Observing >> Solar System Observing
Pages: 1 | 2 | 3 | 4 | 5 | 6 | 7 | 8 | 9 | 10 | 11 | (show all)
stanislas-jean
Reged: 10/22/08
Re: Ashen Light - Redux new [Re: GlennLeDrew]
      #5787526 - 04/09/13 07:49 AM
May be it is not clear enough from me.
I am speaking about the diffraction edge created by the edge of the occulter: this effect can be seen visually at the eyepiece.
The light is spreading perpendicullary to the edge. You have to shift the lighted part of the planet disk fully behind the occulter for avoiding this.
After an exhaustive campain of tests on 2 days, with and without an occulter my conclusion was that the use of the oculter brought actually nothing consistent.
This was reinforced with the practice of tests on long distanced cibles consisting in a part highly lighted and a part low lighted with a known ratio of intensities.
Also same conclusion, the occulter bring nothing more and through was determined some possibilities: a ratio of 100 000 was still possible, the lighted part being 5000cd/m2.
Hope this is clearer.
All the numbers mentionned in my old posts were coming from these tests.
Stanislas-Jean
buddyjesus
Reged: 07/07/10
Loc: Davison, Michigan
Re: Ashen Light - Redux new [Re: stanislas-jean]
      #5788713 - 04/09/13 05:02 PM
gotcha
stanislas-jean
Reged: 10/22/08
Re: Ashen Light - Redux new [Re: buddyjesus]
      #5789483 - 04/10/13 01:48 AM
Sorry I donot understand, can you be clearer about.
Stanislas-Jean
Rick Woods
Reged: 01/27/05
Loc: Inner Solar System
      #5789509 - 04/10/13 02:24 AM
Stan,
"Gotcha" is American slang for "I've got you", which in this case means "I understand now".
stanislas-jean
Reged: 10/22/08
Re: Ashen Light - Redux new [Re: Rick Woods]
      #5789534 - 04/10/13 02:39 AM
Yes OK Rick, my english is not excellent.
Thanks.
Stanislas-Jean
buddyjesus
Reged: 07/07/10
      #5791384 - 04/10/13 09:58 PM
sorry for using slang given the people in the discussion. I will be more mindful in the future.
azure1961p
Reged: 01/17/09
Loc: USA
      #5791550 - 04/10/13 11:14 PM
Rodger Wilco there Buddy-j,
Pete
Rick Woods
Reged: 01/27/05
Re: Ashen Light - Redux new [Re: azure1961p]
      #5798913 - 04/14/13 05:11 PM
I have a book on the way; "Handbook of the Physical Properties of the Planet Venus", a NASA publication from the 60's (or maybe 70's). I'm hoping for a good review of the Ashen Light phenomenon in it. I have the equivalent publication for Mars, and it has great coverage of the Blue Clearing and several other topics.
These NASA handbooks are outstanding! The Mars one is available free as a downloadable PDF several places on the web. The Venus one may be also, but I didn't look (printing costs would have been greater than the cost of buying it.)
Rick Woods
Reged: 01/27/05
      #5801932 - 04/16/13 02:34 AM
The book came today; NASA SP-3029 (1967). It only has about a page and a half on the Ashen Light, though. Pertinant quote:
"Weinberg and Newkirk were unable to identify any emission lines on 20 spectrograms taken of the unilluminated portion of Venus in 1959. But their failure in 1959 and Newkirk's success in 1958 are consistant with independent visual searches during these two periods. However, Weinberg and Newkirk are not convinced of the reality of the ashen light phenomenon and, at present, it must be concluded that there is neither a satisfactory explanation nor definite proof of its existance."
There's a bit of explanatory test before this; but they really give it short shrift, and end up with the same inclusive conclusions we still have now. I was hoping for a little more in-depth treatment of the subject, similar to the (superior) Mars version of this book.
Ah well - I laughed, I cried, I kissed six bucks goodbye. There's a lot more stuff in this booklet though, so it was still a good buy.
Rick Woods
Reged: 01/27/05
      #5815408 - 04/22/13 02:20 PM
I found an interesting article from 1970 in the JBAA by D.S. Brown titled "The Ashen Light - A Refraction Effect?" in which the author makes a good case for the AL being caused by light refracted around from the daylight side by the dense atmosphere. This seems very plausible to me. So does Fred Taylor's theory of the glowing red surface being visible sometimes through thin spots in the cloud cover. Evidently the auroral activity is considered unlikely because of the weak magnetic field of Venus.
Another article cites a German astrophotographer who imaged the AL in ultraviolet at the same time an observer was reporting it cisually through a blue filter.
Still another suggests lightning, as considerable evidence of lightning has been seen by spacecraft, and displays a preference for the evening side of Venus as opposed to the morning; the visual record mirrors this preference, but may be due to people preferring to observe in the evening instead of the morning.
My vote right now is for refraction; glowing surface runs second.
GlennLeDrew
Reged: 06/18/08
Loc: Ottawa, Ontario, Canada
      #5817586 - 04/23/13 02:06 PM
How high are the cloud tops? If at sufficient altitude, the clear atmosphere above will not have a particularly high density. That notwithstanding, would it not be a most astonishing coincidence that the refraction should be just so, in order to maintain a near constant level of illumination all the way to the anti-solar point on the globe? And if the atmosphere is dense enough to so strongly bend the light yet not attenuate it to any appreciable degree, implies an almost magical degree of transparency. To be so transparent over such long distances yet at the same time scatter light to the point of ready visibility is an obvious incongruity.
Such a degree of scattering can only occur with a significant degree of attenuation--after all, the scattered light is being 'removed' from continued direct propagation. In such case, any ashen light so resulting should be seen only as a glow confined to the terminator region, decreasing in surface brightness toward the anti-solar point, probably dimming to invisibility (against the other illumination from external sources) after perhaps some 5-10 degrees (several hundred to *maybe* 1,000 km) into the night side.
Edited by GlennLeDrew (04/23/13 02:19 PM)
azure1961p
Reged: 01/17/09
Loc: USA
      #5817801 - 04/23/13 03:31 PM
You know what's more compelling to me here if I could sidetrack a moment - when the crescent is ultra thin and the terminator particularly toward the cusps begin to reveal the patchy cloud topography. Glenn mentioning the glow beyond the terminator on an example and it merely made me think of another cloud phenomenon.
Ok back to scheduled programming.
Pete
Edited by azure1961p (04/23/13 03:32 PM)
Rick Woods
Reged: 01/27/05
      #5818168 - 04/23/13 06:00 PM
Glenn,
The easiest answer I could find without lots of digging was from Patrick Moore ("Venus", 2002, p.151):
"There are various cloud layers. The upper clouds lie at around 43 miles above ground level; the cloud deck ends at 18 miles above the surface, and below this the visibility is unexpectedly good..."
Does this tell you anything?
David Knisely
Reged: 04/19/04
Loc: southeastern Nebraska
Re: Ashen Light - Redux new [Re: ROBERT FREE]
      #5819743 - 04/24/13 12:58 PM
ive seen it a few times myself over the years,but sometimes i think the brain causes some of it ,but patrick moore has also stated he an other good astronomers saw that as well.in daylight when the crescent is real big i saw it a few times over the years and the surface area was definitely darker on venus opposite the crescent.
Well, very very near inferior conjunction with Venus as narrow a crescent as it can get, there is light scattered by the atmosphere of Venus that will sort of "complete the circle" of the entire edge of the disk of the planet (and may be visible and recordable in daylight observations), but this is not the Ashen light. The Ashen light is quite faint and is reportedly seen on the un-illuminated disk of Venus under darker sky conditions with a planetary phase that is not as strongly crescent as the inferior conjunction is and is also seen away from the limb of the planet. I have never seen it, but it may be a variable phenomena. To my knowledge, it has never been imaged and there isn't much hard evidence for its existence. Clear skies to you.
GlennLeDrew
Reged: 06/18/08
Re: Ashen Light - Redux new [Re: David Knisely]
      #5820524 - 04/24/13 07:06 PM
Rick,
At an altitude of 50 km or so, Venus's atmospheric pressure is much like that at sea level on earth. At the cloud tops of 43 km, the air pressure would be a big greater than at sea level on Earth. Our atmosphere refracts light at sea level by just over 1/2 degree. At cloud top level on Venus, then, we might assume a refraction of about a degree.
A check on this is afforded by the observation of the completion of the atmospheric ring of light around the full disk when very near inferior conjunction. The elongation of the planet from the Sun st that time tells us that this is angle light is refracted into the night side.
Rick Woods
Reged: 01/27/05
      #5822242 - 04/25/13 01:52 PM
Glenn,
That was 43 miles, not kilometers.
Also, you'd have to consider the density, constitution, and conditions of the atmosphere. The AL isn't always there; there must be conditions that occur periodically that make it visible.
Rick Woods
Reged: 01/27/05
Re: Ashen Light - Redux [Re: Rick Woods]
      #5832398 - 04/30/13 01:52 PM
In the now-locked "Spokes on Saturn's Rings" thread, one member made the comment in passing that the AL had indeed been imaged in visible light. That was, of course, a minor bombshell to drop; and several of us encouraged him to provide, or point us at, some documentation of it here in this thread. I also PM'd him with this request.
So far, no response has been forthcoming; so much as I'd love to see such an image, I think we're back to the "never been imaged" point.
Rats!
2 registered and 7 anonymous users are browsing this forum.
Moderator:  Rich (RLTYS), star drop, dr.who
