James Cunningham
Reged: 08/07/10
Loc: Maryland
Error 16 or 17?
      #5827982 - 04/28/13 09:47 AM
What would cause an intermittent Error code 16 or 17? This is recent. I have to hit "undo" to get it back communicating. It has happened the last 2 nights. It will not cause me to lose my alignment. Thanks.
dragonslayer1
Reged: 02/25/12
Loc: SLC, UT
Re: Error 16 or 17? new [Re: James Cunningham]
      #5828429 - 04/28/13 01:51 PM
Hey Jim, from all I read the easiest way to trouble shoot it is a power problem; spread power pin on scope or verify power supply is good and rock steady
Kasey
bogg
Reged: 11/17/09
Loc: Bruce County Ontario
Re: Error 16 or 17? new [Re: dragonslayer1]
      #5828895 - 04/28/13 06:39 PM
As dragonslayer1 says check the power supply. Another problem I have had are the pins and connectors from the handset to the scope and to the dec housing. Replacing the connector on the wire end solved mine. Good luck
jchaller
Reged: 05/29/08
Loc: Tenino, WA.
Re: Error 16 or 17? new [Re: bogg]
      #5835298 - 05/01/13 09:50 PM
I've had this occur several times, and it was just a bad power connection at the scope.
orion61
Reged: 10/20/07
Loc: Birthplace James T Kirk
Re: Error 16 or 17? new [Re: jchaller]
      #5839059 - 05/03/13 09:04 PM
YUP I had that, it was my Battery, try an A/C adapter the error will go away..NBD,
good luck
5 registered and 17 anonymous users are browsing this forum.
Moderator:  Brian Risley, panhard, Mitchell Duke, mayidunk
