HowardK
Reged: 10/20/10
Tip for Az Eq6 users
      #5827152 - 04/27/13 07:33 PM
Maybe you alll thought of this but....
In ALT AZ mode the Az Eq6 mount can be tricky to collimate the 2nd scope in Az...here's what I suggest...
Buy a set of car engine feeler guages....there will be one in there that will shim out the dovetail on the 2nd scope to bring it perfectly in line....especially if its a vixen type dovetail bar as this sits flush in the saddle giving plenty of area for the shim to do its shimming...much better than folding strips of aluminium foil.
frolinmod
Reged: 08/06/10
Loc: Southern California
Re: Tip for Az Eq6 users new [Re: HowardK]
      #5827236 - 04/27/13 08:07 PM
Anthony at ADM Accessories sells a "hocky puck" style counterweight shaft to (ADM) dovetail adapter with azimuth push/pull adjustment bolts built right in. He'll customize it for any counterweight shaft diameter. The AZ-EQ6 uses a one inch diameter counterweight shaft. Note that it expects you to do altitude adjustment by rotating the shaft, hence doesn't have any altitude adjuster.
I already had an ADM Accessories MAX-M, so I just put it on the counterweight shaft side instead. Adjustments with the MAX-M are fast and easy.
HowardK
Reged: 10/20/10
Re: Tip for Az Eq6 users new [Re: frolinmod]
      #5827976 - 04/28/13 09:45 AM
Can u show me the link to the adjustable ADM adapter?
I have the max m but its weight is too heavy
frolinmod
Reged: 08/06/10
      #5828029 - 04/28/13 10:26 AM
It's the DUAL-CW which you can find on this webpage.
HowardK
Reged: 10/20/10
      #5828345 - 04/28/13 01:18 PM
Interesting
biz
Vendor
Reged: 11/08/09
Loc: New Zealand
      #5828569 - 04/28/13 03:03 PM
Hi Howard.
Just remember you have the saddle that you sent me that I inserted cone adjustment screws. This was done to cure the problem of adjusting the secondary OTA.
You may be able to get that to fit your new mount.
cheers.
Graham.
HowardK
Reged: 10/20/10
Re: Tip for Az Eq6 users new [Re: biz]
      #5828618 - 04/28/13 03:29 PM
Yup
That is exactly what i am going to do......
Nice one Graham
HowardK
Reged: 10/20/10
      #5828619 - 04/28/13 03:30 PM
Just need a vixen rail though for the OTA
biz
Vendor
Reged: 11/08/09
Loc: New Zealand
      #5828917 - 04/28/13 06:58 PM
Yup
Nice one Graham
Howard, let me know how you get on.
Cheers.
Graham
19 registered and 41 anonymous users are browsing this forum.
