and presumably Mexico-made - SME-40 double stack.
But no problem - they screw together beautifully as if they were made for each other - which of course they were !!
So is there any real issue here?
Edited by Eclipse (05/23/13 07:54 AM)
7 registered and 10 anonymous users are browsing this forum.
Moderator:  Phillip Creed, nitegeezer
