Telescope Specific Forums >> Meade Computerized Telescopes
REC
Reged: 10/20/10
Loc: NC
125 ETX Focusing Problem new
      #5792108 - 04/11/13 10:57 AM
My 125 ETX has real bad image drift to the point of the object moving out of the FOV and have to move the scope as I try to get it in focus. I have tried moving the focus knob all the way one way and back, but not much improvement/
Is there any step by step method for removing the back and tighten the focuser as something back there must be loose. I don't have any problems focusing my 90ETX.
Pictures of te steps or how to video would be great!
Bob
tomatohead
Reged: 11/21/10
Re: 125 ETX Focusing Problem new [Re: REC]
      #5793049 - 04/11/13 06:44 PM
this may help:http://www.weasner.com/etx/techtips/2011/etx125_focus_mod.html
redlinedb16a
Reged: 10/17/10
Re: 125 ETX Focusing Problem new [Re: tomatohead]
      #5822080 - 04/25/13 01:04 PM
I ripped mine to pieces a few times
Nothing to it
Grab the purple tube and unscrew it carefully
It will give you a perfect view of the mirror and slide
I regreased my slide and that corrected it
There's no adjustment on the focus
It's just a threaded rod.
I have a step by step here
http://www.astronomyforum.net/etx-telescope-forum/124524-dissassembly-my-ota-...
If you can't view the pics let me know
The etx is easy
REC
Reged: 10/20/10
Loc: NC
Re: 125 ETX Focusing Problem new [Re: redlinedb16a]
      #5824142 - 04/26/13 11:14 AM
Well I was at the Meade booth at NEAF last week and the tech guy suggested the same thing, unscrew the barrel to get at the focuser. The only thing he cautioned is that once you open it up, you take the chance of messing up the collimation. So is this way better then opening up the back of the housing?
I'll try this link you listed, but looks like I have to subscribe or join?
Thanks for your help!
Bob
redlinedb16a
Reged: 10/17/10
      #5824164 - 04/26/13 11:28 AM
When I get home ill post pics
Yes if you unscrew the corrector plate or tube there is a chance you the alignment can be off
Mine has be apart several times and I have zero issues
Images are extremely crisp
Pay attention to how tight the tube was
Make alignment marks to ensure you don't over or under tighten it when putting it back together
Personally if you pull it apart I'd flock the tube,flocking made a world of diffrence in mine,I gather more light now
When you remove the mirror and grease the slide the grease will take up some slack which will help
I used gray Molly grease
On the focus rod also
REC
Reged: 10/20/10
Loc: NC
      #5824179 - 04/26/13 11:33 AM
Ok, found your article and pictures. Where and what do I grease? Is there anything I have to tighten to help remove the image drift?
Bob
redlinedb16a
Reged: 10/17/10
      #5824457 - 04/26/13 01:39 PM
I removed the mirror and the mirror holder as one assembly
I applied a lite coat of grease onto the outside of the tube that the mirror/holder slide on
When you unscrew your tube and remove it,the mirror will be attached to the rear section
Work the focus knob and you will see what moves and what doesn't
That should show what needs to be greased
The only way to align the mirrors perfect again is too send it to meade or experiment which I wouldn't do unless I absolutely had to
On the back of the ota if you further dissassembly the scope there's are collimnation screws marked with red paint
I don't see unscrewing the tube having much mis alignment effects unless you screw it on way tighter or looser than when you pulled it off
Now with that said I'm in no way telling you to move foward
If you are not comfortable or mechanically inclined it may not be a good idea
On a 1-10 scale with 10 being the most difficult
To me it's a 2,easy and wear latex gloves in a clean environment
redlinedb16a
Reged: 10/17/10
      #5824472 - 04/26/13 01:46 PM
Look at the black tube in the center of the mirror
That's the tube that needs grease
There is a small metal ring that acts as a clip to hold the mirror on
That must be removed to be able to slide the mirror holder off the shaft
I don't quite remember what holds the focus shaft onto the mirror holder which I why I said unscrew the whole ota purple tube
That will allow you to see behind the mirror
redlinedb16a
Reged: 10/17/10
      #5824612 - 04/26/13 03:02 PM
After going thru my memory and photos
Here's the back of the ota behind the plastic
Pull off the focus knob unscrew the tube pull
If you choose to remove the mirror and mirror holder remove the clip on the small tube
Slide mirror/holder and focus shaft comes with it
Here's some pics
Notice the screws with red paint,I wouldn't touch those as they are for aligning the mirrors
And notice the clip on the tube that needs to be removed if you choose to remove the mirror
Now if your not sure about removing the mirror it can be grease in place but carefully not to get excess grease on the mirror
Bring the mirror all the way back like on my pick
Grease the front half of the tube.
Bring the mirror all the way to the front against the clip and grease the back half
Just a thin coat,nothing that drips or could fall off
What the grease does is lubricates of corse but grease will fill the gap between the tubes and will make it harder for image shift to occur
As I put my grease on I rotated my mirror around the tube as I pushed it down the slide to help evenly distribute the coat of grease.
I wiped off the lil extra that built up on the back side of the mirror holder
Honestly it's all easy to do
Just take your time and don't drop anything or touch the reflective mirror service
REC
Reged: 10/20/10
Loc: NC
      #5824696 - 04/26/13 03:34 PM
Well thank you very much for these step by step instructions and pictures and yes they are worth a thousand words:)
For the grease, what do I use and where do I get it?
Then the other matter is how to remove the scope from the fork mount as I guess that has to be done first?
Bob
redlinedb16a
Reged: 10/17/10
      #5824786 - 04/26/13 04:15 PM
Leave the scope on the mount
Just grip the purple ota and turn it counter clockwise
Remove just the purple tube
The plastic back of the scope will remain on the forks
If you want to remove the mirror get a .50 mm Allen wrench remove the focus knob
Remove the lil metal circle clip on the small tube
Simply slide the mirror assembly off
Grease shaft and re install
redlinedb16a
Reged: 10/17/10
      #5824794 - 04/26/13 04:21 PM
I removed my whole assembly cause my scope got rained on and debris inside
The etx 125 is Not a sealed ota
Look under the tube where the 1/4" 20 tripod mount is.....that's an opening in that 1/4" gap that allows debris in
redlinedb16a
Reged: 10/17/10
      #5825259 - 04/26/13 08:25 PM
Sorry forgot about the grease
I bought some napa Molly lube
It's thin and gray
I used it on my lx200 gears
Great stuff
REC
Reged: 10/20/10
Loc: NC
      #5825927 - 04/27/13 09:24 AM
Ok well I think I have enough information to tackle this project now. Need to find the grease in a local store if I can, otherwise I'll have to order a tube online. Any other type that you know of that is in a retail store?
Thanks so much for taking the time to help me with this solution
Bob
rtanton
Vendor (Explorer Scientific)
Reged: 02/06/07
Loc: Mission Viejo, CA
      #5826046 - 04/27/13 11:00 AM
Another alternative would be Dow Corning high vacuum grease. It is a good lube for applications other than metal to metal at high speed. It is silicone based with fumed silica filler and its viscosity will not change with temperature. Because it is silicone you need be careful where it is applied. Being stripped of light ends it will not migrate onto optics as a vapor. You can find small quantities on line e.g. http://www.amazon.com/Corning-Vacuum-Grease-Lubricant-Container/dp/B00B3O2YW4...
redlinedb16a
Reged: 10/17/10
Re: 125 ETX Focusing Problem new [Re: rtanton]
      #5826345 - 04/27/13 01:38 PM
Lowes or homedepot will have grease
The thicker the grease the more resistance you will have which will allow less image shift
Some types of grease would act like glue
Stay away from red or blue grease
White,light brown will do also
REC
Reged: 10/20/10
Loc: NC
      #5826565 - 04/27/13 03:33 PM
I forgot to ask from your last reply about flocking. In this picture it looks like you have lined the inner tube with some kind of felt or something? What do you suggest I use and how do you go about flocking it?
redlinedb16a
Reged: 10/17/10
      #5826652 - 04/27/13 04:22 PM
I got my flocking from scopestuff.com
Extremely fast shipping
However the flocking is not easy to do perfect
If you do mess up the glue is so strong it will rip the flocking off if you pull it apart then the glue has to be scrapped out
It's not to hard but a pain if you mess up
http://www.scopestuff.com/ss_flok.htm
Google telescope flocking,I think there's other stuff too
Geo.
Reged: 10/01/08
Loc: Upstate NY
Re: 125 ETX Focusing Problem [Re: redlinedb16a]
      #5827289 - 04/27/13 08:33 PM
The worst mirror flop I ever saw was in a 125. +1 for the dow grease. The small tub they sell on eBay will service several scopes.
The only way to screw up the collimation is to fool with those screws with the red thread lock on 'em.
REC
Reged: 10/20/10
Loc: NC
Re: 125 ETX Focusing Problem new [Re: Geo.]
      #5828002 - 04/28/13 10:07 AM
Thanks George, did you flock your tube too?
Bob
4 registered and 7 anonymous users are browsing this forum.
Moderator:  Starman27, Christopher Erickson, Starman81
