Pages: 1 | 2 | 3 | (show all)
Levine
Reged: 03/24/06
Loc: 40° 47' 52" N / 85° 49' 14" ...
ZAO I vs. ZAO II...?
      #5841640 - 05/05/13 01:04 PM
I recently corresponded with a friend overseas. He had bench tested the two generations of ZAO's with a laser interferometer, and found the results to be so dissimilar that he felt that there was hardly basis for comparison.
He much prefers and recommends the I's over the II's
Now, those are his eyes, and all of our eyes are FAR less sensitive than an interferometer.
So the question: given the following conditions -
Dark and steady skies with optimal seeing
An optically perfect telescope
Sample EP's from both batches selected at random
An experienced observer who has worked with "good" orthos for a long period of time
- would any *MEANINGFUL* differences in performance be detected?
Any of you who have had "head to head" experience with these pieces, please tell us about your observations and preference.
leonard
Reged: 10/19/07
Loc: West Virginia
Re: ZAO I vs. ZAO II...? new [Re: Levine]
      #5841705 - 05/05/13 01:34 PM
Hello ,
He much prefers and recommends the I's over the II's <<<<<
Which brings up the question , what did this test show your friend ????????????????????????
Levine
Reged: 03/24/06
Re: ZAO I vs. ZAO II...? new [Re: leonard]
      #5841765 - 05/05/13 02:19 PM
Hello ,
Only that the resulting diffraction patterns were different.
That's all.
leonard
Reged: 10/19/07
Loc: West Virginia
      #5841868 - 05/05/13 03:24 PM
Hello Levine,
IMO , this test your friend did would have no bearing on the optical performance of these two eyepieces . I may be wrong but both the Zeiss 1 an Zeiss 2 are excellent .
The fact this person is basing his judgement on a different pattern says nothing at all.
Leonard
Jeff Morgan
Reged: 09/28/03
Loc: Prescott, AZ
      #5841896 - 05/05/13 03:39 PM
Good question.
Send me a set of each and I'll get back to you in a year.
Levine
Reged: 03/24/06
      #5841899 - 05/05/13 03:41 PM
Hello Levine,
Leonard
Right...Interferometry, and viewing with one's eye, are two different things: you cannot directly infer or predict "real world" perfomance based solely upon bench testing.
SteveC
Reged: 06/15/06
Loc: Sunshine State & Ocean State
      #5841900 - 05/05/13 03:41 PM
I compared both sets and couldn't find any visual differences, other than the fact that ZAO I's were available in 25mm and 34mm (?). I kept the ZAO II's because they were newer and sold off the I's..............except for the 25mm, which I still own.
Levine
Reged: 03/24/06
Re: ZAO I vs. ZAO II...? new [Re: SteveC]
      #5841904 - 05/05/13 03:44 PM
I have the 34 and 25 ZAO I's, plus the II set.
My eyes, 'scopes, and seeing are all so-so.
Given that, I have found no reson to complain.
johnnyha
Reged: 11/12/06
Loc: Sherman Oaks, CA
      #5841916 - 05/05/13 03:55 PM
The ZAO-IIs are supposed to have better edge correction for faster scopes, down to f4. Whether this makes a difference on axis I dunno since I don't have any ZAO-Is for comparison.
SteveC
Reged: 06/15/06
      #5842005 - 05/05/13 04:42 PM
You're a lucky guy, that 34mm ZAO is a rare bird. I gave up my search for one a couple of years ago, just too difficult to find.
Levine
Reged: 03/24/06
      #5842096 - 05/05/13 05:31 PM
Pieces like this require determination, to be sure!
Acquisition requires 4 ingredients:
Time
Persistence
Ready cash
LUCK
When one finally came up for auction, I refused to allow it to slip away.
In my experiece, just about any EP you could imagine can eventually had, if you just stick to your guns.
For example, I once assembled a FULL Set of Clave focal lengths, including the 2" pieces.
I did it in 11 months.
10 piece Silvertop set? Two weeks.
Etc...
Paul G
Reged: 05/08/03
Loc: Freedonia
      #5842985 - 05/06/13 06:42 AM
I've side-by-sided the I's and II's, both mono and binoviewing with the Mk V, in several scopes including the following Astro-Physics refractors and Mak-Cass:
92 mm f4.9
92 mm f6.6
105 mm f5.8
130 mm f6
130 mm f6.3
155 mm f7
175 mm f8
254 mm f14.6
I've seen no noticeable difference between the I's and the II's. It's possible that one might notice a slight difference in edge correction in a fast scope if one were observing in an area with excellent seeing, but that's not where I live. In our seeing here, no difference.
The real gems of the I's were the 25 and 34mm. I was disappointed they didn't include those focal lengths when they brought out the II's.
Edited by Paul G (05/06/13 06:44 AM)
ManuelJ
Reged: 12/19/05
Loc: Madrid, Spain
Re: ZAO I vs. ZAO II...? new [Re: Paul G]
      #5843009 - 05/06/13 07:14 AM
ZAO II: less afov, better corrected for fast optics
ZAO I: less eye relief, I like the eyecup of the 16
That's all, folks ;-)
vahe
Reged: 08/27/05
Loc: Houston, Texas
Re: ZAO I vs. ZAO II...? new [Re: ManuelJ]
      #5843040 - 05/06/13 07:40 AM
Two ways to look at this:
1 Newer is always better, be that an eyepiece, a camera, a car or whatever, if you subscribe to this theory then there is your answer !!!!
2 I took that question to ap-ug and got an answer from Roland (#61232 & #61241)
According to Roland;
They are optically the same, mechanically a bit different. The newer ones have smaller field stops because a few picky people complained in the past that the outer part of the field were not sharp in the version 1, so Baader had them made with smaller field stops.
And for coatings;
I have both and they look quite similar, I am not sure there was any great improvement. Both types produce very dark fields and both produce the same sharp planet images.
I have three pairs of version 1, 16, 25 & 34mm, with my F/20 Maks the 34mm offers the finest planetary views of any eyepiece, head and shoulder above all else including ZAO-25 and 24mm Brandons which are my only eyepieces that rival Zeiss on planets.
Vahe
Levine
Reged: 03/24/06
Re: ZAO I vs. ZAO II...? new [Re: vahe]
      #5843045 - 05/06/13 07:48 AM
And for coatings;
Vahe
Great stuff!
Scott99
Reged: 05/10/07
Loc: New England
      #5843264 - 05/06/13 10:58 AM
there is one obvious difference.....the dreaded undercut. ZAO I has it and also the sliding eyeguard
Scott99
Reged: 05/10/07
Loc: New England
      #5843273 - 05/06/13 11:02 AM
Interesting, I don't do much planetary with the longer ones but I've heard this before - people also liking the 25mm orthos best for planetary and just using barlows to get to higher magnfication.
Could it be that larger lenses somehow deliver better contrast? Maybe because the light is spread out over a larger area of glass. People have been saying for a long time that you get better contrast with a high quality Barlow + ortho rather than with an eyepiece with a tiny integrated barlow, could be the same effect.
Sarkikos
Reged: 12/18/07
Loc: Suburban Maryland, USA
Re: ZAO I vs. ZAO II...? new [Re: Scott99]
      #5843276 - 05/06/13 11:05 AM
Take into account that his Mak is an f/20.
Paul G
Reged: 05/08/03
Loc: Freedonia
      #5843288 - 05/06/13 11:12 AM
Obligatory pic:
Sarkikos
Reged: 12/18/07
Re: ZAO I vs. ZAO II...? [Re: Scott99]
      #5843289 - 05/06/13 11:13 AM
Scott,
FWIW, my XO 5.1 showed more perceived contrast and ease of discerning surface detail than my BGO 5. The XO 5.1 has 5 elements in 3 groups, the BGO has 4 elements in 2 groups. Some observers have said that the XO's are at the same level as the ZAO's.
I think that how well an eyepiece with an integrated Barlow (Smyth lens or whatever) performs might vary quite a bit from eyepiece to eyepiece. I usually avoid separate Barlows except to bring my binoviewer to focus in my Newts.
12 registered and 28 anonymous users are browsing this forum.
