Equipment Discussions >> Classic Telescopes
Pages: 1 | 2 | 3 | 4 | 5 | 6 | 7 | 8 | 9 | 10 | 11 | (show all)
sgorton99
Reged: 04/30/08
Loc: Wisconsin, Madison
Re: Unitron 155 level screws new [Re: starman876]
      #5818428 - 04/23/13 07:05 PM
I will look tonight. Have been really busy. Need to pack a couple of things up also.
starman876
Reged: 04/28/08
Loc: VA
Re: Unitron 155 level screws new [Re: sgorton99]
      #5819518 - 04/24/13 11:04 AM
I did find some of the screws. Send me a PM with your address and I will send them to you.
starman876
Reged: 04/28/08
Loc: VA
      #5819552 - 04/24/13 11:21 AM
From the way the spring is made it almost looks like a mill made the ends with a milling bit to make the cut resluting in the rounded part of the slot. If you cannot find the exact part you can purchase a small milling bit and just use your drill press to make the slot. Just an idea not a sermon
of course a cheap xy milling table from Harbor Freight would help.
Edited by starman876 (04/24/13 01:52 PM)
sgorton99
Reged: 04/30/08
      #5819683 - 04/24/13 12:29 PM
Thanks - PM sent.
neotesla
Reged: 11/18/10
Loc: Canada
      #5819897 - 04/24/13 02:15 PM
Another way would be to drill a hole where the rounded part is then use tin snips to cut into the sides of the hole...
starman876
Reged: 04/28/08
Loc: VA
Re: Unitron 155 level screws new [Re: neotesla]
      #5820142 - 04/24/13 04:14 PM
that is true
sgorton99
Reged: 04/30/08
Unitron 155 mount painted new [Re: starman876]
      #5822875 - 04/25/13 07:23 PM Attachment (13 downloads)
Hopefully this is the last painting of the mount base. 2 coats of primer and 3 black. I will touch up the upper portion of the mount, as I did not have that part stripped to preserve as much of the original as I could. When thoroughly dry, will buff to better match with the rest of the mount.
sgorton99
Reged: 04/30/08
Unitron 155 mount together (mostly) new [Re: sgorton99]
      #5828539 - 04/28/13 02:50 PM Attachment (14 downloads)
Couldn't resist getting this back together for a photo-op. I HAVE resisted putting this on the tripod, because I really want the paint to cure for a while longer.
sgorton99
Reged: 04/30/08
Unitron 155 progress new [Re: sgorton99]
      #5829060 - 04/28/13 08:37 PM Attachment (13 downloads)
Some progress on the tripod tray today as well. Before and after pic.
starman876
Reged: 04/28/08
Loc: VA
Re: Unitron 155 progress new [Re: sgorton99]
      #5829328 - 04/28/13 11:15 PM
Looks good Steve
nightpilot
Reged: 02/16/12
Loc: Southern Suburbs, Chicago
Re: Unitron 155 mount together (mostly) new [Re: sgorton99]
      #5830471 - 04/29/13 03:09 PM
This looks very nice Steve. Looking forward to seeing it all together. I know you have commented about proceeding slowly with the restoration and it looks definitely worth it.
Bob
starman876
Reged: 04/28/08
Loc: VA
Re: Unitron 155 mount together (mostly) new [Re: nightpilot]
      #5830579 - 04/29/13 03:51 PM
I have heard of taking your time. This is almost a career
Just teasing Steve. You are doing a great job.
sgorton99
Reged: 04/30/08
Re: Unitron 155 mount together (mostly) new [Re: starman876]
      #5830749 - 04/29/13 05:24 PM
Thanks guys!
Any luck with those screws Johann?
sgorton99
Reged: 04/30/08
Unitron 155 coming along new [Re: sgorton99]
      #5850767 - 05/09/13 07:38 PM Attachment (11 downloads)
I'm going to need a higher ceiling.
starman876
Reged: 04/28/08
Loc: VA
Re: Unitron 155 coming along new [Re: sgorton99]
      #5850787 - 05/09/13 07:44 PM
I have 8 foot ceilings and I just do not leave them set up anymore. Dings in the ceiling, my son running into the counterweight ( it is funny) and tripping over the tripod.
terraclarke
Reged: 05/29/12
Loc: Just South of the Mason-Dixon ...
Re: Unitron 155 coming along new [Re: starman876]
      #5850823 - 05/09/13 07:58 PM
Absolutely beautiful restoration job Steve. Just wonderful. I really admire your patience for detail.
sgorton99
Reged: 04/30/08
Re: Unitron 155 coming along new [Re: terraclarke]
      #5851099 - 05/09/13 10:53 PM
Thanks Terra, and thanks Johann for the screws I need !
terraclarke
Reged: 05/29/12
      #5851152 - 05/09/13 11:32 PM
Yes, thank Johann indeed. I got a much needed tripod bolt just a week or so ago from none other than our dear Johann.
nightpilot
Reged: 02/16/12
      #5851955 - 05/10/13 12:53 PM
Every shot looks better and better. You are not alone on the higher ceilings thing. My scopes have been banished to the lower levels of the home. Pretty tight.
In reality banished is probably a most strong term. It is probably the best place.
starman876
Reged: 04/28/08
Loc: VA
Re: Unitron 155 coming along [Re: nightpilot]
      #5852218 - 05/10/13 03:31 PM
if you are married the proper term is banished
19 registered and 8 anonymous users are browsing this forum.
Moderator:  Rich (RLTYS), Brian Risley
