Mike in Tampa
Reged: 05/19/13
Piggy backing your SCT?
      #5899981 - 06/03/13 03:39 PM
besides the coolness factor of having a refractor piggybacking on your SCT, what are some of the advantages to this setup?
MikeBOKC
Reged: 05/10/10
Loc: Oklahoma City, OK
Re: Piggy backing your SCT? new [Re: Mike in Tampa]
      #5900595 - 06/03/13 09:16 PM
Setting aside AP applications, the refractor gives you a wide field view as opposed to the SCT "through a soda straw" one. It is also fun to compare the different light gathering power and resolution of the two scopes. Perhaps best of all is for outreach -- you double the available eyepieces for folks. One of my favorite things to do at an outreach event is to piggyback my TMB92L atop the CPC1100 and go to the moon. I first invite visitors to take a gander at Luna in full through the refractor, which usually elicits an "oh wow" comment. Then I offer them a close up view through the big SCT with the Pentax XW7 in the diagonal, which gives them a view of perhaps one-eighth of the moon, and which tends to bring out the "Holy moly Harry you gotta see this!" exclamations.
Of course you are also right . . . a piggyback refractor does look ultra cool.
zippeee
Reged: 12/27/10
Loc: Alberta, Canada
Re: Piggy backing your SCT? new [Re: MikeBOKC]
      #5900947 - 06/04/13 12:57 AM
I used to have my Raptor piggybacked until I got a different mount for it. Now I have my LS80 in those rings, it's nice to have H-alpha and whitelight . . . just pick your eyepiece.
Brian RisleyModerator
Reged: 09/04/06
Loc: SW Florida
Re: Piggy backing your SCT? new [Re: zippeee]
      #5902778 - 06/04/13 10:11 PM
Use a CPC-800 and PST this way, works great for outreach!
(Have to properly counterweight it though!)
Brian
1965healy
The Snarkster
Reged: 06/23/07
Loc: San Antonio, TX
Re: Piggy backing your SCT? new [Re: Brian Risley]
      #5902803 - 06/04/13 10:25 PM
CPC800 with a Stellarvue 80mm piggybacked. Wide field views thru the 80. With the Stellarvue 60 finder I have you can guide using it and use both the SCT and 80 for Astro photography. Balance is critical so a counterweight system is needed. My set up is pier mounted on a wedge in my Obs. I admire folks who put up and take down their scopes, I did it for a year using a scope buggy and found that it stole some of the joy to have to work so hard at it. Built the Obs and easily tripled the time I spend at the scope.
Arizona-Ken
Reged: 08/31/08
Loc: Scottsdale, Arizona
Re: Piggy backing your SCT? new [Re: 1965healy]
      #5908543 - 06/07/13 06:44 PM
I share Mike's views on the subject and the "coolness" factor. In my case, I have a SV80 Raptor mounted on my CPC1100. I use my setup for DSO hunting and enjoy the difference in views in having a galaxy "in context" in a larger view and then zero in on details with the CPC1100. Best of both worlds.
Arizona Ken
rboeAdministrator
Reged: 03/16/02
Loc: Phx, AZ
Re: Piggy backing your SCT? new [Re: Arizona-Ken]
      #5916861 - 06/12/13 12:22 PM
I no longer do any piggy backing but the rail is very handy to slap the laser finder up on to show the public what the scope is looking at.
They are usually impressed that it shows an empty bit of sky to the naked eye.
Mogster
Reged: 03/14/04
Loc: Manchester, England
Re: Piggy backing your SCT? new [Re: rboe]
      #5919217 - 06/13/13 05:44 PM
For visual useI'd rather have the second scope on its own mount. I found that my ED80 got in the way on top of my 9.25 and the viewing position wasn't great. I found mounting and in mounting it to heft the CPC was a bit of a drag also.
It does look cool though.
Stacy
Star Partyer
Reged: 09/15/02
Loc: Seattle, WA
Re: Piggy backing your SCT? new [Re: Mogster]
      #5965910 - 07/11/13 03:26 PM
I mount my SV80 towards the front, and put the diagonal to the side to avoid interfering with the main scope (11" NSGPS). It's actually quite interesting to me to first observe the wide view and then the much more magnified view through the SCT. It also provides a means to view larger targets and open clusters that are simply not practical through the F10 SCT.
It's also so much easier than having to set up two mounts. YMMV.
Stacy
spongebob@55
Reged: 12/26/11
Loc: Bergen Co. New Jersey
Re: Piggy backing your SCT? new [Re: Stacy]
      #5967150 - 07/12/13 10:36 AM
When I had my CPC1100 I mounted my ST80 to it. It gave my a nice wide field view of DSOs and acted as a finder for those nights where I didn't find stuff to easily. But being from a white white zone, the f/5-ness really brightened the background. Also, you have to get counter weighting systems, most likely, so keep that in mind. Also an increase in height which could make it uncomfortable to use. I tried the same on my 14" GEM mounted SCT and gave up because of the added time to set up, extra weight ergo extra counter weights, pain to balance, and just too high to use at some points. But I really liked it on my CPC1100.
Bob
10 registered and 17 anonymous users are browsing this forum.
