StrangeDejavu
Reged: 03/20/13
Loc: Florida
Bent compression ring?
      #5850760 - 05/09/13 07:36 PM
I got my Z10 dob today. However, as I was playing with the 5 or 6 screws on the focuser tube, I apparently screwed in one side on the 1.25" adapter too hard. Now the compression ring is slightly bent and won't allow 1.25" eyepieces and my laser collimator inside without scratching it to hell. Newb mistake... I know.
Has anyone had this happen to them and found a simple fix for it? Sunset is quickly approaching and I haven't even checked collimation, let alone set it out to cool down.
CharlesW
Reged: 11/02/12
Loc: Chula Vista & Indio, CA
Re: Bent compression ring? new [Re: StrangeDejavu]
      #5850834 - 05/09/13 08:01 PM
Pull the ring out, wrap it around something that is a little bigger than 1.25", then cinch it down with a hose clamp. That should take out the flat spot.
StrangeDejavu
Reged: 03/20/13
Loc: Florida
Re: Bent compression ring? new [Re: CharlesW]
      #5850847 - 05/09/13 08:05 PM
Thanks Charles, i'll do that. I just took out my 1.25" adapter from my refractor so at least I can check collimation and use it tonight.
Edited by StrangeDejavu (05/09/13 08:37 PM)
Reged: 06/16/04
      #5850913 - 05/09/13 08:52 PM
I've done it. Just remove it and bend it back, it's just brass. I used a small diameter roller to reform it.
StrangeDejavu
Reged: 03/20/13
Loc: Florida
Re: Bent compression ring? new [Re: Jon Isaacs]
      #5851188 - 05/10/13 12:14 AM
Thanks guys, it's good as new.
4 registered and 27 anonymous users are browsing this forum.
Moderator:  cbwerner, tecmage, rflinn68
