Pages: 1 | 2 | 3 | (show all)
Cotts
Just Wondering
Reged: 10/10/05
Loc: Toronto, Ontario
Re: Blackwater Observatory UPDATE! new [Re: Cotts]
      #5827066 - 04/27/13 07:13 PM Attachment (12 downloads)
More...
Cotts
Just Wondering
Reged: 10/10/05
      #5827071 - 04/27/13 07:14 PM Attachment (11 downloads)
Many hands make light work....
Cotts
Just Wondering
Reged: 10/10/05
      #5827075 - 04/27/13 07:15 PM Attachment (10 downloads)
And again.....
Cotts
Just Wondering
Reged: 10/10/05
      #5827084 - 04/27/13 07:17 PM Attachment (8 downloads)
The amazing crew from the North York Astronomical Association.....
Cotts
Just Wondering
Reged: 10/10/05
      #5827126 - 04/27/13 07:26 PM Attachment (13 downloads)
The Pod is up and 'running'. There are some issues with my plinth base and the concrete 24"x24" pads that it is sitting on. I will have to do some shimming to level the top off. The dome rotates reasonably well but there are a couple of high spots that need levelling out.
I have locked the dome and left nothing inside. When I return from the Texas Star Party in mid-May I will silicone all the seams and take care of the final shimming and levelling. Then install some 120vac and 12vdc wiring, lights, the flooring pads and, finally the telescope and mount. Should be first light well before june 1!!
There will be more pics of these details as they happen.
Thanks for staying tuned.
Dave
rockethead26
Reged: 10/21/09
Loc: Arizona, USA
      #5827153 - 04/27/13 07:33 PM
Looks great, Dave! I'm jealous.
Starhawk
Space Ranger
Reged: 09/16/08
Loc: Tucson, Arizona
Re: Blackwater Observatory UPDATE! [Re: rockethead26]
      #5827707 - 04/28/13 02:42 AM
That foundation you came up with looks pretty good, and getting through the door should be easier with the higher rim.
-Rich
Cotts
Just Wondering
Reged: 10/10/05
Re: Blackwater Observatory UPDATE! new [Re: Starhawk]
      #5827891 - 04/28/13 08:44 AM
Rich, the door entry was one of my main thoughts. I had a chance to try a 'standard' height Pod and the entry was very difficult for me with my combination of height and inflexibility. My plinth adds a very helpful 7".
I entered and exited my Pod several times yesterday with ease and the extra height inside makes it feel very roomy....
Dave
Midnight Dan
Reged: 01/23/08
      #5827965 - 04/28/13 09:37 AM
Nice, Dave! I've purchased a pod and will be getting it this summer, so I'm very interested in this. I'm not as tall as you and probably not as inflexible (although I'm a lot less flexible than I used to be!), but I'm still thinking that a few extra inches of height would be nice. If I decide to do something like this I need to make plans now because I'm putting in the pier first and need to get it to the right height.
Some questions. Do you plan to do anything to support the bays? What did you use for the diameter (inner and outer) of the plinth? It seems like you got that information ahead of time since you built the plinth before the pod arrived. Is there anything holding the plinth segments to each other, or are they just bolted to the base? Any thoughts on what you'd do differently with the plinth if you had to do it over again?
-Dan
Cotts
Just Wondering
Reged: 10/10/05
Re: Blackwater Observatory UPDATE! new [Re: Midnight Dan]
      #5828910 - 04/28/13 06:51 PM
Some questions. Do you plan to do anything to support the bays? I will put some wood base under them especially when I have shelves in them. What did you use for the diameter (inner and outer) of the plinth? It seems like you got that information ahead of time since you built the plinth before the pod arrived. The exact dimensions are on the Sky Shed Pod website. Is there anything holding the plinth segments to each other, or are they just bolted to the base? They are only bolted to the 24"x24" concrete patio slabs. Any thoughts on what you'd do differently with the plinth if you had to do it over again? I have had trouble making the plinth level. There is a variance, high spots to low spots, of about 1/2" which are entirely due to the patio stones which are a #$^$%&^ to move around and level. If I had a second chance I would consider a wooden form and poured concrete for the plinth. But how much $ ?
-Dan
10 registered and 6 anonymous users are browsing this forum.
