steve-in-kville
Reged: 12/24/07
Loc: Pennsylvania, USA
Using my EQ in ALT/AZ??
      #5880723 - 05/23/13 04:48 PM
Questions don't come dumber than this one... please read on.
My experience with EQ's was limited to the EQ-2 that came with my refractor. I just took delivery of my Celestron AVX and I am itchin' to get it outside and play.
Anyone who says that the dumbest questions are the ones not asked has never met me! So here goes...
If I want to use my mount in a normal alt/az way, still obviously use my hand control for up/down & left/right functions, how would I do it?
I know that many of these computerized/motorized mounts have such a function. I have read all through the manual and have found nothing. I have also punched around on the hand control and cannot find such a function.
Has anyone done this? I would like to do some solar as well as terrestrial tomorrow if the weather holds.
Mark9473
Reged: 07/21/05
Loc: 51N 4E
Re: Using my EQ in ALT/AZ?? new [Re: steve-in-kville]
      #5880770 - 05/23/13 05:09 PM
Looks like you're out of luck. The latitude adjustment range is 7 to 77 degrees so you can't get it to alt-az.
steve-in-kville
Reged: 12/24/07
Re: Using my EQ in ALT/AZ?? new [Re: Mark9473]
      #5880776 - 05/23/13 05:12 PM
Hmmm. Okay. Guess I will stick with my GNG set up for such viewing.
Phil Sherman
Reged: 12/07/10
Loc: Cleveland, Ohio
      #5882633 - 05/24/13 04:15 PM
If your balancing will allow it, you could adjust the tripod legs so that that the 77 degree altitude becomes 90. I suspect that you'll need to have one leg pointing South to prevent the mount from tipping over. With one leg S, you'll need to have it a bit shorter than the other two.
Phil
8 registered and 33 anonymous users are browsing this forum.
