ccdmaker
Reged: 11/15/11
Loc: Illinois, USA
Building Camera - Advice on CCD Imager
      #5873397 - 05/20/13 10:19 AM
After a gap of 12 years I have decided to build another cooled CCD Camera. I have plans to eventually share the schematics, firmware and ASCOM camera driver with the Amateur DIY community. My thoughts are to modularize the design such that it can support different CCD Imager chips from various manufacturers, hoping that the design can be adapted as the things change over time. In the past I gained quite a bit of experience with the Kodak 40X series (9 microns square, 768 X 512). That was in 1993-2001, and I am sure there must be many more choices now with better specs.
To start with I want to find a chip with smaller pixel size because my refractor is only 632 mm focal length, and I would like to sample at about 1"-2"/pixel, which means the pixel size needs to fall between 3 - 6 microns square.
The Kodak 8300 would probably work (5.4 microns), but are there any others (monochrome) in that size category with higher QE?
... And maybe cheaper too?
Edited by ccdmaker (05/20/13 10:23 AM)
blueman
Photon Catcher
Reged: 07/20/07
Loc: California
Re: Building Camera - Advice on CCD Imager new [Re: ccdmaker]
      #5873686 - 05/20/13 12:53 PM
The 8300 has a pretty respectable QE really.
Blueman
Raginar
Reged: 10/19/10
Loc: Rapid CIty, SD
Re: Building Camera - Advice on CCD Imager new [Re: blueman]
      #5874872 - 05/20/13 10:43 PM
An ST-10 will get you what you're looking for.
blueman
Photon Catcher
Reged: 07/20/07
Loc: California
Re: Building Camera - Advice on CCD Imager new [Re: Raginar]
      #5874892 - 05/20/13 10:50 PM
If you like Blooming chips, the ST10 is the best for QE. Me, I do not like dealing with the blooms.
Blueman
Iver
Reged: 10/12/07
Loc: Monterey County,Ca.
      #5874950 - 05/20/13 11:25 PM
Have a look at the Sony CCD's that SX is using. Very High QE, small pixels, no shutter needed and anti-blooming! Your project sounds interesting, please keep us updated.
http://www.sxccd.com/products
ccdmaker
Reged: 11/15/11
Loc: Illinois, USA
Re: Building Camera - Advice on CCD Imager new [Re: Iver]
      #5876851 - 05/21/13 08:09 PM
Thanks all for the responses.
The KAF3200 (used in the ST10 mentioned by Raginar & blueMan) has 6.8 X 6.8 micron pixels - that would make my sampling about 2.3"/pixel, maybe just a little coarse.
The Sony ICX694ALG (used in the SX mentioned by Iver) is 4.54 X 4.54 and yes, it has impressive QE - this would let me sample at about 1.4" / pixel.
Now to go through the painful process of acquiring one or two of these - always difficult when you are dealing with a manufacturer primarily devoted to consumer products
hytham
Reged: 12/25/12
Loc: Canadian in the US
      #5877370 - 05/22/13 03:05 AM
The KAF 3200 would come close to meeting your needs: 6.8 micron, very high QE, low noise camera (dark current and total system noise), but it is a NABG chip.
My issues with the Sony chips and these issues may not even affect you:
1) Small FOV - admittedly not too long ago I wasn't overly concerned with having such a small chip, but considering I want to get into widefield photography it is counter intuitive especially with my scope.
2) Small pixels - when compared to the larger pixel CCD offerings, the high QE of the Sony is negated.
If Sony come out with a significantly larger chip and retain that kind of QE, now that would be something to look forward to.
The other thought I have is ... how freaking expensive is it to get a chip straight from a manufacturer that generally sells in bulk quantities to vendors?
ccdmaker
Reged: 11/15/11
Loc: Illinois, USA
Re: Building Camera - Advice on CCD Imager new [Re: hytham]
      #5878127 - 05/22/13 02:03 PM
The great advantage of working with the Kodak chips is that most of them have almost identical clocking requirements, several are even pin compatible with each other; and for me this may be the best route having had experience with KAF 4000, 401. Most of the time the seeing at my location is rarely better than 2", so maybe 6.8 microns may be fine.
The last time I checked (2011) Kodak (now TrueSense Imaging) will still sell small quantities). I think the 8300's are about $400.
I am yet to check on the availability of the Sony Imagers.
avarakin
Reged: 07/13/09
Loc: Parsippany NJ, USA
      #5879162 - 05/22/13 10:02 PM
Can one order evaluation board?
Gray
Reged: 01/31/11
Loc: Hixson, TN
Re: Building Camera - Advice on CCD Imager new [Re: avarakin]
      #5883716 - 05/25/13 10:29 AM
I did a price check last fall on an ICX 285AL, $240 each with a three chip order. Shipped from China of course.
Raginar
Reged: 10/19/10
Loc: Rapid CIty, SD
Re: Building Camera - Advice on CCD Imager new [Re: Gray]
      #5883752 - 05/25/13 10:45 AM
Blooms are annoying. But, the detail is pretty neat . And, you can do some variable star work since it's pretty linear.
I think an 8300 would still be the best bet.
ccdmaker
Reged: 11/15/11
Loc: Illinois, USA
      #5885304 - 05/26/13 10:05 AM Attachment (7 downloads)
Gray,
Do you recall where you got the pricing info from? I would like to get current pricing on the ICX694ALG for the record,
though I am leaning towards the KAF8300.
Part of the reason for that is the relative ease designing a PCB to support a cooled imager - the KAF's are dual in-line, while the ICX694 has multiple rows of pins. This usually results in a trace routing nightmare http://www.cloudynights.com/ubbthreads/images/icons/frown.gif
orlyandico
Reged: 08/10/09
Loc: Singapore
      #5885492 - 05/26/13 12:15 PM
last i checked the KAF3200 was over $2000
i am definitely also interested in this project...
Gray
Reged: 01/31/11
Loc: Hixson, TN
      #5885530 - 05/26/13 12:39 PM
ccdmaker,
I checked to see if I still had one of the emails I normally received to no avail. I was sitting in an electronics lab searching the internet for prices at the time. If they send me another reminder email, I will post back with their contact info. Looking at that design, I'm thinking you'd have to use two pcb's to cover the inner pin outs? Anywho, if you run into a difficulty with pcbs, I can take a design to school and make whatever you'd need. Actually, I want to try and build my own camera one day too.
orlyandico
Reged: 08/10/09
Loc: Singapore
      #5885693 - 05/26/13 02:27 PM
I also think the DIL style Kodak chips are easier to deal with. There were some Kodak type amateur cameras out there - the Audine and Genesis 16.
http://www.genesis16.net/
Gray
Reged: 01/31/11
Loc: Hixson, TN
      #5888622 - 05/28/13 10:07 AM
Well, they sent me another email. Here's the contact info.
Top Source Technology Co.,Ltd
Te:86-755-83586635 Fax: 86-755-83972235
E-mail: LizaLin@188.com Msn: topsource003@hotmail.com
skype: topsource003 Website:http://www.tsourceic.com/
ccdmaker
Reged: 11/15/11
Loc: Illinois, USA
      #5888997 - 05/28/13 01:40 PM
Thanks, Gray
I will check on the availability from Top Source, though I am leaning towards the KAF 8300. IMHO, for a few microns' reduction in pixel size, the increase in complexity may not be worthwhile, at least for the first pass at the design.
The complexity arises in the layout within the cramped confines of the camera head.
There is another reason - To improve cooling efficiency, I was thinking of soldering short, thin wires directly to the CCD from surrounding PCB. This technique is preferable to plugging the CCD into a socket on the PCB. Doing that would be a pain on chips with multiple rows of pins. Most of the thermal loading comes from conduction.
I will still go ahead and find the availability/pricing on the Sony Imager just in case.
6 registered and 11 anonymous users are browsing this forum.
Moderator:  Oldfield, Scott in NC, bilgebay, WOBentley
