tim57064
Reged: 08/23/12
Loc: Southeast South Dakota,USA
Binoviewer for Celestron CR-150-HD6" Refractor ? new
      #5862271 - 05/15/13 01:45 PM
Hello to all.I Just had my,new to me,CR-150-HD6"f/8 Refractor out for first light, last night. I was amazed at what I was able to view with it. If the clouds had not moved in at 2am , I would have pulled an all nighter.
I had tried to use my Celestron bino viewer in the scope and found there was not enough in travel with any of my eyepiece pairs. Would this be a problem with any bino viewer?
I was very disappointed that I would not be able to view with both eyes as I have gotten used to it with my SCT's. I am hoping to find a solution to this predicament without having to spend a bundle on it? Any and all suggestions will be appreciated.
I had the bino viewer setup with the 2" diagonal in place with the 1 1/4" redusing bushing in. The skies are not going to be cooperative for the next 5 nights or so ,so I thought I would see what ya all have to say about the subject. I was just thinking about something. Would the bino viewer work if I used my 1 1/4" diagonal on the scope instead of the 2" diagonal? Not enough in travel is the problem as I stated. Please, Help.
hfjacinto
I think he's got it!
Reged: 01/12/09
Loc: Land of clouds and LP
Re: Binoviewer for Celestron CR-150-HD6" Refractor ? new [Re: tim57064]
      #5862277 - 05/15/13 01:47 PM
The binoviewer should work with a 1.25" Diaganol.
A Prism diagonal will work really well. I have the Baader T2 Prism.
SteveSMS
Reged: 03/29/08
Loc: Jersey Shore USA
      #5862614 - 05/15/13 05:06 PM
Hi Tim,
If you have a Barlow try putting the binoviewer into it and then into the diagonal. You will most likely have a magnification of 3X to 4X but it should focus. I think you will be able to find a 1.9X OCA for your BV for under $50. You might want to contact Harry at Siebert Optics, he has many different solutions for binoviewers and he stands behind his products. I'm not positive but I don't think a standard 1.25" diagonal will give you the in-focus that you need.
Clear Skies,
Steve
herrointment
Reged: 03/12/11
Loc: North of Hwy. 64
Re: Binoviewer for Celestron CR-150-HD6" Refractor ? new [Re: SteveSMS]
      #5863053 - 05/15/13 07:58 PM Attachment (9 downloads)
Tim, I have the same scope, purchased used here on CN. The previous owner had shortened the tube. With a Wyorock focuser installed I can use any set up I want and everything reaches focus. It was dumb luck but I'll take it. I can post the numbers if you are interested.
I should add that to use the scope in mono requires one extension tube!!!
Edited by herrointment (05/15/13 08:03 PM)
johnnyha
Reged: 11/12/06
Loc: Sherman Oaks, CA
Re: Binoviewer for Celestron CR-150-HD6" Refractor ? [Re: herrointment]
      #5863134 - 05/15/13 08:21 PM
The 1.25" diagonal will give you around an extra 1" in-focus.
14 registered and 30 anonymous users are browsing this forum.
Moderator:  Scott in NC, FirstSight, panhard, star drop
