Privacy Policy | Please read our Terms of Service | Signup and Troubleshooting FAQ | Problems? PM a Red or a Green GuÖ uh, User
Sean Wood
Reged: 04/19/11
Loc: North Carolina
Could the Samsung Nx1000 work fo astrophotography? new
      #5834434 - 05/01/13 01:39 PM
Thinking of maybe doing some astrophotography(Famous last words, right?). Woot.com keeps posting the Samsung NX1000 for $299. With it being 20.3MP, having less mass and weight than a typical DSLR and yet still having the ability for interchangeable lenses, a must for a T-mount. I was thinking it might make it ok for entry level astrophotography. Or would it would be an outright waste of time and money, please explain why it would be.
It seems to have a 4 min maximum "bulb" time. Would that be a significant problem?
Educated guesses as to what types of modifications I might would have to make to use it, if using it is even an option would be appreciated.
areichow
newbie
Reged: 04/30/13
Re: Could the Samsung Nx1000 work fo astrophotography? new [Re: Sean Wood]
      #5834541 - 05/01/13 02:31 PM
I've wondered that myself, for wide field/starscape type shots. Consensus seems to be that the camera isn't great for low-light work, though IQ at lower ISOs seems pretty good.
mpgxsvcd
Reged: 12/21/11
Loc: Raleigh, North Carolina
      #5834569 - 05/01/13 02:44 PM
You are probably going to just get a bunch of comments like. Use a Canon. It is better. I havenít tried the NX so I am not sure if it is good or not. However, I do have a lot of experience with Micro Four Thirds cameras that are very similar in terms of low light exposure so I will share my thoughts and hypothesis.
The bulb limit really depends on the final focal ratio of your scope. I use an F4.0 scope and I blow out the sky in my backyard in 1 minute at ISO 1600. Therefore, I rarely need to go over 4 minutes. However, if you are running an F8.0 or slower scope you could definitely need 4 minutes or more depending on your sky conditions.
The Samsung NX cameras are APS-C sized sensors. However, they have packed a lot of pixels into those sensors. The low light high ISO performance of the NX cameras is fine in the test results I have seen but I am not sure if it applies noise reduction to the RAW files or not.
If it doesnít apply any noise reduction to the RAW files then it should give you basically the same output that the Canon cameras do for stacking images. Both sensors score very similar results on DXO mark.
http://www.dxomark.com/index.php/Cameras/Compare-Camera-Sensors/Compare-camer...
My personal preference would be to get a Panasonic GX1 over the Samsung if you are using a faster scope. I like the way the live view mode on the Panasonic cameras work for AP. With those cameras you donít need to use anything like BackyardEOS for focusing or aligning. You can do everything in camera. The NX may be similar. However, I havenít seen any tests of that aspect for the NX. I use it all the time on my m4/3s cameras.
The bulb mode on the GX1 is limited to 120 seconds. However, tracking and sky glow usually start to become an issue before that especially if you are not guiding.
You can get a brand new GX1 on Amazon for $260.
http://www.amazon.com/Panasonic-DMC-GX1-Compact-System-Camera/dp/B00604YTFM/r...
If you really need 4 minutes for bulb mode then the Panasonic G2 will do that and it is only $310 for the body only on Amazon.
http://www.amazon.com/Panasonic-DMCG2K-12-1MP-Digital-Camera/dp/B004ACBYIQ/re...
Edited by mpgxsvcd (05/01/13 03:08 PM)
nofxrx
Vendor (HyperCams & Mods)
Reged: 07/12/05
Loc: Palm Bay,Florida
Re: Could the Samsung Nx1000 work fo astrophotography? new [Re: mpgxsvcd]
      #5835287 - 05/01/13 09:41 PM
Alright, just so I do not start any debates on whether a specific camera/model/manufacturer can be used for AP or not, let me just simplify it by saying this:
No matter what, CURRENTLY(and for the past ~4-6 YEARS) Canon has dominated the AP community.
Why?
Because they are great cameras.
They already have a TON of software and support for them (hello, BackYardEOS is reason ALONE to buy a Canon IMHO!!!!!)
And they PRODUCE. no questions asked. plug and play.
No worrying about this or that or anything...
They WORK.
Pretty much every digital camera (when I say that I am referring to ANY *removable lens type system*) nowadays is capable of brilliant images, both daytime and AP.
IMHO, get a Canon APS-C or Full Frame DSLR, get it modified, and you will be very happy.
Get something else, and you will probably still be very happy, but it may not be as easy to do.
RE: NX1000
I had an NX100, and it was HORRIBLE at ISO800 and up...
If I were looking at a mirror-less option, I would look no further than the Sony NEX cameras.
Great image quality thanks to the world famous Sony sensors
And they can be modified for AP/Full Spectrum/etc...
(I am sure the NX1000 is too, but I have not personally modified one, yet, so cannot comment on it)
Kay, I said my peace..
Good luck!
mpgxsvcd
Reged: 12/21/11
Re: Could the Samsung Nx1000 work fo astrophotography? [Re: nofxrx]
      #5835876 - 05/02/13 09:38 AM
The only problem I have with this statement is that it implies that ALL cameras need "a TON of software and support". In the past you had to have computer software that would allow the cameras to use longer shutter durations in live view or semi-live view. That is one of the reasons why BackYardEOS was created and it works very well to remedy that issue for Canon cameras. For Nikon cameras the software isn't there yet.
However, recently some mirrorless cameras(Panasonic and maybe more) have remedied the problem by putting the software into the camera directly which can eliminate the need for a computer at all. The issue is that not enough people know this. The stereotype that you cannot use in camera live view for AP will continue to persist until someone speaks up about it and enough people listen.
There is nothing wrong with recommending or using a Canon camera for AP. Like you said it works. However, the problem I have is when it is called the best camera simply because almost no one will dare try anything else.
Edited by mpgxsvcd (05/02/13 09:39 AM)
Footbag
Reged: 04/13/09
Loc: Scranton, PA
      #5836082 - 05/02/13 11:27 AM
You could use Magic Lantern and Canon will do all of that in camera, but I find a huge benefit of having a laptop with me in the field. Much easier to frame, align, focus, etc...
I'll be the first to ridicule Canon and other manufacturers for not allowing that to happen in a stock camera, but that's not to say I'd use the feature without my laptop if available. The laptop allows me to be more meticulous, and that improves my images.
Now Backyard EOS and soon to be NIK are amazing packages. They are simple, intuitive, and don't cost a lot. They alone are a good reason to buy a Canon (or a Nikon in anticipation).
mpgxsvcd
Reged: 12/21/11
Re: Could the Samsung Nx1000 work fo astrophotography? new [Re: Footbag]
      #5836135 - 05/02/13 11:58 AM
Have you tried the Panasonic or Olympus live view for AP? If not how can you say a laptop makes it "Much easier to frame, align, focus, etc..."?
I have done it with BackyardEOS and with the Panasonic camera. Both giving me the exact same abilities. The big thing is that doing it in camera allows me to do those things without the computer, battery issues, or the cables that go with it.
Footbag
Reged: 04/13/09
Loc: Scranton, PA
      #5836159 - 05/02/13 12:10 PM
I've used the camera screen live view with my Canon camera.
It has nothing to do with the capabilities or brand of the camera, it's the size of the screen. When I first started imaging, I used live view via the camera screen. I just couldn't see the screen well enough or find the buttons I needed. I didn't like touching the camera, because that could change the orientation or bump the mount. The other thing is that Live View actually creates lots of noise and occasionally glow. You need to turn the screen off before imaging. I use live view to frame and focus, then turn it off and let the camera cool down. Then I begin my acquisition routine.
mpgxsvcd
Reged: 12/21/11
      #5836209 - 05/02/13 12:38 PM
That is most of the problem. The things you mention are specific to how the DSLR live view works. With Mirrorless cameras, built-in wifi, and touch screens it is a little different.
A simple red Acrylic cover can remedy the LCD light pollution issue. However, I typically just turn the screen off and use the Electronic View Finder. That is something that the DSLRís canít do because their view finders are optical.
The screen size really shouldnít matter for focusing or alignment if you are using the magnified view. When the field of view is magnified to 10x it really wonít matter how big the screen is. The screen on the cameras I have is actually quite large.
In addition all of the new Panasonic micro four thirds cameras come with built-in wifi that can wirelessly stream the live view to a tablet. That will give you your hands free operation and the larger screen size you desire.
I will say that I have only tried the focusing with a Newtonian and the live view. The vanes on the Newtonian really make the focusing a lot easier than using another type of scope without a Bahtinov mask.
Footbag
Reged: 04/13/09
Loc: Scranton, PA
      #5836322 - 05/02/13 01:30 PM
I agree that built in WiFi would be nice, but I don't see mirrorless cameras operation being much different then DSLR's. You still have buttons, and relatively small screens. The benefit of the DSLR being slightly less noise. The benefit of the mirrorless being weight and size.
I don't find the viewfinder or the screen useful. I really do need to see my images on my laptop. I don't even think I'd be happy with an 11" laptop screen. With PHD, I have the laptop out there anyway, I might as well get the most out of it.
This morning, for example, I was shooting some flats for last nights session. I looked at the BYE screen and noticed one of my dust doughnuts was moving around with each exposure. I think it was dust, and was able to retake flats after tilting the tube differently; but if I had not noticed it, I wouldn't have any flats for my entire session. I never would have noticed that on the cameras LCD.
After I'm setup and imaging, I typically monitor my session over my iPad from bed. My PHD star movement alarm is the only thing I have to listen to. If anything goes wrong, that's my clue.
mpgxsvcd
Reged: 12/21/11
      #5836438 - 05/02/13 02:21 PM
I havenít tried this yet. However, there is a program that will not only let you get the cameraís live view onto a laptop but it will also allow you to control the camera. All of this is over wireless. The link below shows how it works.
http://www.personal-view.com/talks/discussion/6703/control-your-gh3-from-a-we...
This is basically like BackyardEOS without the wires. The nice thing is that these m4/3s cameras give you 3 options. You can use the LCD screen, use the EVF, or use a laptop/tablet. All of the solutions are wireless and you donít have to choose any particular one. You can even switch back and forth.
mpgxsvcd
Reged: 12/21/11
      #5836456 - 05/02/13 02:27 PM
There is a really big difference between live view modes. The mirrorless can use any shutter duration and ISO value for the live view. That is a HUGE difference.
Also the wireless control of the camera remedies needing to touch the scope/camera/mount.
The biggest problem is that people generalize DSLRs vs. Mirrorless. They always say that DSLRs automatically have lower noise and mirrorless are always smaller. My GH3 is about the same size as the smallest Canon DSLRs. However, it noise profile is better than any Canon APS-C camera ever made according to the test results.
In the case of the newest mirrorless solutions they are almost always smaller than the Canon DSLRs and also offer better noise response. It really seems like Canon and its devote users are the only ones not willing to change. All of the newest Sony, Olympus, and Panasonic mirrorless solutions have surpassed all of the Canon APS-C solutions in pretty much every aspect over the last few months. Nikon is the only company that doesn't have a viable mirrorless solution now. However, their DSLRs are still king of the hill.
Edited by mpgxsvcd (05/02/13 02:36 PM)
Footbag
Reged: 04/13/09
Loc: Scranton, PA
      #5836564 - 05/02/13 03:14 PM
For someone using it for video astronomy, shutter duration during live view may be nice. I think Canon offers that, BYE has it, but I rarely use it. I'm usually just looking for a single star and the diffraction spikes from the B-mask.
I like the wireless feature, but that seems to be coming on all cameras. Personally, I think every electronic device should have a built in WiFi web server.
Nikon really did bring their A-game with their newest round of sensors. Hopefully, Canon will respond accordingly.
I'd be interested in seeing some 5m darks from some of the mirrorless cameras. I'm a bigger sensor, bigger pixel guy, but cannot wait until the mirroless outperform the current gen of DSLR's. Of course, at that point, the DSLR's will dominate the future line of mirrorless.
mpgxsvcd
Reged: 12/21/11
      #5836591 - 05/02/13 03:27 PM
I think the Canon DSLR's are going to need a time machine then. The mirrorless cameras already dominate them. It all lies in the Sony sensor that they are all using now.
Panasonic claims it is using their own sensor. However, the GH3 produces an identical RAW image down to the pixels with the Olympus OMD E-M5. Olympus has already stated that they use a Sony sensor in their newest cameras. When Olympus started using the Sony sensors their camera's low light ratings leap frogged over Canon and come very close to the Sony and Nikon offerings now.
Gary BEAL
Reged: 05/10/03
Loc: New Zealand
      #5836609 - 05/02/13 03:42 PM
And the Fuji X series, I use the X-Pro, great camera. Just the old fashioned with a cable release that gets me.
Gary
Footbag
Reged: 04/13/09
Loc: Scranton, PA
Re: Could the Samsung Nx1000 work fo astrophotography? new [Re: Gary BEAL]
      #5836623 - 05/02/13 03:51 PM
What do 5m darks frames look like with your GH3? Any visible noise?
I know the CCD guys talk about "noise free" Sony sensors, of course they are cooling them. I'd have to suspect mirror less have a bit more thermal buildup, but maybe not.
mpgxsvcd
Reged: 12/21/11
      #5836730 - 05/02/13 04:53 PM
I can make some samples. What ISOs? ISO 6400 is the last true electrical ISO but ISO 1600 is probably the ideal. The GH3 that I have was specifically designed with thermal build up in mind because its video capabilities are so highly regarded. That being said nothing is going to beat a cooled unit especially in the hot humid south where I live.
I am messing with a truly unique feature that only the Panasonic GH3 has. It will allow me to do almost the entire DSS stacking process in camera with an unlimited number of ISO 1600 RAW images. It can do lights, darks, even flats all in camera and all with RAW files. It even has several different ways of combining the images and you can switch back and forth between the different ways in-between images.
The feature is called Multi Exposure. However, the manual hardly talks about it and what it does say is wrong. It is almost like they started to make the feature decided it was too complicated but didn't want to take it out completely so they just left it in and didn't mention it anywhere else.
The great thing is that the feature really does work you just have to figure out how to get it to work to use it.
Stacking on the computer will always be better. However, there is something to say for producing excellent images in camera or on a tablet screen that you normally wouldn't be able to see until after you got home the next day.
I haven't produced any AP photos using this method yet. That is because the only thing it won't do is align the images. I haven't been guiding so far so this stacking process was useless. However, I have my guide camera being delivered tomorrow. After the cloud god's think I have done sufficient penance I am going to try it out.
If if the in camera stacking process doesn't work out I should still be able to get the exact same if not better images than the Canon cameras get since ever test I have seen has rated the GH3 as a better high ISO camera than the Canon APS-C offerings.
Footbag
Reged: 04/13/09
Loc: Scranton, PA
      #5836774 - 05/02/13 05:17 PM
5m at iso1600 would be good. Just want to get an idea of how the noise would compare to my older XS.
Sean Wood
Reged: 04/19/11
Loc: North Carolina
      #5837223 - 05/02/13 08:57 PM
WOW.... didn't mean to throw gasoline on an embers fellas... *BLEEP*.
I appreciate the suggestions to "go big or go home" with getting the more expensive Canon DSLR or even the other suggestions... But we're missing the point here... $299 for a 20MP camera. Going all in isn't an option at this point. I'm "ballin' on a budget" to cite a youthful euphemism. A kid in college and a sophomore in HS. The budget is stretched thin these days. I'm just really looking to get started to see if imaging is something I'd even be remotely into.
If this isn't a good entry level option then what other options are there out there in the sub $300 range.. OTHER THAN A MEADE DSI?
As far as controlling the camera I was considering the Samsung control software or one of the various other camera control packages for android... Use my tablet.. Leave the back screen completely off(no cool down after centering) and use the tablet as the control unit. Plus most of these allow downloading the images directly to the android device as well so no worries about even having to touch the camera outside of the focusing process. Or at least that's my line of thought for now...
Falcon-
Reged: 09/11/09
Loc: Gambier Island, BC, Canada
      #5837276 - 05/02/13 09:21 PM
I would say that the 20MP portion of the specs are really not all that important. It will be rather tricky to find a combo of excellent optics and good seeing to REALLY take advantage of all those pixels. Something like a T3/1100D is nearish your budget and a used XS/1000D or XSi/450D would be within it while still counting as the conventional-wisdom pick.
HOWEVER yes, that is a good price for a nice lightweight APSC sensor camera! My only worries would be that the control software you are talking about will let you do the max exposure times (would be no good if they could only do 30s exposures) or if the android-app control only downloaded JPEG rather then RAW. If those two concerns are met then yes, I agree with your line of thought.
18 registered and 31 anonymous users are browsing this forum.
Moderator:  Dave M, WOBentley, tecmage
