highfnum
Reged: 09/06/06
Loc: NE USA
mallincam with c11 f3.3 new
      #5834973 - 05/01/13 06:30 PM Attachment (112 downloads)
it was nice last night so
i took out the little beasty(C11)
and took a few shots - its been awhile
M51 M97 M 81
highfnum
Reged: 09/06/06
Loc: NE USA
Re: mallincam with c11 f3.3 new [Re: highfnum]
      #5834977 - 05/01/13 06:31 PM Attachment (67 downloads)
m97
highfnum
Reged: 09/06/06
Loc: NE USA
      #5834978 - 05/01/13 06:32 PM Attachment (67 downloads)
m81
Dwight J
Reged: 05/14/09
      #5834981 - 05/01/13 06:34 PM
The C11, F 3.3 focal reducer, and Mallincam make a great combo. I use the same setup to great effect. Nice grabs!
dragonslayer1
Reged: 02/25/12
Loc: SLC, UT
Re: mallincam with c11 f3.3 new [Re: Dwight J]
      #5835372 - 05/01/13 10:49 PM
very nice pictures, you have a ballpark integration time on the M51 shot please?
Kasey
highfnum
Reged: 09/06/06
Loc: NE USA
Re: mallincam with c11 f3.3 new [Re: dragonslayer1]
      #5835644 - 05/02/13 04:03 AM
51 was 56 sec
Larry F
Reged: 05/24/04
Loc: Westchester, NY
      #5835862 - 05/02/13 09:30 AM
Nice, John!
Atl
Reged: 04/13/12
      #5835866 - 05/02/13 09:31 AM
Question about the colored stars. Are they the actual color or is this an artifact? My camera was doing this last night but I wasn't sure what to make of it.
highfnum
Reged: 09/06/06
Loc: NE USA
Re: mallincam with c11 f3.3 new [Re: Atl]
      #5835867 - 05/02/13 09:35 AM
some of that square looking green blue red looking stars are
'hot pixels' not real stars
1) did not have TEC on
2) proper way is to create a dark frame and subtract to get rid of them
3) these pictures are 'graps' as you see them on HDTV
highfnum
Reged: 09/06/06
Loc: NE USA
Re: mallincam with c11 f3.3 [Re: Larry F]
      #5835872 - 05/02/13 09:37 AM
thx larry
Atl
Reged: 04/13/12
      #5836018 - 05/02/13 10:55 AM
Ok thanks...I am still figuring out what's going on with the images I am seeing.
dragonslayer1
Reged: 02/25/12
Loc: SLC, UT
      #5836084 - 05/02/13 11:27 AM
thank you, you are using hyperstar it would seem with such a fast focal length? Which camera are you using? thank you, Kasey
highfnum
Reged: 09/06/06
Loc: NE USA
      #5836134 - 05/02/13 11:58 AM
no hyperstar- simple f3.3 SCT focal reducer/corrector
hyperstar is faster than that(2.0)
MCHP - mallincam today its considered older model
nytecam
Reged: 08/20/05
Loc: London UK
      #5836358 - 05/02/13 01:51 PM Attachment (22 downloads)
no hyperstar- simple f3.3 SCT focal reducer/corrector hyperstar is faster than that(2.0)
Hi - excellent pics is hotpixel removal post processing? Regarding the quoted f/3.3 FR - is that a nominal value or the actual f/ratio on the scope? The two may not be the same. I run my nominal 3.3 FR @ f/3.6 but who am I to get technical My Owl PN from last night via Lodestar in 60s exp
GlennLeDrew
Reged: 06/18/08
Loc: Ottawa, Ontario, Canada
Re: mallincam with c11 f3.3 new [Re: nytecam]
      #5836405 - 05/02/13 02:10 PM
With my Meade f/3.3 reducer and Mallincam (with CCD 12.5mm below the lens mount's front surface), the 60mm long 2" visual back w/ 2"-1.25" adapter results in exactly f/3.3. This tells me that the focus must lie 72.5mm from the shoulder on the reducer's cell. This shoulder I refer to is the edge which a threaded on adapter stops against.
It could be the case that more recently made reducers are somewhat different in dimensioning...
highfnum
Reged: 09/06/06
Loc: NE USA
      #5836411 - 05/02/13 02:13 PM
I don't know
highfnum
Reged: 09/06/06
Loc: NE USA
      #5839714 - 05/04/13 08:36 AM Attachment (36 downloads)
a little late adding m101 same set up
FishInPercolator
Reged: 04/30/13
Loc: NYC
      #5869548 - 05/18/13 03:17 PM
How did you achieve a f/3.3? I asked around how to do this with a C6 f/10 and was told with the Universe version there are inevitable problems due to chip size.
A. Viegas
Reged: 03/05/12
Loc: New York City/ CT
Re: mallincam with c11 f3.3 new [Re: FishInPercolator]
      #5869619 - 05/18/13 03:56 PM
Jason -
For focal reduction in a typical SCT at prime focus you can either use the Celestron or Meade F6.3 of F3.3 correctors, these you can usually find around used for $75-90. For Mallicam specifically, there is a MFR5 focal reducer you can buy that comes in two pieces, and can be put together in such a way as to get from 0.39 - 0.8x in reduction. This adapter costs $250. The FL on a C6 is what ~1500mm ? so I think you could probably achieve good results using a stock F6.3 corrector. I am not sure if the F3.3 corrector would produce too much vignetting on the C6...
Al
Stew57
Reged: 05/03/09
Loc: Silsbee Texas
      #5869730 - 05/18/13 04:55 PM
The chip size in the Universe is much larger than the mallincam extreme, X2, or VSS. Focal reducers work well with the smaller chips. You will get vignetting with the Universe with the above mentioned reducers. Celestron makes a specific reducer for large chip cameras and the HD line of scopes. These should work fine. There may be others but the reduction factor is limited.
7 registered and 6 anonymous users are browsing this forum.
Moderator:  csa/montana, JayinUT
