stevenwav
Reged: 02/06/12
Loc: New England
Re: ZAO I vs. ZAO II...? new [Re: etsleds]
      #5846927 - 05/07/13 11:59 PM
I will definitely keep an eye out for some clean examples - I'm intrigued. Great to hear how specific eps work with specific scopes and focal lengths.
NickG
Reged: 11/06/06
Re: ZAO I vs. ZAO II...? new [Re: stevenwav]
      #5846990 - 05/08/13 01:06 AM
I can't personally substantiate the following comments from someone (who shall remain nameless) when I was enquiring about purchasing Abbe 1 or 2's:
"The Abbe Orthoscopic I 1.25 inch eyepiece is THE original by Carl Zeiss Jena. The Abbe II is an inferior copy by Baader, and is frankly the biggest insult to astronomy that I have ever encountered, and I have encountered a fair few in my time.
The Abbe II is trying to piggyback the Abbe I for success.
You can tell the difference in the top plate where the copy by Baader has ridges on the top whereas the original is totally smooth.
I use a full set of the originals in my observatory, and there is nothing that comes close, they are that good."
So, this persons opinion is quite clear. Not my opinion mind you! So, is it true, I wonder, were the Abbe II's made by Baader and not Zeiss??
Clear skies.
ManuelJ
Reged: 12/19/05
Loc: Madrid, Spain
Re: ZAO I vs. ZAO II...? new [Re: NickG]
      #5847090 - 05/08/13 03:18 AM
Clear skies.
great_bear
Reged: 07/05/09
Loc: Walthamstow, London, UK
Re: ZAO I vs. ZAO II...? [Re: NickG]
      #5847118 - 05/08/13 03:39 AM
Hmmm... Great detective work.
Alternatively, just read the label.
IIRC Baader paid Zeiss to do a new production run. It sounds like the person you spoke to misunderstood this and incorrectly believed Baader "copied" the original Abbe's.
Sgt
Reged: 12/17/05
Loc: Under the southern horn of the...
      #5847259 - 05/08/13 07:48 AM
The person who told you that doesn't have a clue what he's talking about.
Clear skies.
Sarkikos
Reged: 12/18/07
Loc: Nyctophobia, Maryland, USA
      #5847341 - 05/08/13 08:59 AM
etsleds,
If seeing supports better, out come the ZAO-IIs and 5XO, if worse, switch to Nikon SWs for a more comfortable & wider view.
I have an XO 5 and XO 2.5, but have never owned or even looked through a ZAO-I or ZAO-II. I like the XO's very much for planets and double stars. I have heard that the XO's are at the same level of performance as the ZAO's. In your experience, how do you think they compare on nights of good seeing?
NickG
Reged: 11/06/06
Re: ZAO I vs. ZAO II...? new [Re: Sgt]
      #5847364 - 05/08/13 09:17 AM
Clear skies.
Ok fair enough. Sounds like he was talking rubbish.
NickG
Reged: 11/06/06
Re: ZAO I vs. ZAO II...? new [Re: great_bear]
      #5847373 - 05/08/13 09:22 AM
Thanks for clearing this up. A misunderstanding or deliberately trying to mislead people?? Hmmm
Clear skies
Cheers
stevenwav
Reged: 02/06/12
Loc: New England
      #5847478 - 05/08/13 10:23 AM
I think I saw that post once and I believe it was refuted later in the chain. The views from the II's were fantastic - that should be enough evidence right there. I also believe in the AP-UG, Roland expresses that he has sets of both and that both views were not different. I can find it if I need to for CN regs.
RodgerHouTex
Reged: 06/02/09
Loc: Houston, Texas, USA
      #5847552 - 05/08/13 11:07 AM
Not to add fuel to the fire, but I heard something similar. That the ZAO Is were designed and made by Zeiss. The ZAO IIs lenses were made by Zeiss but the body of the eyepieces were made for Baader by someone else. It kind of makes sense to me because I own the so called Zeiss barlow that came with the ZAO II set and it has Baader marked on the side.
It has also been the Baader model to do that with some of their prism diagonals which contain Zeiss prisms as well as, if I remember correctly the Baader Mark V binoviewers.
Scott99
Reged: 05/10/07
Loc: New England
      #5847708 - 05/08/13 12:47 PM
If the guy should remain nameless then perhaps he should remain silent as well?
stevenwav
Reged: 02/06/12
Loc: New England
Re: ZAO I vs. ZAO II...? new [Re: RodgerHouTex]
      #5847813 - 05/08/13 01:50 PM
FWIW - I went back to find the reference that I mentioned regarding a similar discussion. While not the actual quoted post, within a similar chain, as a rebuttal to whether or not zeiss was instrumental in the ep construction of the ZAO II's, reference was made to the Alpine Astro website which features this comment...
Baader Planetarium has spent years working with Carl Zeiss to design and produce an eyepiece at the limits of modern optical design and fabrication technologies. The result is the Abbe-II.
Every part of the Abbe-II has been fabricated and assembled by Zeiss in their Jena optical facility. In no other way could the demanding specifications and tolerances be achieved, for each and every eyepiece."
It is there now on the site under the ZAO II ep section.
NickG
Reged: 11/06/06
Re: ZAO I vs. ZAO II...? new [Re: Scott99]
      #5848317 - 05/08/13 05:47 PM
That was my call to not mention who, obviously. I deliberately removed some of the really juicy bits to keep the peace. And my reason for quoting it was to clear it up, which it has now. The worry is it was a dealer!
Proof that you have to be wary what you read or have communicated to you on the net.
johnnyha
Reged: 11/12/06
Loc: Sherman Oaks, CA
      #5848451 - 05/08/13 06:47 PM
Yeh I'll defer to Roland on this one...
RodgerHouTex
Reged: 06/02/09
Re: ZAO I vs. ZAO II...? new [Re: johnnyha]
      #5848749 - 05/08/13 09:19 PM
Ah. Maybe it was Roland. He did sell them, yes?
johnnyha
Reged: 11/12/06
      #5848758 - 05/08/13 09:21 PM
Just to be clear, I meant Roland is a fan of the ZAO-II and I defer to his opinion, not the "inferior copy" guy. Roland probably knows more about what he's talking about.
NickG
Reged: 11/06/06
      #5849137 - 05/09/13 12:16 AM
RRRRRRRRRRight!
...and in case someone misconstrues this, no, it wasn't Roland.
There's a lot of "clearing things" up. You have to be very politically correct these days
I have to admit that post of mine was a clanger...I should have known better! The bloke came across as though he was an expert and claimed he knew people that worked at Zeiss, hence.....and the rest is history. And history it is now!
Clear skies.
Edited by NickG (05/09/13 12:27 AM)
Levine
Reged: 03/24/06
Loc: 40° 47' 52" N / 85° 49' 14" ...
Re: ZAO I vs. ZAO II...? new [Re: Levine]
      #5853541 - 05/11/13 10:42 AM
Has anyone compared the performance of the much older "vintage" Zeiss 0.965's to their modern counterparts?
Not talking converted microscope pieces; these would be from earlier than 1950.
I was fortunate to come across a an older O-9, but have not had the opportunity to fully evaluate it yet. In addition to the '9, there may also be a 7 and 5 - possibly others?
Edited by Levine (05/11/13 10:50 AM)
gnowellsct
Reged: 06/24/09
Re: ZAO I vs. ZAO II...? new [Re: vahe]
      #6634121 - 07/14/14 11:45 PM
Two ways to look at this:
1 Newer is always better, be that an eyepiece, a camera, a car or whatever, if you subscribe to this theory then there is your answer !!!!
Vahe
In astronomy the newer eyepieces are better because they're the ones that are clean.
GN
leonard
Reged: 10/19/07
Loc: West Virginia
Re: ZAO I vs. ZAO II...? new [Re: gnowellsct]
      #6634633 - 07/15/14 11:09 AM
Hello ,
>>> In astronomy the newer eyepieces are better because they're the ones that are clean. <<<<
One should never assume things like this as examples exist that belie that statement .
If this were true it would make a buffoon of anyone paying loads of money for a Zeiss ortho 1, as there getting up in age .
12 registered and 21 anonymous users are browsing this forum.
Moderator:  ausastronomer, droid, cbwerner, kkokkolis
