Gregk
Reged: 11/19/06
Loc: San Tan Valley, Az,
What mount should I get
      #5850244 - 05/09/13 03:10 PM
Finally I am getting to a permanent pier situation for AP. Been working off a wheely bar since 2006
My payload modest. Maximum 8 inch SCT OAG and Cameras (450D SS III Mono)
Mounts I am considering Pier Mounted
Atlas
Celestron CGEM
G-11 Losmandy
IoPtron IeQ-45 with updated Clutches (Whatever that is refereing too)
I currently have an Orion Sirius which I am pleased with but not sure it could perform well enough with an 8 inch for AP. I like the quitness of the Sirius Motors and its ability to Goto and track well. I've had an LXD-75, Orion Atlas and a CG-5 also along the way.
The G11 would do well but not sure I can get with the external motors.
Let me Know
Greg
EdmontonAB
Reged: 04/30/08
Loc: Sooke, BC , Canada
Re: What mount should I get new [Re: Gregk]
      #5850599 - 05/09/13 06:20 PM
With autoguiding the Sirius mount should handle the 8" with a finderscope/guider setup. I have an AT8RC that I used on a Sirius mount with a 50mm guidescope and took 5 - 10 min exposures. I would try the combination first. You may not have to upgrade the mount.
Gregk
Reged: 11/19/06
Re: What mount should I get new [Re: EdmontonAB]
      #5850659 - 05/09/13 06:55 PM
I'm wondering if its worth another 1200.00 to get a G11 for better PE. I do well at 950mm with my 6 inch sct and sirius but have to use the oag for great guiding. The pier however would lead me to do a drift alignment once a month or so
That would help to.
Phil Sherman
Reged: 12/07/10
Loc: Cleveland, Ohio
      #5850919 - 05/09/13 08:58 PM
If you need to redo polar alignment every month with a pier then I'd strongly suspect that you don't have a proper foundation (the below ground part) for it.
Phil
neilson
Reged: 08/22/10
      #5852914 - 05/10/13 10:39 PM
I would pick the Atlas. My new G-11 required a bit of tweaking to get that good PE and balance is critical. After using Nexstar I was disappointed with the Gemini 2. And there were a number of problems that still haven't been worked out since it's still new. You might want to check out the Gemini 2 yahoo group. I ended up switching to a barely used CGE which I am very happy with. But If I was using an 8" OTA I would get an Atlas. I always hear very good reports on them. But I have never owned one.
neilson
RogerRZ
Whatta you lookin' at?
Reged: 01/09/06
Loc: West Collette, NB, Canada
Re: What mount should I get new [Re: neilson]
      #5853236 - 05/11/13 04:13 AM
I would say that if your budget permits condidering a G11+Gemini, you'd be better served on the used market by some sort of Tak (EM10-11) or AP (400-600GTO) Maybe a MI250. These should perform well out of the box, no tweaking required.
I can't quite afford to go to this price bracket (3-4K), so I'm sticking to my EQ6 Pro, that apart from carrying capacity, is similar to your Sirus...
Wouter D'hoye
Reged: 06/27/03
Loc: Belgium
Re: What mount should I get new [Re: RogerRZ]
      #5853643 - 05/11/13 11:51 AM
from a cost<:performance point of view the Atlas is hard to beat. The G11 might be a bit better but only at a substantial increase in cost. Though the nice thing is that the G11 is a well proven mount with excellent built quality, and will really last a lifetime. (I can't comment on the goto system though as mine is non goto)
My advice would be to start with the mount you have. It should actually be able to handle a C8. If it doesn't work out well you can still upgrade to the Atlas or the G11.
Kind regards,
Wouter.
gdd
Reged: 11/23/05
Loc: N Seattle suburb, WA
      #5853781 - 05/11/13 12:53 PM
Hi Greg,
I have a G11, like it, and find it easy to use. However, since you already have a Sirius, the Atlas would function in exactly the same way you are familiar. But if you find the Sirius can do the job when pier mounted, why bother changing?
Gale
pfile
Reged: 06/14/09
Re: What mount should I get new [Re: gdd]
      #5854266 - 05/11/13 06:56 PM
it seems like recent G11s with the high precision worm (but not the one-piece worm block or the Ovision one-piece worm) can exhibit really large PE, like 30arcsec pk-pk. not sure what's going on there, but 2-3 recent owners including myself have seen this.
Gregk
Reged: 11/19/06
      #5854291 - 05/11/13 07:30 PM
Hi Guys thanks for all the good input.
I have been thinking allot about the decision. I've had the Sirius mount for about 3 years now and really like it. It only weighs 15 lbs and for monthly remote trips it is super.
Although now I my not have to go remote.
I think for now I'll make an adapter plate for my pier and go with the sirius. If it does well then I'll just keep it since I really like the EQMOD control and mapping system.
The other thing is that the mount will stay on the pier with no shelter around it other than just an insulated sono tube or insulated garbage can. It does get to 110deg here in Arizona so I need to keep it shaded. Well see
19 registered and 66 anonymous users are browsing this forum.
