bersonic
Reged: 01/20/13
Advanced VX vs Orion Sirius new
      #5841053 - 05/05/13 01:43 AM
What are your thoughts?
SeattleScott
Reged: 10/14/11
Re: Advanced VX vs Orion Sirius new [Re: bersonic]
      #5841066 - 05/05/13 02:17 AM
Vx has thicker tripod legs and is slightly heavier. Should make it more stable. Sirius has the excellent motor and gears that the Atlas is known for. Should make it more precise, but I can't speak for the Vx in this regard. So it really depends on what size scope you are putting on it. The precision is nice if the Sirius can handle your scope.
JonM
Reged: 07/25/08
Loc: Colorado
      #5841943 - 05/05/13 04:08 PM
The Sirius can use EQMOD. That is a great advantage in my opinion
mark379
Reged: 02/07/09
Loc: New Jersey
Re: Advanced VX vs Orion Sirius new [Re: JonM]
      #5845727 - 05/07/13 02:12 PM
The Sirius is beefier than the Vx.
If you can get a cg5 2" tripod to go with it, you will have a move combination.
RTLR 12
Reged: 12/04/08
      #5845904 - 05/07/13 03:15 PM
Jon, What is the advantage of EQMOD and don't you need to have a computer to run it with the mount?
Stan
okra
newbie
Reged: 01/22/13
Re: Advanced VX vs Orion Sirius new [Re: RTLR 12]
      #5846035 - 05/07/13 04:34 PM
Can only speak for the sirius, having imaged with it for 4 years. First its noisy dont let that scare you. I use two optical trains with a total weight (ED80)17 pounds 4 oz and an AT8RC at 24 lb 10 oz.Both are handled well on a concrete pedestle. the heavier train works only so so on the tripod. A small amount of binding occurs in the EQ axis using the 8RC. but only in certain positions and seldom causes lost image. Mine is left in the weather ( covered -temp extremes of 15-110f) requiring it to be regreased and adjuster yearly DIY
tjugo
Reged: 11/06/07
Re: Advanced VX vs Orion Sirius new [Re: okra]
      #5846092 - 05/07/13 04:59 PM
If money is not an issue get the sirius, it is a better mount and coupled with eqmod it will bring you many features you cannot get with the VX.
IMO the sirius is overpriced but is a better mount,
Jose
BKBrown
Reged: 08/23/09
Loc: Northern Virginia, USA
      #5846191 - 05/07/13 05:45 PM
If your Sirius is way noisy you might have an issue that needs attention. My Sirius is significantly quieter when slewing than any Celestron mount I have been around, and essentially silent when tracking. I hope you don't have any serious problems
Clear Skies,
Brian
mclewis1
Thread Killer
Reged: 02/25/06
Loc: New Brunswick, Canada
Re: Advanced VX vs Orion Sirius new [Re: tjugo]
      #5846270 - 05/07/13 06:17 PM
If money is not an issue get the sirius, it is a better mount and coupled with eqmod it will bring you many features you cannot get with the VX. Jose
Exactly what would you get with EQMOD that you can't get with the NexStar firmware, NexRemote, and NexTour software?
"Better" mount how?
Does it carry more weight?
Is it more accurate PE wise?
Is it more accurate Goto wise?
Is the polar alignment more accurate?
Is it easier to use?
tjugo
Reged: 11/06/07
Re: Advanced VX vs Orion Sirius new [Re: mclewis1]
      #5846550 - 05/07/13 08:32 PM
Some answers to your questions:
I think both will carry the same wight.
I don't know. If the VX is like a CG5 PE-wise then yes, the Sirius has a better PE.
Yes. With EQMOD you can build a N-point sky model
The ASPA routine is already available for the Sirius. The Sirius has an illuminated polar scope.
The celestrons are easier to use.
Some stuff I like about EQMOD:
-- Custom horizons
-- Custom tracking rates
-- AutoPEC
-- Ability to monitor autoguide commands
-- Multiple park positions
-- Work with any GPS
-- Ability to set for how long you want to track past the meridian
-- Joystick compatibility
-- Access to EQMOD developers (they fix bugs very fast)
-- Multi point sky modeling
NexRemote will not offer any you any new feature, it offers the same functionality as the regular HC.
Jose
JonM
Reged: 07/25/08
Loc: Colorado
      #5846726 - 05/07/13 10:00 PM
I have used the Atlas hand controller (same as the Sirius) and EQMOD. Yes, you need a computer at the telescope with EQMOD but, as an imager, I always have one there anyway. EQMOD is faster to get set up, and you can use any star in your star program (I use Stellarium) to get aligned on. You can also save your alignment data for the next session if you don't move the telescope and have a permanent set up. EQMOD also provides for pulse guiding eliminating the need for an ST-4 connection to your guide camera. It also has a polar align routine that is the bees knees. You can also record and save PEC data, adjust the tracking rate, adjust the guiding parameters and a lot of other functions that are just easier to use than trying to figure out the handsets menus. Aligning is much easier for me using EQMOD.
RTLR 12
Reged: 12/04/08
      #5846916 - 05/07/13 11:49 PM
Thanks Jon. It sounds very similar to the Celestron program. Just the familiarity seems to be the difference. I know some prefer one over the other and I really never knew why. Kind of a Ford/Chevy thing. I'll have to give it a try.
Thanks again for the explanation,
Stan
ourobouros2k2
Reged: 11/10/11
Loc: okc area, oklahoma
Re: Advanced VX vs Orion Sirius [Re: RTLR 12]
      #5847265 - 05/08/13 07:54 AM
Having used Nexremote and EQMOD with CdC, I can say EQMOD wins hands down. EQMOD looks complex, but it is very intuitive, highly customizable, and rock solid when used in conjunction with Carted du ciel. You can even record custom wav files for various scope functions and use a wireless gamepad for slewing control. I use a wireless keypad with EQMOD, a combo I could never get working with Nexremote.
So in the above choice, Sirius mount (which I have) would be my preference.
29 registered and 35 anonymous users are browsing this forum.
