B. Cook
Reged: 10/18/10
Loc: No. California
New Refractor Coming What Filters Recommended ??? new
      #5846736 - 05/07/13 10:07 PM
Have a new Sky Watcher Pro 120ED Apo on its way. What filters should I consider getting especially for planet viewing? I have the OIII and a neutral density. Also considering a UHC filter. Feedback appreciated. Thanks Bill
Edited by B. Cook (05/07/13 10:33 PM)
David Knisely
Reged: 04/19/04
Loc: southeastern Nebraska
Re: New Refractor Coming What Filters Recommended ??? new [Re: B. Cook]
      #5846830 - 05/07/13 10:48 PM
For a good narrow-band "UHC-like" filter, I like the DGM Optics NPB filter:
CN REPORTS: DGM Optics NPB Filter
For a good Oxygen III filter, I recommend the Lumicon OIII filter, although the Thousand Oaks OIII and DGM OIII filters aren't bad either. Clear skies to you.
youngamateur42
Reged: 11/21/12
Loc: La Verne, CA
Re: New Refractor Coming What Filters Recommended ??? new [Re: David Knisely]
      #5848627 - 05/08/13 08:22 PM
one of the best filters for planetary use on pretty much every planet is a #80A blue filter, sometimes called the Jupiter filter (from Orion brands). This blue filter is amazing on Jupiter, I've easily picked out the Red Spot on Jupiter in a 70mm refractor, so that should provide some pretty astounding views. But this filter's only for planetary and lunar, they're of no use for deep sky observing. Glad to help!
SeattleScott
Reged: 10/14/11
Re: New Refractor Coming What Filters Recommended ??? new [Re: youngamateur42]
      #5849142 - 05/09/13 12:23 AM
Yellow helps with seeing polar caps on Mars. Not sure how much benefit there is in getting UHC if you already have OIII.
Sarkikos
Reged: 12/18/07
Loc: Nyctophobia, Maryland, USA
      #5849332 - 05/09/13 07:13 AM
IME & IMO, the best general contrast filter for planets is the Baader Moon & Sky Glow. Magenta is very good for Mars.
Reged: 06/16/04
Re: New Refractor Coming What Filters Recommended ??? [Re: SeattleScott]
      #5849389 - 05/09/13 07:51 AM
I use them both. An UHC filter has two advantages over the O-III. First, it passes more bands than just the O-III, I believe they also pass the H-beta filter so it can enhance objects that do not respond to the O-III filter.
Second, O-III filters take a toll on the stars visible something like M-8 shows a a lot of nebulosity but at the cost of stars in the cluster. An UHC filter shows more stars so it can make a nice balance.
32 registered and 27 anonymous users are browsing this forum.
Moderator:  ausastronomer, droid, cbwerner, kkokkolis
