FishInPercolator
Reged: 04/30/13
Loc: NYC
Push To software new
      #5893154 - 05/30/13 08:15 PM
Are there any "push to" software packages that run off a laptop for mounts that do not have native goto capabilities? There would have to be some way for the software to realize the scope's orientation.
orlyandico
Reged: 08/10/09
Loc: Singapore
Re: Push To software new [Re: FishInPercolator]
      #5893166 - 05/30/13 08:23 PM
You need encoders on the mount.
Cartes du Ciel can talk to a Tangent Instruments box (or similar) and update the reticle in real time as you push the scope around.
Although the best bet is probably Sky Safari for iOS or Android, with a Nexus device reading your mount encoders.
Starhawk
Space Ranger
Reged: 09/16/08
Loc: Tucson, Arizona
      #5893169 - 05/30/13 08:24 PM
There are all-in-one as well as encoder based versions. Jim's Mobile Incorporated has several- mostly made as retrofit kits. You can also find them at Universal Astronomics for use on push-to forks (really nice, light, and tough mounts, BTW).
There are others as well. But yes, this capability exists, and you don't actually need the laptop along.
-Rich
FishInPercolator
Reged: 04/30/13
Loc: NYC
Re: Push To software new [Re: Starhawk]
      #5893299 - 05/30/13 09:21 PM
Hey Rich... could it work on an Astro Tech Voyager alt-az? There is a tracking device for that as an add-on as well, so essentially in the end I could have a better version of the 6SE mount I think... now if there's a wedge I could have EQ and possibly the lightest 20 lb payload eq mount in existence!
Edited by FishInPercolator (05/30/13 09:30 PM)
FishInPercolator
Reged: 04/30/13
Loc: NYC
      #5893363 - 05/30/13 11:32 PM
Eh, these train-n-track thingies are a nuisance I hear.
John Carruthers
Skiprat
Reged: 02/02/07
Loc: Kent, UK
      #5895507 - 06/01/13 03:46 AM
http://www.manortronics-force-gauges.com/Astro
AstroFix are compact and self contained push to units.
Starhawk
Space Ranger
Reged: 09/16/08
Re: Push To software new [Re: John Carruthers]
      #5895518 - 06/01/13 04:05 AM
Between the AstroTech Voyager and the NexStar SE, you are talking about going from a set of tailored friction bearings to a fully powered GOTO mount. The Voyger has no hope of tracking something in the sky, Alt Az or Equatorial- it's the minimum gear to be able to walk outside, plop down a scope, and point it at something. With that said, it needs no power or calibration. I suggest just running something like Sky Safari on an iPhone and use the map from it to get way points to get the scope pointed if you are using an AT Voyager.
-Rich
FishInPercolator
Reged: 04/30/13
Loc: NYC
      #5895792 - 06/01/13 10:46 AM
There's a tracking addon for the Voyager but not sure how well it would perform for taking longer than 2 minute exposures.
S.Boerner
Reged: 04/29/10
Loc: Eastern Missouri
Re: Push To software [Re: FishInPercolator]
      #5896092 - 06/01/13 01:50 PM
Google Dave Ek and you'll find links to how to build your own digital setting circles that will let you do a push to with a computer. I added them to my old C8 for about $125 . They work well.
16 registered and 31 anonymous users are browsing this forum.
