ASTROTRUCK
Reged: 01/02/10
OVER PROCESSED ??
      #5874639 - 05/20/13 08:40 PM Attachment (23 downloads)
is this over processed ?? not sure how to post enabling enlargement. - resized thanks
image is cak merged with imerge as bit map, then opened in photoshop & saved as jpeg.
the stacking process in reg6 results are the same before & after & avistax does not work with my images - not been able to discover why.
resized to 800x800 - at some point in post processing the granulation became less obvious.
thanks
steveward53
Reged: 05/14/12
Loc: Newmarket,UK
Re: OVER PROCESSED ?? new [Re: ASTROTRUCK]
      #5875149 - 05/21/13 04:57 AM
Either resize to 800x800 in Paint or PS.
Matt Wastell
Reged: 07/05/09
Loc: Paddington, Brisbane, Australi...
Re: OVER PROCESSED ?? new [Re: steveward53]
      #5875178 - 05/21/13 05:48 AM
The small image looks great - interested to see it larger.
Aboy
Reged: 07/17/12
Loc: Thousand Oaks, CA
      #5875263 - 05/21/13 07:33 AM
Did you try to add color? Or to do it a little less dark?
The image looks great by the way
raylal
Reged: 04/19/10
Loc: Cornwall, Ont., Canada
Re: OVER PROCESSED ?? new [Re: Aboy]
      #5875628 - 05/21/13 11:37 AM
Looks very good as is. Great job.
Ray
BYoesle
Reged: 06/12/04
Loc: Goldendale, Washington USA
Re: OVER PROCESSED ?? new [Re: raylal]
      #5875653 - 05/21/13 11:46 AM
Looks good to me!
ASTROTRUCK
Reged: 01/02/10
Re: OVER PROCESSED ?? new [Re: BYoesle]
      #5875940 - 05/21/13 01:34 PM
i dont add color as it tends to wash out detail but it did get darker as i copied & processed to get it to site - usually a bit brighter but thanks for responses.
it's a merge using imerge numbers from earlier postings.
256;25;0; feathered - works nicely
its the linked wavelets that can overkill.
JeanB
Reged: 07/11/11
Loc: Montreal, Canada
      #5875998 - 05/21/13 02:01 PM
Terrific as is indeed. I would not add or remove anything to it.
Jean
BYoesle
Reged: 06/12/04
      #5876027 - 05/21/13 02:16 PM Attachment (2 downloads)
...it did get darker as i copied & processed to get it to site...
Of course processing is a matter of personal taste, but you can post-process to lighten things up.
I generally prefer less contrast as it preserves details better - I use the Histogram adjustment in PSP to achieve the results I desire. Don't know what you use, but it could help.
Here's my adjustment for your image, lightening up the penumbras:
BYoesle
Reged: 06/12/04
      #5876030 - 05/21/13 02:17 PM Attachment (2 downloads)
Here's the overall result:
Aboy
Reged: 07/17/12
      #5876153 - 05/21/13 03:10 PM
Of course processing is a matter of personal taste.
I agree with you 100%
ASTROTRUCK
Reged: 01/02/10
      #5877909 - 05/22/13 12:15 PM
THANKS for replies & for the photoshop help -
i lightened my image but i see the granulation is just not there as in other posters' images.
i think it is my stacking process - i shall use "virtual dub" to start selecting the clearer images - regi6 at 95% quality is not showing any difference.
thanks for help
BYoesle
Reged: 06/12/04
      #5878408 - 05/22/13 03:44 PM
Hi Astrotruck. I would change to using the best frame % in RS6 (I use the best 10-20 %), and go easy on the linked wavelets. Then combine in iMerge, and do the final adjustment for brightness, contrast, etc. in your image program... I use Paint shop Pro, but Photoshop should have the same histogram adjustment tool. For bringing out the granulation, try the unsharp masking tool -- good luck.
BTW -- CaK can be more difficult than Ha, and is more affected by the seeing conditions...
ASTROTRUCK
Reged: 01/02/10
      #5878910 - 05/22/13 07:28 PM
THANKS - i shall reset the rs6 to 10% - also just tried the unsharp mask MUCH better- THANKS .
cak is tough but thanks to lunt my 2" straight thru is a good one - i see together both surface detail & prominences via laptop - very beautiful ...
your doublestack has me drooling ... i might add a lunt etelon to my meade 60 coronado etelon & meade 1500 blocking filter. lunt appeared onto the market about 4 months after i prepaid my mexican meade order.
thanks for your help !!
9 registered and 13 anonymous users are browsing this forum.
