Galicapernistein
Reged: 09/24/07
Loc: Detroit Michigan
SkySafari Plus as Atlas
      #5873894 - 05/20/13 02:45 PM
Is SkySafari Plus detailed enough to use instead of traditional atlases? For instance, if I'm looking for a very faint galaxy cluster, will SkySafari zoom in to show the field as it would appear through, say, a 50x eyepiece? Does it show the orientation of the galaxies? Or doesn't it show galaxy clusters?
btschumy
Vendor - Simulation Curriculum
Reged: 04/13/04
Loc: Longmont, CO, USA
Re: SkySafari Plus as Atlas new [Re: Galicapernistein]
      #5873930 - 05/20/13 03:03 PM
I think you'll find that SkySafari Plus is quite a bit more detailed than any printed atlas. Galaxies are draw in the correct orientation and size. Galaxy clusters are drawn only if each individual galaxy in the cluster is in the database.
Here is an image from Plus showing Markarian's Chain. Stars down to about 12th mag are shown (this is about as deep as Plus goes).
http://www.southernstars.com/bill/MarkarianChain.png
Bill
Galicapernistein
Reged: 09/24/07
Re: SkySafari Plus as Atlas new [Re: btschumy]
      #5873961 - 05/20/13 03:20 PM
Thanks Bill. So if I want to find a galaxy cluster field, I would do a search for the brightest member (which would probably already be in the database)? Or is there a search function for galaxy clusters?
btschumy
Reged: 04/13/04
      #5873990 - 05/20/13 03:30 PM
Well, we do have some of the well known ones. For example you can search for "Markarian's Chain" and find it. However, we haven't made an effort to ensure all named galaxy clusters will be found that way. Searching for a bright member of the chain will always get you there though.
We should have all galaxies down to about 15th mag in the Plus database.
Jeff Morgan
Reged: 09/28/03
Loc: Prescott, AZ
      #5874000 - 05/20/13 03:34 PM
Over the last year or so I have been transitioning from Uranometria to SkySafari. I think my paper atlas has taken its last trip out of the office.
SkySafari is more than detailed enough - and it not only replaces your atlas, but reference books too. And unlike paper atlases, it is not affected by wind.
The only display feature where I find SkySafari wanting is dark nebula. They are rendered as square outlines in the approximate size of the object, and the display color is the same the RA and DEC grid. It can be very cluttered and confusing times. Ideally they would be actual shape (like bright nebula) although rendering square outline in a different display color (dark grey?) would be very helpful too.
Galicapernistein
Reged: 09/24/07
      #5874017 - 05/20/13 03:38 PM
15th mag is more than enough for my current scope, but in case I ever win the lottery the Pro sounds even better. Thanks for the info!
Galicapernistein
Reged: 09/24/07
Re: SkySafari Plus as Atlas new [Re: Jeff Morgan]
      #5874058 - 05/20/13 03:55 PM
I just bought a new Uranometria too, but I'll be more than happy to leave it home as a reference book.
Edited by Galicapernistein (05/20/13 03:58 PM)
helpwanted
Reged: 07/04/07
Loc: Phoenix, AZ
      #5874818 - 05/20/13 10:05 PM
I also find very little need for a printed atlas, after using SS+
Reged: 06/16/04
Re: SkySafari Plus as Atlas new [Re: helpwanted]
      #5875205 - 05/21/13 06:31 AM
I have been using handheld devices for the past 10 or more years. Until Sky Safari came along, I was using Planetarium for the Palm and it was quite capable with large databases but slow...
But Sky Safari really has taken it to the next level... As Jeff said, it's not just the chart but it's the wealth of information and not just the typical distances, magnitudes, rise and set times, RA and DEC alt-az etc. For many objects there are detailed descriptions including observing tips and observing information...
Reged: 07/06/07
      #5875361 - 05/21/13 09:19 AM
It leaves traditional atlases, print atlases, in the dust. Even Millennium...
Tom Polakis
Reged: 12/20/04
Loc: Tempe, Arizona
      #5875474 - 05/21/13 10:35 AM
Pretty much what everybody else said is true. There's no going back after you start using SkySafari.
My single complaint is that I would like a wider range of star dot sizes when you are zoomed into a small field. If the range of magnitudes in a field is, say, 12 to 15, all of those symbols are plotted with roughly the same, tiny size. It would be very helpful if the 12th magnitude stars appeared as larger symbols in small fields. I understand what that would do with the occasional 6th magnitude interloper star symbol, but it would be a worthwhile trade-off.
tezster
Reged: 07/14/09
Loc: Missisauga, Canada
Re: SkySafari Plus as Atlas new [Re: Tom Polakis]
      #5879732 - 05/23/13 08:28 AM
The most important aspect of using SkySafari while observing at a dark site (and it's not even really directly related to the app itself) is controlling the amount of light output by whichever portable device it's being used on. This is typically accomplished by using night mode, in addition to some type of light-dimming app and/or placing a red/rubylith film over the display.
Having said that, the benefits definitely outweigh any disadvantages compared to a traditional printed atlas.
Reged: 06/16/04
      #5881710 - 05/24/13 07:57 AM
If you really want to look at galaxies and have the scope to go deep, the Pro is probably better... 740,000 Galaxies down to magnitude 18.
For most observers, probably the Plus is more than adequate.
Galicapernistein
Reged: 09/24/07
Re: SkySafari Plus as Atlas new [Re: Jon Isaacs]
      #5881921 - 05/24/13 10:16 AM
Jon, with all the extra galaxies included in the Pro version, do the galaxy fields look cluttered? In theory I like the idea of being able to know that there are galaxies that I can't see, but in the field, do the "invisible" galaxies make the visible galaxies harder to pick out? Or can you edit out the dimmer galaxies?
JonNPR
Reged: 03/04/13
Loc: Oregon
      #5882313 - 05/24/13 01:22 PM
You can customize SSP in almost any way you want or need for a particular use for instance: magnitude limits specifically for DSO's; whether they will display when you are zoomed out to wide views. So you can choose whether the large number of fainter galaxies will be displayed, and when they will be.
It's an excellent program with continuing significant support.
Jon (although not THAT Jon!)
Galicapernistein
Reged: 09/24/07
Re: SkySafari Plus as Atlas new [Re: JonNPR]
      #5882372 - 05/24/13 01:52 PM
Thanks Jon. It sounds like the Pro is what I'll be getting.
btschumy
Reged: 04/13/04
      #5882735 - 05/24/13 05:19 PM
Be aware that Pro on Android takes about 1.3 GB of free space on the internal SD card. It is a large program.
weinerat
Reged: 12/30/09
Loc: Dalian China
Re: SkySafari Plus as Atlas new [Re: tezster]
      #5907248 - 06/07/13 12:59 AM
Terence, light dimming app? Can you name a few. I have rubylith for my iPad but will lose it this summer while the family is traveling so I need to use my phone. Would like an app to reduce the brightness.
tezster
Reged: 07/14/09
Re: SkySafari Plus as Atlas new [Re: weinerat]
      #5907435 - 06/07/13 07:58 AM
Hi Aaron - I use an app called screendim with an Android tablet, which probably isn't that useful for you if you ahve an iPhone. I'm sure there are a number of dimming apps for the iOS.
Jeff Morgan
Reged: 09/28/03
Loc: Prescott, AZ
      #5908794 - 06/07/13 09:20 PM
I have looked at a few and deleted them as inadequate.
The simplest solution is to buy another sheet of whichever red film you prefer. It's not like buying another Ethos.
3 registered and 4 anonymous users are browsing this forum.
Moderator:  richard7, kkokkolis
