Ajohn
Reged: 12/03/07
Olso and Ross - Dall null test new
      #5838457 - 05/03/13 02:03 PM Attachment (41 downloads)
I asked if some one would post an oslo file for this and no one did so here is my take on it. I also asked about sources but have finally found how to get Oslo to take source na and object height in Focal mode.
The file is set up for a Ross test with a 125mm lens. For Dall just remove the 2nd pass though the lens and set the image distance from the mirror to it's radius.
Not much fun trying to get source - lens - mirror distances with sliders but it can be done with Genii. Guess figures based on say 1/2 the lens focal length and run Genii with a high lpm setting. 250 is fine for this mirror. The source na has a slight effect on the result. I chose to slightly over fill the mirror. Oslo does odd things with the na over 1.
There is little difference between the 2 tests but Dall seems to have the lead on minimal residual SA and slightly better ray intercept curves. Neither of these tests are really on axis but the Dall test can be via a beam splitter. Neither are perfect - if I have the set up correct. Maybe some one can test the file some how.
Both are useless at F3 so guess it's ofner next.
John
Whoops Wrong File
Edited by Ajohn (05/03/13 02:08 PM)
Ajohn
Reged: 12/03/07
Re: Olso and Ross - Dall null test new [Re: Ajohn]
      #5838468 - 05/03/13 02:13 PM
I should add that the results usually need the longer distances changing a little to minimise the spot size and maximise the mtf of the set up.
John
Mike I. Jones
Reged: 07/02/06
Loc: Fort Worth TX
      #5838612 - 05/03/13 03:24 PM Attachment (29 downloads)
I tweaked your design in several places. Using "Rim Reference Rays" rather than "Entrance Pupil", and setting the 220mm mirror as a reference surface, makes the light cone go right to the edge of the mirror. I also shifted the test wavelength to 0.585m, which is a pleasing yellow and better for testing than 0.656m, the color of red Nyquil and harder to see.
Is the lens you used fictitious or commercial off-the-shelf (COTS)? If COTS, from who?
Ajohn
Reged: 12/03/07
Re: Olso and Ross - Dall null test new [Re: Mike I. Jones]
      #5838703 - 05/03/13 04:28 PM
It's and off the shelf lens Mike. Wavelength is down to Dall- low dispersion variation -red light - crown. I haven't looked at BK7 in that respect but would suspect it's still true. I have tried a red led with the Dall set up and it's ok but lens problems were very obvious. I should really have changed the wavelength to suite that.
I picked the lens from this list. They do various grades.
http://www.galvoptics.fsnet.co.uk/lenses.htm
I checked that the focal lengths come out right - backwards. At F3 I tried a range from 80 to 200mm. Not good enough but 120mm was about the best spot wise. Oddly Dall suggests lenses with a focal length of around 1/2 the mirrors diameter. The graph as it comes in ATM III can't be read with sufficient accuracy really so it's good that Genii seems to be able to optimise the set up. I'd guess from the results though that this is really a technique for F5 max and not too large a mirror.
John
Ajohn
Reged: 12/03/07
      #5838837 - 05/03/13 06:01 PM
Problems Mike. It wont come up with sensible answers to a Dall set up and I can't see why.
Also very minor problem of not being able to solve for the diameter of the lens used.
No problem setting the wavelength for a red led with the original Ross file.
Trouble is that I know there is no problem with the Dall test on a 220mm F6 mirror.
Also it's a 125mm FL lens. Sorry about that.
John
Edited by Ajohn (05/03/13 06:04 PM)
Mike I. Jones
Reged: 07/02/06
Loc: Fort Worth TX
      #5838895 - 05/03/13 06:46 PM
Post the file, let's see what's what.
Ajohn
Reged: 12/03/07
      #5839554 - 05/04/13 04:51 AM Attachment (25 downloads)
Looks like I should delete the file I posted Mike. The ray intercept plot and LSA plots have a scale that is 4 and 10 times coarser then than yours with the Ross set up. Opic is also giving a better optimisation now. I've had that sort of problem before and no idea why.
Anyway here is the file changed to Dall.
John
Ajohn
Reged: 12/03/07
      #5839588 - 05/04/13 05:47 AM
It looks like it's an optimisation problem - not finding a true minima so there are likely to be problems plugging any mirror / lens combination into it. Just tried changing the mirror and X data to a 300mm F4.4 mirror. One optimisation may have been ok but a subsequent one was hopeless.
John
MKV
Reged: 01/20/11
      #5839652 - 05/04/13 07:28 AM
There is no optimization problem, John. The Dall and Ross null tests are theoretically true null tests in monochrome light.
Ajohn
Reged: 12/03/07
Re: Olso and Ross - Dall null test new [Re: MKV]
      #5839697 - 05/04/13 08:24 AM
There is a little more info coming up on Google now than last time I looked. I found 2 pages on using Oslo to set it up, one for V6... and another for the earlier version. Both are very similar to the file I posted but only optimise for lens to pin hole spacing and adjust the other manually if needed. This suggests that the conjugates don't matter other than getting the image of the mirror in a suitable place. I will try that.
One version of optical shop testing also gives a formulae based purely on the position of the mirror rad centre and the image formed by the lens. It also suggests that there is no difference between Dall and Ross nulls - with a single lens other then less of a possible offset tester problem. It also suggests that it's a pure 3rd order null and similar mirror limitations to the one mentioned in ATM III.
John
Ajohn
Reged: 12/03/07
      #5841162 - 05/05/13 05:44 AM Attachment (11 downloads)
Mike I tried the reference surface idea but using source NA. It doesn't work out the full projected diameter of the mirror is used.
There doesn't seem to be any real difference between Dall and Ross other than field curvature is much lower on the Ross set up. Ross may leave more residual SA at times but that could be down to optimisation not finding a true minima??? It seems Ross used an aspheric plate to correct the higher order SA.
This has been gone through before on
http://www.atm-workshop.com/dall-null.html
http://www.atm-workshop.com/dall-setup.html
Also seems a null is possible with the lens the other way round but I've had no luck.
At 220mmF4 I'm not surprised people use a Ronchi screen. This is the result, I assume as would be seen with a knife edge. Now have to wonder why the file you posted gave such good results. Any mirror changes I make give worse results than I was getting.
John
Ajohn
Reged: 12/03/07
      #5841168 - 05/05/13 06:00 AM Attachment (6 downloads)
This is the same for 220mmF6 and ties in with when I used it with a knife edge.
John
DAVIDG
Reged: 12/02/04
Loc: Hockessin, De
      #5842611 - 05/05/13 10:38 PM Attachment (16 downloads)
Ajohn,
Why aren't you use RossNullXp to do the setup ? It also has the option to save the results in a OSLO file. http://www.ceravolo.com/ross_null.pdf
Attached is an example OSLO file it created.
- Dave
Edited by DAVIDG (05/07/13 08:59 AM)
Ajohn
Reged: 12/03/07
Re: Olso and Ross - Dall null test new [Re: DAVIDG]
      #5844901 - 05/07/13 04:36 AM Attachment (4 downloads)
Mainly because I am mostly interested in the Dall null test Dave.
The file you posted seems to give an answer to something I cam across. A paper called aberrations in the SMALL lens Dall null test. Could be that there was another using a bigger lens the other way round.
I converted your file to the Dall test and viewed as the links suggest it seems to give better results but I then played with the Ross file and got even better results. Subsequently playing with another Dall set up after optimisation improved the results. On that one a 1/25 wave null on an 220mm F3 mirror rather than 1/20 but it needs a huge lens. The main difference seems to be more LSA on a Dall test and a slower F number during testing.
This is the result of your file and same lens used for a Dall set up. Lower one is the Dall.
One thing I am not clear on is how an Oslo wavefromt interferogram relates to shadows as would be seen with a knife edge during testing. Any one know?
John
Edited by Ajohn (05/07/13 04:37 AM)
Mike I. Jones
Reged: 07/02/06
Loc: Fort Worth TX
      #5845115 - 05/07/13 08:45 AM
Just a nit: It's "OSLO", not "OLSO". If you Google "OLSO" trying to find OSLO-EDU you'll just find the "Olson twins"!
DAVIDG
Reged: 12/02/04
Loc: Hockessin, De
      #5845129 - 05/07/13 09:00 AM
Sorry Mike, one of these days I'll learn how to type and spell !
- Dave
Ajohn
Reged: 12/03/07
Re: Olso and Ross - Dall null test [Re: DAVIDG]
      #5845267 - 05/07/13 10:33 AM
Wouldn't worry about it Dave. Comments on knife edge shadows against Oslo interferograms would be much appreciated. Or even against Ronchi.
I just modified my call back routine to tune null tests up with a slider. With a a lens change I can get around 1/30 wave P/V on a 220mm F3 mirror. Not sure it's practical though. Trying to achieve a magnification of 1 needs distance adjustments in nm or less. Oslo EDU will sadly only allow a min rms auto focus in cmd files and not min opd but iterations and graphics updates work ok.
John
Ajohn
Reged: 12/03/07
      #5851400 - 05/10/13 05:59 AM
RossNullXp is a bit naughty on 2 counts. It sets an image size that would be very difficult to achieve in practice and also always seems to optimise for a mirror on the way to being 10% over the requested size. The image size makes the null look a little better so probably isn't important. The increased size of the mirror can add a significant amount to the null that it gives. If a solve is added to the mirror diameter in the oslo file it produces and the beam radius corrected with a factor formed from the solved rad and the required mirror diameter radius results are mixed but only after refocusing for min opd.
I have sorted out the Oslo problems. I did have the lens to source spacing as the variable in the call back routine with the slider on the mirror to lens distance. On the Ross set up Oslo can get it's nickers in a twist around the point where the magnification of the set up is near unity. If these are reversed it doesn't happen but it still pays to reduce the step size as the source and and return image get near to each other.
I found a null lens that can give a 1/10 pv null in a Ross set up on an F3 220mm mirror. Tols on lens to mirror are 0.25mm and lens to source 0.1mm. The tol on the mirror rad is 0.1mm though. Ouch! This was with a 40mm dia 125mm FL lens.
John
DAVIDG
Reged: 12/02/04
Loc: Hockessin, De
      #5851739 - 05/10/13 10:40 AM
John,
If you never used the Ross or any type of null test, what your going to soon find out is that achieving the null is much more difficult then worrying about if the test is good to 1/10 wave or less, especially with an f/3 mirror. Even with the residue errors in the test and the tight tolerances, if you can achieve a clean null the results will be mirror that is smooth and slightly over or under corrector which is good place to be. One can use other tests, I like to star test to determine what the actual correction is and then fine tune the results. I'm working on 16" f/3 parabola now made from a slumped blank that a group of us at Delmarva Star Gazers made 8 of them. I plan on using the Ross, double pass autocollimation with my 11" x 17" flat, and the star test to cross check the final figure.
- Dave
Ajohn
Reged: 12/03/07
      #5851886 - 05/10/13 12:01 PM Attachment (6 downloads)
Dave. With me at the moment it's a case of can I test the mirror with a good chance of success. I intend to try just ordinary Foucault based on some tests shown on youtube but for an F4 mirror from memory. It used a thinish slit like mask which I understand goes back to Ritchie and looks easy to take measurements. I'd guess that the tester used a carefully set slit. I think people are inclined to forget that fast mirrors were made using Foucault and then checked with Hartman (spelling?)
I've looked at Ross and Dall and find that while relatively low nulls can be obtained they don't really leave any scope for error and in my humble opinion aren't that good anyway. More recently I have looked at Ed's Dall conjugate test and find that with a pin hole at 4m from the mirror I can get nulls better than 1/30 wave P/V. That leaves scope for tolerances other than the usual "what is the actual mirror rad". Up the pin hole distance to 24m and the null is to 1/200 P/V. In practice I would wonder if the sky ever offers even 1/30 p/v viewing.
Ed's intended use is via building the scope and using it as a test stand with a led test light 100yds away but it looks like it has a lot more scope than that. Frankly I suspect this test is the only one that really justifies the purchase of a rather expensive 1/20 wave lens intended to be used via the Ross method. Not that I would spend that much frankly.
May as well post the 4m null. My advice would be forget Ross and if you must the same lens could be used anyway.
John
18 registered and 21 anonymous users are browsing this forum.
