jacobmarchio
Reged: 08/30/12
Loc: Alabama
CGEM azimuth motion rough
      #5908221 - 06/07/13 03:56 PM
Hi all,
The azimuth motion for polar alignment on my CGEM is very rough, or "jumpy". Is there an easy solution for this? WD-40? Anything recommended/not recommended?
DaveJ
Reged: 01/07/05
Loc: NE Ohio
Re: CGEM azimuth motion rough new [Re: jacobmarchio]
      #5908242 - 06/07/13 04:02 PM
Hi all,
Funny you should ask. Take a look at an ongoing thread here.
jacobmarchio
Reged: 08/30/12
Loc: Alabama
Re: CGEM azimuth motion rough new [Re: DaveJ]
      #5908368 - 06/07/13 04:57 PM
Oops! Didn't see that thread! Thanks.
I'll try WD-40, and see if it works. Bicycle chain grease was suggested, so I'll try that next...
DaveJ
Reged: 01/07/05
Loc: NE Ohio
      #5908514 - 06/07/13 06:27 PM
I'd first try "Super Lube" available at Harbor Freight or Amazon if you're sure grease is the idea you'd like to try. Honestly, the white plastic "milk jug" is a better idea but the sticky-backed UHMW plastic is much better still, especially if you'll be taking it apart for travel setup.
Ron (Lubbock)
Reged: 08/17/12
Loc: West TX
      #5910633 - 06/08/13 11:47 PM
When the mount is first put onto the tripod, one tightens a screw clamp underneath the tripod to secure the mount. This hand-tightened clamp should be loosened just a little before making azimuth adjustments. On my mount, the azimuth then glides smoothly. Otherwise, the azimuth sticks or moves in spurts. Of course, one has to tighten it again before continuing.
DaveJ
Reged: 01/07/05
Loc: NE Ohio
Re: CGEM azimuth motion rough new [Re: Ron (Lubbock)]
      #5911011 - 06/09/13 09:07 AM
No need to loosen the head when the UHMW material (mentioned above) is used. Honestly, as I previously mentioned, the head can be cranked down hard and the AZ motions are "smooth as butter" once the UHMW material has been installed. It made a night-and-day difference in my CGEM DX and my friend's CGEM.
Ron (Lubbock)
Reged: 08/17/12
Loc: West TX
      #5911050 - 06/09/13 09:48 AM
That's an interesting fix. UHMWPE also performs well in hip replacements, probably for the same reasons- good wear resistance.
Raginar
Reged: 10/19/10
Loc: Rapid CIty, SD
      #5911164 - 06/09/13 11:29 AM
Add some super lube. the other thing I found that helped was getting ADM knobs. They're easier to grab... You can also drill the holes out and re-tap them with SAE threads.. And, the 'milk jug' material helps tremendously.
Edited by Raginar (06/09/13 11:30 AM)
petemumbower
Reged: 07/12/09
Loc: West Michigan
Re: CGEM azimuth motion rough new [Re: Raginar]
      #5912038 - 06/09/13 08:57 PM
I used slick strips on my CGEM tripod head and it is super smooth now for polar alignment. I detailed the install and linked to the supplier on my little blog HERE.
mich_al
Reged: 05/10/09
Re: CGEM azimuth motion rough new [Re: petemumbower]
      #5912286 - 06/09/13 11:47 PM
Take a look at both sliding surfaces and make sure they are smooth. Mine had some paint that needed to be removed and some rough areas that needed sanding. Careful harping too much on tha AZ adjusters cause the thread in the mount can be stipped.
gmartin02
Reged: 04/11/05
Loc: Santa Clarita, CA
      #5913550 - 06/10/13 04:38 PM
I just cut my own ring out of a piece of 1/16" thick Teflon sheet I had lying around from another project - now the motion is super smooth.
jacobmarchio
Reged: 08/30/12
Loc: Alabama
Re: CGEM azimuth motion rough new [Re: gmartin02]
      #5915325 - 06/11/13 03:53 PM
Thanks everyone for your suggestions- I'll be trying them.
Stargazer78
Reged: 03/05/13
Loc: Susanville California
      #6051435 - 08/28/13 08:15 PM
Looks like mine is doing the same thing
Stew57
Reged: 05/03/09
Loc: Silsbee Texas
Re: CGEM azimuth motion rough new [Re: Stargazer78]
      #6051443 - 08/28/13 08:22 PM
Poor man's Teflon (milk jug)on mine. Works great and is free.
A. Viegas
Reged: 03/05/12
Loc: New York City/ CT
Re: CGEM azimuth motion rough new [Re: Stew57]
      #6051622 - 08/28/13 10:40 PM
I used the milk jug cut-out as well, with some WD40 squirted on it for good measure. works great now, going on 4 months... no complaints...
Al
17 registered and 44 anonymous users are browsing this forum.
