SergeC
Reged: 03/23/12
Loc: Gainesville, FL
This was a tough one! - M101 from orange zone new
      #5867382 - 05/17/13 03:35 PM Attachment (45 downloads)
I'm fairly happy with how much i was able to squeeze out of this, given I shot from my suburban back yard, and the object was clear of trees for only about an hour. Nevertheless I had to take advantage of better-than-usual transparency and the rare cool, dry night in Flow-ree-duh this time of year.
Comments and critiques welcome, of course, and thanks for looking.
Imaging scope: ST120
Camera: SS G3 OSC w/ Baader Semi-APO filter
Mount: CG5
Guide: SSAG/ST80/PHD
Subs: 13 X 300s
Capture: Nebulosity 3
Processing: Neb3 (stack), FITS Liberator (stretch), PS CS6
Al Miller
Reged: 08/25/08
Loc: South, Texas
Re: This was a tough one! - M101 from orange zone new [Re: SergeC]
      #5867535 - 05/17/13 04:09 PM
That's pretty impressive actually. The views on other monitors a likely different but, from what I see here you can pull more detail from this image. A bit of unsharp masking to tighten the stars and fine details would help as well. Still it's quite good from such a site.
SergeC
Reged: 03/23/12
Re: This was a tough one! - M101 from orange zone new [Re: Al Miller]
      #5867641 - 05/17/13 04:36 PM
Thanks Al, Ill try that. Still learning my way around PS so not familiar yet with what techniques (and when) to use.
BTW, love your sig, a man after my own heart. Wife says if I want another scope I have to offload one my 14 guitars. May just have to get a new wife (JK!)
Edited by SergeC (05/17/13 04:45 PM)
vorkus
Reged: 08/18/10
Loc: Pgh, PA USA
      #5867707 - 05/17/13 05:11 PM
Good job. I'm also in an orange zone and have fun trying to get galaxies like M101.
JJK
Reged: 04/28/08
      #5868023 - 05/17/13 07:48 PM Attachment (18 downloads)
Have you tried a LP filter? I recently got a Hutech LP2 for my SBIG STL-11000 one-shot color CCD camera, and it's made a difference in my Red Zone backyard.
The attached rough draft of M101 is a very tight crop of 5x600s light subs w/no flat field correction (- 20*C) I took last weekend (Ceravolo 300 @ f/4.9). The H-II regions are apparent. The color balance and color noise will get better when I use flats and take a lot more images. The stars will look tighter when I tweak the collimation and use the stacking routine correctly (for some reason, the program didn't work as I expected in this round of imaging).
CounterWeight
Reged: 10/05/08
Loc: Palo alto, CA.
Re: This was a tough one! - M101 from orange zone new [Re: JJK]
      #5868552 - 05/18/13 12:28 AM Attachment (16 downloads)
Serge,
Taking a quick look at the data as posted it seems pretty clipped in your initial stretching, the background shouldn't be that black? On the R/H side of the histogram you see it's sharp and vertical. If you are less agressive it will allow for more low contrast detail. When i push the levels there is a very sharp cutoff which to me means is too agressive near the black point?
SergeC
Reged: 03/23/12
Re: This was a tough one! - M101 from orange zone new [Re: CounterWeight]
      #5868999 - 05/18/13 09:03 AM Attachment (11 downloads)
Hi Jim - I really appreciate your making the time and effort to help out. Here's a screen cap of my initial stretch of the linear FITS file I get from stacking in Neb3, after cropping stacking artifacts. I'm clipping the white just to show up the noise and LP gradient I'm dealing with; I'd normally leave the white point at maximum before bringing the stretched tif into PS.
You can see there's a distinct and well-separated black peak to the left of the main histogram peak. For the image in the OP I had set the black level between those 2 peaks, assuming the leftmost peak was due to some stacking artifact that I hadn't quite cropped. I'll try re-processing without clipping out that leftmost peak and see what happens.
I'd appreciate any other tips and suggestions, and thanks again for your help.
JJK
Reged: 04/28/08
      #5869103 - 05/18/13 10:31 AM
I'd be curious to see the result of reprocessing the image. Light pollution and LP gradients complicate getting the color balance correct. I still think you'd benefit from a filter.
I made a typo in my op. The filter I purchased was a Hutech LPS2.
DNTash
Reged: 09/02/07
Loc: GMT+2
      #5869126 - 05/18/13 10:49 AM
Very nice through the ST120.
SergeC
Reged: 03/23/12
      #5869212 - 05/18/13 12:11 PM
Thanks for the info. I'll post my next re-process attempt later. I have a broadband LP filter I use for visual, but find it gives CCD images a blue-green cast that's hard to correct. I'll check out the Hutech. Another one I was looking at was the Orion SkyGlow Astrophotography filter.
CounterWeight
Reged: 10/05/08
Loc: Palo alto, CA.
      #5869257 - 05/18/13 12:35 PM
Serge, thanks for posting that FITS image. Very sharp cutoff there with that void between it and the remainder of that signal to the R/H side. So maybe that is more just an artifact of how the CCD is biased or signal balanced. M101 is really tough IMO because so much of it is very low luminance and it's signal so near the noise level. You can see what I'm referring to in the image John (JJK) posted.
I also image in heavy LP and it makes RGB a headache at best. I also try to use the IDAS-LP2 for it, but have problens with my current setup making that happen. There is also HLVG and Gradient Exterminator for helping in post processing. When I was doing OSC I always split the color channels into their own color panes and went after things sepirately, but you have to be very careful with desired signal and the balance when you reassemble. There are also things to try jsut with balance background signal or normalize it before appling initial stretching, but also IMO tricky. With my current mono setup I just take a lot of subs at smaller exposure length, but then I am in a white zone for LP.
Just sort of rambling here, hope any of it is helpful.
JJK
Reged: 04/28/08
      #5869267 - 05/18/13 12:47 PM
I'd be curious to see the result of reprocessing the image. Light pollution and LP gradients complicate getting the color balance correct. I still think you'd benefit from a filter. It's always better to spend time processing the best data you can obtain.
I know what you mean. I currently use Nebulosity to correct for the background color offset (blue cast before correction). I'm going to give PixInsight a try soon (it might deal with color offsets better).
FWIW, the Hutech LPS2 filter worked well for me, and I'm 22 miles NW of the White House (the improvement will be even better when I use flat field correction). I'm going to eventually get a FLI 16803 monochrome camera and narrow band filters, but those won't be much help with imaging galaxies and stars.
SergeC
Reged: 03/23/12
      #5869653 - 05/18/13 04:11 PM Attachment (8 downloads)
OK, here's a re-process attempt. I think I squeezed out some more detail, especially in the core, but somehow I threw off the color balance I had in the OP. Jury's still out (for me) as to which I like better. Would love to hear from you folks.
Thanks again for all who've commented and made suggestions. You're all a big help. Whoever said this was easy (if anybody ever did) should be beaten over the head with a fork and wedge.
Madratter
Reged: 01/14/13
      #5869721 - 05/18/13 04:52 PM Attachment (5 downloads)
Hi Serge:
There is definitely more detail than you are bringing out. Also the color balance is now too purple, although I prefer it to the original.
Here is a modified version. I can't get the color balance right with just the version posted. I'll take this down if you want me to.
If you post the unstretched version on dropbox or something, I wouldn't mind taking a quick try at it.
Edited by Madratter (05/18/13 05:15 PM)
SergeC
Reged: 03/23/12
Re: This was a tough one! - M101 from orange zone new [Re: Madratter]
      #5869790 - 05/18/13 05:43 PM
...If you post the unstretched version on dropbox or something, I wouldn't mind taking a quick try at it.
Don't mind if you do. The following are Dropbox links:
My workflow is basically to stretch the RGB channels separately in FITS Liberator and then bring them together in PS. I'll do a number iterations of curves and levels, blurring, saturation (Adam Block method), etc. to bring up and denoise the color info. I use the synthetic Luminance for detail, so I apply deconvolution, curves and levels tweaking, gradient correction, etc. to that and then bring it on top of the united RGB.
If any of you do play around with my raw files, all I ask is that you jot down your workflow so I can try to reproduce it.
Thanks, and clear skies.
Madratter
Reged: 01/14/13
      #5869960 - 05/18/13 07:02 PM Attachment (6 downloads)
I'm having no success with the color data in this at all. The differences between channel are just very thin. I did dig more out of the luminosity channel, at the risk of being somewhat lumpy.
Processing was in PixInsight:
1) I brought it into PixInsight
2) Extracted the Luminosity Channel
3) Dynamic Background Extraction
4) Histogram Stretch
5) Wavelets
6) TGV Denoise
7) Histogram Stretch
JJK
Reged: 04/28/08
Re: This was a tough one! - M101 from orange zone [Re: SergeC]
      #5870453 - 05/18/13 10:51 PM
Serge, what does the data look like if you don't split the RGB?
In my very rough draft of M101, I used Nebulosity 2.x to dark subtract, DeBayer to color, align & stack (I goofed up this part), cropped, remove color background offset, save to TIFF. I then used PhotoShop (curves & level, mild add-on Topaz Denoise filter, Neil Carboni's hard gradient removal, and weak Smart Sharpen). I didn't split the color channels.
15 registered and 13 anonymous users are browsing this forum.
Moderator:  nitegeezer, WOBentley, dr.who, rflinn68
