Telescope Specific Forums >> Meade Computerized Telescopes
flygal6
journeyman
Reged: 03/03/13
Meade 12V pwr cord tip polarity
      #5841730 - 05/05/13 01:51 PM
I have a meade 12v pwr cord and one of the wires pulled out of the tip. I unscrewed the collar with the intent of making repairs and resoldering the wire to the tip. To make a long story short, then the connection tip broke off totally. Off to radio shack I go. I purchased a 12v 5amp power cord and the correct adapter tip (this was the only type they sold). My first question is this power cord safe to use as a replacement? Second does anyone know if the original cord has a positive or negative tip polarity? I need to know this to make sure I put the tip on correctly and not get it reversed.
Thanks Carol
Edited by flygal6 (05/05/13 03:37 PM)
Whichwayisnorth
Reged: 07/04/11
Loc: Southern California
Re: Meade 12V pwr cord tip polarity new [Re: flygal6]
      #5841746 - 05/05/13 02:03 PM
Center is positive, outside ground.
highertheflyer
Reged: 07/08/05
Loc: Aledo, Texas
Re: Meade 12V pwr cord tip polarity new [Re: Whichwayisnorth]
      #5842533 - 05/05/13 09:44 PM
This statement so true, and never ever, to cross the polarity!
Make certain you find a way to always connect the positive to the positive, red to red, big prong to little prong, etc....!
Perhaps someone here on Cloudy nights can come up with a way that would protect your choices in the wee hours of the night and as a backup, not allow you to cross connect.
flygal6
journeyman
Reged: 03/03/13
      #5842549 - 05/05/13 09:58 PM
Thanks - it worked!
nitegeezer
Reged: 11/27/07
Re: Meade 12V pwr cord tip polarity new [Re: highertheflyer]
      #5842675 - 05/05/13 11:24 PM
I have thought of putting a bridge rectifier on the inside of that connector to make it a don't care. That would protect polarity issues, but I am not sure if the 1.5v drop across the bridge would be too much. I don't want to protect myself from one problem and just create another. It all depends what the lower limit is on the power requirements.
OzAndrewJ
Reged: 11/30/10
Re: Meade 12V pwr cord tip polarity new [Re: nitegeezer]
      #5842682 - 05/05/13 11:38 PM Attachment (6 downloads)
Gday NiteGeezer
You also need to be careful re ground loops doing this as well.
ie items coming off the same battery/supply, then directly connecting to the scope, like guiders etc.
One way to protect agains reverse polarity is to use a reverse biased PChannel Mosfet in the supply line, and wire it up so it will only ever open if the polarity is correct.
A simple test utility is to get a multi colour LED ( or wire 2 LEDs back to back ) in a plug unit.
Put the cable into the unit and one of the LEDs will always glow
and the colour tells you the polarity.
nitegeezer
Reged: 11/27/07
Re: Meade 12V pwr cord tip polarity new [Re: OzAndrewJ]
      #5842735 - 05/06/13 12:20 AM
That looks like a great idea.
Up to now I have not worried about ground loops because I was pretty much a visual user. I am now going to get serious about ap, so I know there are issues. My Canon camera by itself would be no problem as there would be no interesting current paths to worry about, but I have decided to operate my camera remotely from a laptop so I know I am going to have to be careful. I am going to see how well I can do without guiding, I consider this more a learning experience rather than going for the perfect shot that first night. I will spend this summer learning what I can do with what I have, and then during the winter look at guiding to see how that would help. By taking little steps, I hope to avoid the ground loop issue. I have put large systems together in the past, and tracking down a ground loop with a large system is a nightmare, so I like to grow things a little at a time.
3 registered and 8 anonymous users are browsing this forum.
Moderator:  Starman27, Christopher Erickson, Starman81
