newtoskies
Reged: 07/15/12
Loc: SE Ma.
My first Globular Cluster - M13
      #5835961 - 05/02/13 10:21 AM
Last night was very clear so around 11pm I took both scopes out. I was trying to find M57 again but it was still too low in the LP over houses and trees so I thought I'd just scan the sky and take in all the stars and doubles. I then remembered there was a Globular in Hercules so I scanned the area with my Dob and bingo, there it was, M13. WOW what a sight. I usually enjoy open clusters more but M13 was just amazing. I used different ep's and mag and settled on my 12mm Paradigm ED which I think gave me the best views. The core was very bright but I was able to see dozens on stars in the outer edges and at times it looked like a spiral galaxy when seeing was not good, spiral arms. Will search later for images to be sure if what I saw is correct.
I didn't try with my 102 because at that time I had packed it up after viewing Saturn. Will try for this one again but with the 102 to see if the views are better. Had a good 2 hours behind the scope, one hour just on M13 alone. Also spent a few minutes viewing M51 with the dob but it was at zenith. Resolving the stars in the cluster was fun and with the dob you can't beat it.
GOLGO13
Reged: 11/05/05
Loc: St. Louis area
Re: My first Globular Cluster - M13 new [Re: newtoskies]
      #5835965 - 05/02/13 10:25 AM
Yep...that's my favorite type of object!! In dark skies they can be crazy good. M13 is probably the best in light polluted skies. Try M92 which should be pretty close to M13. It's a little tighter, but also a good one.
Very cool objects!
mak17
Reged: 02/08/11
Loc: Central Florida
Re: My first Globular Cluster - M13 new [Re: GOLGO13]
      #5835977 - 05/02/13 10:29 AM
Good job on the find. Your 4 inch won't show you a better view but it is def worth a look. From dark skies there's a cool galaxy just north of m13. Also be sure to track down m92 which is also in hercules. M3 is one to check out as well. I know it's up at that time.
newtoskies
Reged: 07/15/12
Loc: SE Ma.
Re: My first Globular Cluster - M13 new [Re: mak17]
      #5836013 - 05/02/13 10:53 AM
Yep I knew there was another in that area but couldn't remember what area. I didn't have my charts out and didn't feel like destroying my dark vision to go get them. I will have to look up M92 and search for it, and M3 again.
Last night is where I started to think again that a 10 or 12" dob would come in handy.
REC
Reged: 10/20/10
Loc: NC
      #5836060 - 05/02/13 11:20 AM
Later on in the year it will be almost straight up and less air to go through. On good seeing nights you can pop that 9mm in your scope and it will take up the whole FOV. Try using averted vision on this one to resolve more stars. Next up in the summer is another great one, M22!
Clear skies:)
bob
GOLGO13
Reged: 11/05/05
Loc: St. Louis area
      #5836061 - 05/02/13 11:20 AM
Yep...DSOs are where the big scopes can be handy for sure!
I find my 10 inch is as big as I would want to go as far as tube dobs. But if you are able to handle the 12 easier, it's worth a thought. Think about transport as well since they are really good in dark skies.
One reason I think it's OK you didn't get the 8 inch is going from a 6 to 10-12 is a much bigger jump. If you could only have one scope, the 8 inch is a good compromise. But I personally like having the 10 over the 8 myself. I've done some comparisons in dark skies and I find the 10 is a nice do it all scope.
If I were going 12+ I would go truss design or the Discovery split tubes.
newtoskies
Reged: 07/15/12
Loc: SE Ma.
      #5836116 - 05/02/13 11:45 AM
Just looked up M13 in Turn Left and saw that NGC6205 is in the same area. Will have to look for it, or try to, next time.
if I can find a used 10-12" in my area I will try to grab it. I love the 6" but for my LP I think a bigger dob will show a bit more. I thought about an 8" and had seen one used for an ok price, but it won't be much of a jump up like you said. We'll see what happens this year.
MikeBOKC
Reged: 05/10/10
Loc: Oklahoma City, OK
      #5836139 - 05/02/13 12:00 PM
There's a whole parade of fine globular clusters coming up in the east in the next month or two. Be sure to put M22 on your summer list. Lots of folks consider it even more visually spectacular than M13.
newtoskies
Reged: 07/15/12
Loc: SE Ma.
Re: My first Globular Cluster - M13 new [Re: MikeBOKC]
      #5836164 - 05/02/13 12:13 PM
I have been looking at that too. Seems there will be a lot of globulars coming up soon...can't wait. I am going to order the RACI finder to make life easier in finding them.
ensign
Reged: 12/16/08
Loc: Southwestern Ontario
      #5836186 - 05/02/13 12:27 PM
Be sure not to miss M5. This is a fine globular as well.
newtoskies
Reged: 07/15/12
Loc: SE Ma.
Re: My first Globular Cluster - M13 new [Re: ensign]
      #5836589 - 05/02/13 03:24 PM
I'll have to right a list ans a plan for viewing. I'll sort it by viewing time with the easy ones for when I don't have much time, and for the harder ones when I have a few hours.
NewMoonTelescope
Vendor
Reged: 08/31/12
Loc: Upstate NY
      #5837086 - 05/02/13 07:25 PM
M13 was my first DSO, and the one that got me hooked. No matter how many years you observe, you never quit appreciating its magnificence. Great job, and thank you for posting. Brings back memories...of last night as I too was busy studying M13
David Castillo
Reged: 09/09/06
Loc: Carmel Valley, Ca
Re: My first Globular Cluster - M13 new [Re: NewMoonTelescope]
      #5837101 - 05/02/13 07:36 PM
That glob got me hooked, and induced a terminal case of aperture fever, That is in a state of dormancy brought on by a lack of funds. I fear a tax refund may bring on a relapse. ( I tried the old home remedy of upgrading eyepieces, but it didn't stop this disease).
Dave
lamplight
Reged: 09/18/12
Loc: western MA, U.S.
Re: My first Globular Cluster - M13 new [Re: David Castillo]
      #5837765 - 05/03/13 08:09 AM
Rob
The nights of apr 30th and may 1 were very good.. I saw m13 first time too that night .. And many more globular clusters!! There's a whole new batch of stuff coming up.. Was out for about 4 hours .. Unfortunate the night of may 1 looked good as well but I was too tired other than a,peak at Saturn.
Seeing and transparency were well above average conditions 4/30-5/1.. And to get to view globulars over faint smudges in Virgo was a treat.. Shoot I should have tried for some of the previously seen galaxies.. I was too excited about the new objects and constellations ..I think my limit that night was roughly mag 4.6 / 4.9 visual, its usually much worse..
Anyhow.. M13 and the other clusters that night were great, and I was only using my 5", I bet you resolved a lot more stars in your DOB!
newtoskies
Reged: 07/15/12
Loc: SE Ma.
Re: My first Globular Cluster - M13 new [Re: lamplight]
      #5837777 - 05/03/13 08:19 AM
Matt I only spent 2 hours behind the scope but it was a great.
I didn't have my charts out so I basically was going by memory of where things should be. Like you I too was checking the constellations and trying to make out the stars. Was a wonder that I could make out hercules since the stars in that constellation were barely to be seen where I am.
Classic8
Reged: 04/12/06
Loc: Naperville, IL, USA
      #5837885 - 05/03/13 09:27 AM
Ditto the previous comments about M5 and M22. Those are very nice ones.
Kraus
Reged: 03/10/12
Loc: Georgia.
Re: My first Globular Cluster - M13 new [Re: Classic8]
      #5837942 - 05/03/13 09:53 AM
You do like I. I switch eyepieces and filters for the best view. Pay nothing to 'rules' "Oh an OIII won't work because blah blah blah".
And I too spend about an hour on an object. One misses much if they get into the 'marathon' mode.
Yes Messier 5 is a grand one as well. Last year as I looked at M-5, an open cluster hovered behind it. Quite eerie it was.
lamplight
Reged: 09/18/12
      #5838166 - 05/03/13 11:40 AM
were you able to grab the free version of skysafari basic for your phone when it went on sale couple weeks ago??
newtoskies
Reged: 07/15/12
Loc: SE Ma.
      #5838289 - 05/03/13 12:36 PM
I didn't catch that. I have some app that is ok. I usually just tour the night sky with no plan and just take it all in. Might say ok I'll look for M or NGC *** and if I can't find it I just hit the usual planet and scan the sky and look at doubles, open clusters but mainly just enjoying the time behind the scope. Basically learning the sky, my scope and thinking how small we really are compared to the galaxy and universe.
lamplight
Reged: 09/18/12
      #5838541 - 05/03/13 02:55 PM
Meditative . I get it. Spent an hour on Saturn wondering which were moons.. Think I saw 4. Tonight looks good!! I'm making coffee I might drag out the eq mount and try a pic or two since I can actually see Polaris for a decent align (I was waaaay off last year.. Used the phone compass.. Terrible.. !!). I think you said you have a thing Fridays but maybe when you get back sneak a peak.. Conditions are reporting average to above average for here.. Your seeing forecast doesn't look the best though..
http://cleardarksky.com/c/BrstObMAkey.html?1
2 registered and 8 anonymous users are browsing this forum.
Moderator:  WOBentley, kkokkolis
