Telescope Specific Forums >> Questar Forum
BullTerrier
Reged: 03/09/13
Some Advice new
      #5904862 - 06/05/13 10:24 PM
Hi Folks. First post of mine.
Have learned much from reading the posts. Was waiting till I got my 3.5 from
the "Mother Ship" as you call it, before I posted. Your posts helped me decide
to get the scope I drooled over in S&T magazine when I was a teenager.
Received it today, nearly 20 weeks after ordering it. Jim was absolutely great
to deal with. Professional and very accommodating.
Anyhow, to the point, I have a few questions:
1. When manually pushing the scope in RA and Dec, should it be a little stiff ?
I'm used to a C8 which pretty much moves freely so I was a bit surprised of how
stiff the Q was when I tried moving the scope (without the slow mo knobs) .
Maybe, because there are no clamps on it like the C8, it has to be a bit stiff.
2. The clamp (knob) on the fork on the opposite fork that the Dec Manual Slow
motion knob. What is it for ? Should it remain loose or should it be snug when
using the scope ?
I'm sure I'll have more questions as time goes on but would appreciate some help
with these questions.
First light, I hope, will be tonite !
Thank You
Martin
Michael Lomb
Reged: 10/26/10
Loc: North Island New Zealand
Re: Some Advice new [Re: BullTerrier]
      #5905233 - 06/06/13 03:53 AM
The right ascension dial should be a bit stiff. The pinion arrangement depends on friction. If you want a large change in ascension you just hold the fork mounts with each hand rotate. There is no clutch to work with and no black lash. I had to stiffen the ascension dial after servicing to avoid slippage when using the ascension knob. Details of this are subject of a previous post.
http://www.cloudynights.com/ubbthreads/showflat.php/Cat/0/Number/5148182/page...
I would not get carried away with loosening the ascension dial, the adjustment screw can disengage altogether. Stiff is good, slippage is bad.
The dial on the L fork if turned counter clock wise can lock (or at least stiffen) the declination dial on the R fork mount. I just leave it loose. I have never found a need to use it at all.
Billydee
Reged: 01/23/08
Loc: Winter Haven, FL
Re: Some Advice new [Re: Michael Lomb]
      #5906327 - 06/06/13 03:59 PM
Martin,
Michael is 100% correct. Welcome to the club and enjoy your new Lady.
Bill
ColoHank
Reged: 06/07/07
Loc: western Colorado
Re: Some Advice [Re: Billydee]
      #5906472 - 06/06/13 05:29 PM
The knob on the left fork is the declination lock. It should be loose when observing and tightened (counterclockwise) when the scope is transported. I suppose it might be desirable, as well, to tighten the declination knob if you have a camera mounted on the scope so any imbalance doesn't cause an unwanted shift in declination.
0 registered and 0 anonymous users are browsing this forum.
Moderator:  cbwerner, Brian Risley
