mrelliot
Reged: 05/17/13
Go-to new
      #5871719 - 05/19/13 03:20 PM
Are there any decent go-to mounts under 900? Or is it better to spend the extra for a heavier duty mount?
Mrelliot
Reged: 07/06/07
Re: Go-to new [Re: mrelliot]
      #5871752 - 05/19/13 03:33 PM
What do you mean by "decent"?
For me (in the U.S.), that would be the Celestron VX...
mrelliot
Reged: 05/17/13
Re: Go-to new [Re: rmollise]
      #5871817 - 05/19/13 03:56 PM
I guess by decent I mean, good quality.
Hilmi
Reged: 03/07/10
Loc: Muscat, Sultanate of Oman
      #5871874 - 05/19/13 04:18 PM
You need to give the folks here some more information about what you want to do with it for them to help you. The Vixen Polarie is good enough to blow you away at less than $400 but its no good for visual use as it is made for DSLRs with lenses. The more info gou give on expected use the more these fine folks here can help you.
mrelliot
Reged: 05/17/13
Re: Go-to new [Re: Hilmi]
      #5871926 - 05/19/13 04:41 PM
Sorry, I never thought of that, I was looking for something simple for visual use.
Ed Wiley
Reged: 05/18/05
Loc: Kansas, USA
      #5871959 - 05/19/13 04:54 PM
What are your goals? If visual, then you are in one place. If serious astrophotography you are in another place. Best to examine your goals and to a bit of research on various mounts, paying particular attention to load capacity, periodic error and pointing accuracy. Example: If you are interested in astrophotography then you should not overload the mount: my Losmandy G11 has an instrument capacity of around 60 lbs, but for AP I try not to exceed 35 lbs, but if I was visual only I could probably go all the way to 60 lbs.
Quality mount, medium capacity? Losmandy G11 and AP Mach1.
Under $900? I might look for a used Losmandy G8.
Ed
Mkofski
Reged: 07/19/11
Loc: Greenfield, Indiana, USA
      #5872004 - 05/19/13 05:16 PM
Celestron AVX & CG5, the iOptron ZEQ25 and Orion's SkyView Pro are all under $900.00 new.
De Lorme
Reged: 12/30/08
Re: Go-to new [Re: Mkofski]
      #5872032 - 05/19/13 05:32 PM
Hi Mrelliot, Could you push it to a $1,000?
If so take a look at Meades new LX80. Holds 40lbs
Or Ioptron mini tower. I think Meades LX80 is the better
deal. De Lorme
Stew57
Reged: 05/03/09
Loc: Silsbee Texas
Re: Go-to new [Re: De Lorme]
      #5872080 - 05/19/13 06:04 PM
The Celestron AVX has updated electronics and is a good mount in your price range. The LX80 not so much so as it has a reputation of being problematic. Used CGEMs and Atlas' are found in your price range sometimes.
Reged: 07/06/07
Re: Go-to new [Re: Ed Wiley]
      #5872141 - 05/19/13 06:25 PM
Ed
And you might find one for that with Gemini, but I ain't too sure about that...
Reged: 07/06/07
      #5872147 - 05/19/13 06:25 PM
deal. De Lorme
It's not. Not by a long shot. Alas.
mrelliot
Reged: 05/17/13
      #5872916 - 05/20/13 12:50 AM
Thanks for all the input.
mrelliot
Reged: 05/17/13
      #5873015 - 05/20/13 02:23 AM
Any thoughts about the iOptron smart EQ pro?
Reged: 06/16/04
      #5873075 - 05/20/13 04:18 AM
Mrelliot
I think there are "decent" GOTO mounts under $900 but it does depend on intended scope and the intended usage. What are planning to mount on it and what are your hopes for it, visual, A-P?
coinboy1
Reged: 05/03/11
Loc: Tulsa, OK
Re: Go-to [Re: rmollise]
      #5873334 - 05/20/13 09:38 AM
I second that. LX80 has not had a good reputation. I would never buy one. I would really look into the Ioptron ZEQ25. This new mount has had good reviews and a lot of potential with very low periodic error.
29 registered and 36 anonymous users are browsing this forum.
