Pages: 1 | 2 | 3 | (show all)
sfugardi
Reged: 09/30/06
Loc: CT
Saturn f21 05/07/13 Excellent Seeing new
      #5845458 - 05/07/13 12:36 PM Attachment (255 downloads)
That's not a misprint. I was treated to the best seeing conditions of the year, I'd call it 4.5/5! I collimated off Arcturus this time, a bit higher in the sky vs Spica in the 0.5-0.55 range with the occasion drop into the 0.4's as measured by Metaguide. I took 7 avi runs over the course of 90min with the first 5 being the best. Here is a 5-frame R only animation. Note that Tethys is rotating around from 7:30. You know the data is excellent when you capture a moon without overexposing. After the seeing dropped off, I managed to dig up my vintage 40yr old Edmond Scientific 5mm ortho eyepiece and attached a baader high contrast filter for a whopping 560x! Now except for the lousy 10% field of view, Saturn looked excellent. Not nearly with quality of the 16" + ethos, but very acceptable to me. 7mm may have been ideal if I owned one. Cassini ring clean throughout, globe banding and color were good, and a hint of darkness was noticed at the north cap. There's nothing like catching 2hrs of sleep before work... I'll post the RGBs later.
Steve
GeorgeInDallas
Reged: 04/15/12
Loc: Dallas, Texas USA
Re: Saturn f21 05/07/13 Excellent Seeing new [Re: sfugardi]
      #5845515 - 05/07/13 12:58 PM
Steve,
Spectacular! Amazing details in the rotating cloud bands! Congratulations! I look forward to seeing the RGBs.
George
R Botero
Reged: 01/02/09
Loc: Kent, England
      #5845634 - 05/07/13 01:36 PM
Excellent shot Steve! Can't wait for the coloured version!
Thanks for sharing.
Roberto
lcd1080
Reged: 06/03/10
Loc: Maryland, USA
Re: Saturn f21 05/07/13 Excellent Seeing new [Re: R Botero]
      #5845923 - 05/07/13 03:24 PM
Super quality Steve, signs of the Encke Gap are clear to see! You mentioned having seen a hint of darkness at the North cap; I'm assuming that means you didn't see the vertices of the hexagon? Did you see the hexagon vertices in the 16 inch SCT when you were able to look through its eyepiece? Just 2 hours of sleep, you must be exhausted!
Pete
Edited by lcd1080 (05/07/13 03:26 PM)
martus
Reged: 01/03/11
Loc: Czech Republic
Re: Saturn f21 05/07/13 Excellent Seeing new [Re: lcd1080]
      #5846010 - 05/07/13 04:12 PM
Steve wonderful !
martus
Mitchell Duke
Reged: 04/22/08
Loc: Georgia
Re: Saturn f21 05/07/13 Excellent Seeing new [Re: martus]
      #5846018 - 05/07/13 04:22 PM
Wow, send that seeing our way
Sunspot
Reged: 03/15/05
Loc: Surprise, AZ
      #5846030 - 05/07/13 04:32 PM
Fabulous in every way!
Mitchell Duke
Reged: 04/22/08
Loc: Georgia
Re: Saturn f21 05/07/13 Excellent Seeing new [Re: Sunspot]
      #5846155 - 05/07/13 05:36 PM
Wow
Kokatha man
Reged: 09/13/09
Loc: "cooker-ta man" downunda...
      #5846329 - 05/07/13 06:42 PM
Bring on the rgb's Steve..!
SeptemberEquinox
Reged: 01/29/12
Re: Saturn f21 05/07/13 Excellent Seeing new [Re: Kokatha man]
      #5846551 - 05/07/13 08:32 PM
Oh. Em. Ji
Kecktastic
Reged: 01/16/10
Loc: Broken Hill NSW Australia
      #5846908 - 05/07/13 11:46 PM
Well...all good things come to those that wait, what ripper data Steve, I can feel your enthusiasm. What great results.
Cheers
Trevor
Olorin
Reged: 08/25/11
Loc: Israel
Re: Saturn f21 05/07/13 Excellent Seeing [Re: Kecktastic]
      #5847171 - 05/08/13 05:42 AM
Fantastic!!
ToxMan
Reged: 01/23/11
Loc: Tucson, Arizona, USA
Re: Saturn f21 05/07/13 Excellent Seeing new [Re: Olorin]
      #5847411 - 05/08/13 09:47 AM
Wow! Congrats on a great catch! Yes, can't wait to see RGBs.
mitovka
Reged: 06/08/10
Loc: Slovakia, CE
Re: Saturn f21 05/07/13 Excellent Seeing new [Re: ToxMan]
      #5847451 - 05/08/13 10:09 AM
WOW! Tons of details!
sfugardi
Reged: 09/30/06
Loc: CT
Re: Saturn f21 05/07/13 Excellent Seeing new [Re: mitovka]
      #5847553 - 05/08/13 11:07 AM Attachment (63 downloads)
Guys, thanks for the kind words! Let me start with the collimation data. With Spica being a bit low on the horizon, I opted for Arcturus this time still near Saturn but higher in the sky to avoid atmospheric disturbance. I used Metaguide with the Flea3 and a R filter at f40 for 20fps. 30fps made the red dot jump around too much and thought since B was being captured at 20, it was ok. I figure an f40 collimation will give plenty of margin for an f20-25 image. A warning here, that if you do not have a dewheater your corrector plate will fog up in minutes after pointing the scope upward. My results were very good generally low 0.5 arcsecs. Knowing my best had been 0.49 under a perfect night with Mars a couple years back, I can quantify the conditions as excellent for sure. After 30min of tweaking, it was as good as I could get it. Attached is the MG screen shot. More to come
Steve
sfugardi
Reged: 09/30/06
Loc: CT
Re: Saturn f22 05/07/13 Excellent Seeing new [Re: sfugardi]
      #5847582 - 05/08/13 11:32 AM Attachment (62 downloads)
I collected 7 RGB avis at 36/30/20 fps, 3'x3'x5' times, with histograms running 45-55% right around peak transit. Actual f-ratio is f22 taking an average of the 5 R's in FireCapture. I tried to dynamically tweak the focus approx +1 count/min to compensate for the chilling of the night air. I was constantly tweaking the dewheater setting to keep the boundary layer to +/- 0.1degC vs the mirror back. Using AS2! and taking the best 5 of 7 avi runs (which were the first ones), I stacked 2800 frames each (picked randomly since I was starting a new folder and 3000 was already taken). Applied Reg6 gaussian sharpen/noise reduction to each, prealigned in Images Plus then derotated in WinJupos. I took derotated R1, R2, R3, R4, R5 and combined as RRRRR, and repeated for G, B. Images slightly sharpened and stretched from 230 in Reg6 then prealigned again in Images Plus. RRRRR, GGGGG, BBBBB files then derotated back in WinJupos as RGBx5 using a grand total of 42,000 frames! A color balance, stretch, and slight sharpening was done in Reg6. Background cleaned up in PS, and the Tethys moon was "borrowed" from my recent Meade 16" IR image and resized since the RGB moon was smeared. There was no LR deconvolutions applied - only Reg6 sharpening. Color and details are very rich. The shadow detail under the front ring on either side is interesting and drops off on either side of the globe edge. In total, this represent 55min of derotated data which took hours to process. Hands down my best image.
Steve
sfugardi
Reged: 09/30/06
Loc: CT
      #5847594 - 05/08/13 11:37 AM Attachment (50 downloads)
Here's the map projection of the 42,000 frame derotated stack from above image with some additional enhancement. Well over 12 rings can be seen here. Please notice that yellow dot in the middle of the dark hex and a light ring around it. I am declaring this to be the hurricane and not an image artifact.
Steve
RedLionNJ
Reged: 12/29/09
Loc: Red Lion, NJ, USA
      #5847744 - 05/08/13 01:10 PM
Very comprehensive write-up and a BEAUTIFUL RGB image. Not exactly the kind of thing you expect to knock out every clear night...
Best,
Grant
HANTO
Reged: 08/24/07
Loc: Unterallgäu, Bavaria, Germany
Re: Saturn f22 05/07/13 Excellent Seeing new [Re: RedLionNJ]
      #5847789 - 05/08/13 01:40 PM
Wow, great! Congrats, Steve!
Regards
Torsten
woolbrig
Reged: 02/01/13
Loc: Bethalto, Illinois
Re: Saturn f22 05/07/13 Excellent Seeing new [Re: HANTO]
      #5847825 - 05/08/13 01:55 PM
That looks great!
2 registered and 12 anonymous users are browsing this forum.
Moderator:  TG, Starman81, bilgebay, WOBentley
