Schaden
Reged: 06/30/08
Loc: Sonoran Desert
First time Antares split
      #5894116 - 05/31/13 11:44 AM
I tried a few weeks ago and could see the B star's light around the edge of Antares' glare, but last night I got a clean split. It was my first time. My diagonal reverses left to right, and it was just where I'd seen a hint of it before. At about the "10 o'clock" position. I had read some see it as green but to me, it was definitely bluish white. At 360x you could have driven a truck between them, at 180x it was still distinct. I think seeing was about an 8/10 Pickering.
Double stars are cool.
C_Moon
Reged: 10/23/09
Loc: Beneath the arms of Cassiopeia
Re: First time Antares split new [Re: Schaden]
      #5894123 - 05/31/13 11:48 AM
Congrats! I've always seen the companion as having a bluish tint as well.
Nucleophile
Reged: 05/24/13
Loc: United States
      #5894132 - 05/31/13 11:51 AM
congrats from here as well. now that you have seen it once, you will see again given good conditions.
In my hands, the secondary is greenish. I always find this target is a good indicator of seeing conditions.
Bill Boublitz
Reged: 05/04/13
Re: First time Antares split new [Re: Nucleophile]
      #5894218 - 05/31/13 12:42 PM
Congrats indeed. My first Antares split was a thrill. I also see it as more green.
Bonco
Reged: 04/17/06
Loc: Florida
Re: First time Antares split new [Re: Bill Boublitz]
      #5894558 - 05/31/13 03:44 PM
Nice report. The secondary of Antares has always looked greenish to me.
Bill
Rich (RLTYS)Moderator
Reged: 12/18/04
Loc: New York (Long Island)
      #5895607 - 06/01/13 08:01 AM
I've always seen the companion to Antares as a warm green color. I took me years to finally split this double but once I knew what to look for splitting Antares became fairly easy.
Rich (RLTYS)
Schaden
Reged: 06/30/08
Loc: Sonoran Desert
Re: First time Antares split new [Re: Rich (RLTYS)]
      #5895997 - 06/01/13 12:46 PM
Thanks for the feedback everyone.
azure1961p
Reged: 01/17/09
Loc: USA
      #5899190 - 06/03/13 08:51 AM
Nice report. I just may finally try for this one again. I barely try this one though and Sirius the same as the seeing , particularly for Sirius is usually not nearly good enough. I want to see if I can't ace out Sntares though in steadier summer seeing.
Congrats here. The glare off that primary is very substantial. Good work!
Pete
ziridava
Reged: 08/17/12
Loc: Arad,Romania,Eastern Europe
Re: First time Antares split new [Re: azure1961p]
      #5899708 - 06/03/13 01:33 PM
Schaden
Congratulations!
I split Antares two years ago ,in the summer of 2011,with my 125mm F/7 Dobsonian ,at 216x,using a Solid Ramsden 8mm eyepiece and a 2x Japanese Barlow.
The SR 8mm is a modern variation of Tolles eyepiece.
Apart of good seeing and good telescope,I believe the use of simple eyepieces/minimum air-to-glass surfaces is helpful on such objects.
At Antares I remember to see the same colors of the companion like you and Paul/C_Moon.
Thank you for posting this,this is the time to test my 8 inch Dobsonian on Antares.
Mircea
rookie
Good Night Nurse
Reged: 01/14/06
Loc: St. Petersburg, FL
Re: First time Antares split new [Re: ziridava]
      #5902869 - 06/04/13 10:57 PM
Nicely done! Congratulations.
Perigny270
Reged: 10/23/11
Loc: Temiscaming, Quebec
      #5948932 - 07/01/13 12:14 AM
Well I finally got a clean split. I tried a few times this spring but seeing just wasn't there. I also tried reducing the glare from A by using a green filter (a tip from here last year). The best was an oscillating elongated blob. No satisfaction there.
Then a few nights ago I was looking at planets and the moon and Antares beckoned. So I swung my 8SE around. Couldn't see B at all in the glare from A. The only filter I had in my EP kit was my Baader UHC - what the heck. At 200X there was a red star and a green star overlapping. Resolved, but not split. Happy nonetheless. Going to 400X didn't help at all.
Then the clouds moved in.
A whole new story tonight - this time with my ES102ED. No split at first. Get out the UHC filter and BANG: two separate stars (red and green) with a black space between them. My first time for my favourite star. Best at 140X although I did get up to 300X. That was fun! The refractor really does a nice job. on the doubles.
You may want to try the UHC trick. If anyone else has tried it, I'd like to here about it.
Reged: 12/18/04
Re: First time Antares split new [Re: Perigny270]
      #5949163 - 07/01/13 06:47 AM
Myself and other observers have tried UHC filters and have found out that some of them show a secondary reflection of a bright star which will make you think you split a double. I'd suggest you try the filter on a bright known single star and see what happens. I personally don't trust UHC filters for splitting doubles. Hopefully you've been able to split Antares.
Rich (RLTYS)
Nucleophile
Reged: 05/24/13
Loc: United States
      #5949203 - 07/01/13 07:36 AM
Rich (RLTYS)
Several years ago, I saw the exact same thing Rich describes with my 8 inch reflector using a Baader UHC filter--I cant remember which star exactly but do remember it was one that had a very bright primary (such as Antares).
This double is tricky for me even with the 15 inch. Early in the night I can easily see the secondary at 200x or so, but then later in the night I cannot (when conditions should be better). Oddly enough, if the seeing is very good, I can see the companion quite clearly at 150x with the 8 inch. It seems sky conditions are the most important factor for Antares. I seem to recall most of my positive sightings happening at the end of twilight versus in the deep dark of late night--maybe that is the trick?
I did make a very preliminary finding recently using an off axis mask with my 15 to afford an unobstructed 6 inch telescope in which the secondary appeared a bit better to see due to overall dimming of the primary.
Try as I may, I have not been able to obtain a good image of the secondary in any scope with any combination of lenses or camera conditions. Antares is ridiculously difficult to photograph.
You should keep trying this one, though, as you will may see the companion when you least suspect it.
Perigny270
Reged: 10/23/11
      #5950486 - 07/01/13 10:34 PM
Thanks for the advice and feedback. For now it looks like a false alarm (darn!). I will try another bright star to check out the reflection.
I will also keep trying with other filters. Dimming the bright primary is difficult. Antares is always a joy to look at. I'll let you know of any development.
fred1871
Reged: 03/22/09
Loc: Australia
      #5950674 - 07/02/13 01:30 AM
You could try observing in twilight to dim the primary star; the companion is bright enough to show when the sky is not fully dark. It can reduce the glare factor.
The biggest problem with Antares is seeing conditions; good air steadiness is essential, and for observers a long way north that's harder to get because Antares stays low in the sky. On the steadiest nights, I've seen the companion (no filter needed) at only 100x, neatly separated from the primary.
Reged: 12/18/04
      #5950795 - 07/02/13 06:05 AM
Good seeing conditions are extremely important for splitting Antares.
Rich (RLTYS)
Achernar
Reged: 02/25/06
Loc: Mobile, Alabama, USA
Re: First time Antares split new [Re: C_Moon]
      #5955217 - 07/04/13 08:02 PM
Interesting, I have noticed Antares B appearing bluish white sometimes too, even though usually it appears greenish. When it does appear that way, it's usually when the seeing is very steady.
Taras
ggalilei
Reged: 09/01/11
Loc: Kentucky
Re: First time Antares split new [Re: Achernar]
      #5960341 - 07/08/13 11:06 AM
Congratulations Schaden! I only managed a clean split a couple of times and it was exciting. One problem is that Antares tends to stay rather low at Northern latitudes and there is quite a bit of sparkle. The companion rides just in front of Antares as they drift through the field of view: that makes it easy to locate it.
Mark Teran
journeyman
Reged: 02/14/11
Loc: Whittier, CA
      #5960709 - 07/08/13 03:13 PM
Hi:
Whaddaya need to split Antares? I have a 100mm ED refractor, but I have feeling that's not big enough. Of course, I could look it up too. Congrats on that nice split.
Mark
Bonco
Reged: 04/17/06
Loc: Florida
Re: First time Antares split new [Re: Mark Teran]
      #5960831 - 07/08/13 04:21 PM
Mark,
I've obtained several nice splits with a 100mm telescope. Suggest 200-250X.
Bill
3 registered and 0 anonymous users are browsing this forum.
Moderator:  PJ Anway, Rich (RLTYS), rflinn68
