Pages: 1 | 2 | 3 | (show all)
dwitek
Reged: 07/03/08
Loc: White Lake, Michigan
No More Tracking
      #5909099 - 06/08/13 01:12 AM
My previously perfect CPC925 refused to track tonight. I noticed it right away as the finder and eyepiece view was drifting when I started my alignment. The readout of the Alt and Az positions was not incrementing and the drift was the same when I powered off the scope so I know it wasn't moving. The clutches were tight. The regulated power supply showed 13.8 volt with hardly any draw. The hand controller moved the scope in all directions with no issue.
I did a quick SkyAlign alignment before the stars could drift too far and it said Alignment Successful but it still didn't track. I loosened and tightened the clutches and moved the scope by hand. I performed two Factory Resets with no change. I tried different Tracking Modes for grins but no change in behavior.
It was one of those perfect nights that don't come to often in Michigan but at least I got to watch the Milky Way rise.
Anyone have any thoughts or should it just be packaged up and sent to Celestron? What about refreshing the firmware?
Dave
Digital Don
Reged: 01/20/04
Loc: Manteno, IL
Re: No More Tracking new [Re: dwitek]
      #5909179 - 06/08/13 03:38 AM
Hi Dave,
I've heard of instances where the tracking mode apparently shut itself off, and other instances where users have inadvertantly turned tracking off.
Double-check that the tracking mode is set to Alt-Az, (or N/S Equatorial as appropriate), an the tracking rate is set to siderial.
Hope you get it sorted out!
Don
dwitek
Reged: 07/03/08
Re: No More Tracking new [Re: Digital Don]
      #5909335 - 06/08/13 08:16 AM
Every time I go into the Tracking Mode setup it shows OFF, so I change it to Alt-Az and hit ENTER. When I go back to Tracking Mode it says it's OFF again. What I can't remember is if it should normally show the tracking mode the scope is in or if OFF should be shown on the menu. It does show SIDEREAL for tracking rate. Can someone verify that?
dwitek
Reged: 07/03/08
      #5909349 - 06/08/13 08:33 AM
I put the scope in EQ North tracking mode and it does "stick" in the menu. I then checked the Axis information and it is incrementing in one axis only, as it should for an equatorial setting. But, when I try to put it in Alt-Az, it always reverts to OFF when I go back and check the setting. So, it's either the hand controller or something in the scope telling the hand controller that it can't do Alt-Az tracking. Anyone else ever see this?
Monadnock
Reged: 04/24/12
Loc: SW NH
      #5909418 - 06/08/13 09:32 AM
Have you tried updating the firmware version?...or if it's current (4.21, I believe] re-flashing it? You'll likely need an RS232 to USB adapter. Celestron recommends this one.
dragonslayer1
Reged: 02/25/12
Loc: SLC, UT
Re: No More Tracking new [Re: Monadnock]
      #5909530 - 06/08/13 10:45 AM
Just a FYI, just before I deforked my 9.25 I had upgraded handset and seem to remember that for one mode to stay locked in (alt/az?) the scope has to be aligned. Put it into just a quick or fake align and see if it changes,,
Kasey
dragonslayer1
Reged: 02/25/12
Loc: SLC, UT
Re: No More Tracking new [Re: dragonslayer1]
      #5909533 - 06/08/13 10:47 AM
PS for above listed issue I spent a lot of time with Celestron on the phone and 3 different people before they acknowledged it is just a firmware thing
dwitek
Reged: 07/03/08
      #5909911 - 06/08/13 03:04 PM
So, I've updated the hand controller to 5.21 and re-imaged all of the motor controllers to 5.14 but no joy. It will just not allow me to choose Alt-Az tracking mode. You can choose it in the menu but when you go back to the tracking mode menu it says OFF. If you do the same with EQ North or EQ South the chosen mode is shown when you return the next time. If I put it on a wedge it would probably work fine but that's not why I have this scope. It's purely for visual.
Looks like I'll need to call Celestron and find out how to send it in.
Monadnock
Reged: 04/24/12
Loc: SW NH
      #5909918 - 06/08/13 03:12 PM
So it does in fact track in those modes?
dwitek
Reged: 07/03/08
      #5909978 - 06/08/13 03:45 PM
Yes, I can hear the motor running and I can see the AZ incrementing when I look at Get Alt-Az in the Utilities (?) menu. I did notice that if I put it in EQ North setting and turn the scope off and back on that it does not retain the Tracking Mode EQ North setting. It always says OFF. But, every other setting int he hand controller is retained.
I don't know their software but it seems that there is some kind of error on the board that reports back to the hand controller to turn tracking off. As a computer guy I'm just speculating.
dragonslayer1
Reged: 02/25/12
Loc: SLC, UT
      #5910064 - 06/08/13 04:34 PM
Try this and test it
Kasey
Monadnock
Reged: 04/24/12
Loc: SW NH
      #5910256 - 06/08/13 07:05 PM
Well I'll just say I'm NOT a computer guy, so you may be correct. I was thinking your controller may have gone bad. Replacing that would be MUCH easier than having to ship the scope out, and the shipping cost and down time would likely be a wash. I always assumed the "brains" of the CPC were in the hand controller, and the boards in the base and arms were just for GPS and motor control. Definitely give Celestron tech a call on Mon. Hopefully, they'll have an easy fix for you.
Got a scope shop that sells CPC's nearby? If so, give them a call and see if they'll let you bring yer scope down and swap controllers for a quick sec. If the new one works, there's your answer. At that point, if it were me, I'd order a replacement through them even if its a few bucks more than your favorite E-store.
Edited by Monadnock (06/08/13 07:11 PM)
dwitek
Reged: 07/03/08
      #5910303 - 06/08/13 08:00 PM
Kasey
Sorry, no go on that one. Ya gotta know when to fold 'em.
dwitek
Reged: 07/03/08
      #5910308 - 06/08/13 08:05 PM
Actually I have another Nexstar+ hand controller I got as spare with the previously owned CGE I have downstate. Might need different firmware for the CPC. As long as they're not hardware dependent it should work. I won't be there till next weekend but I'll bring the CPC with me to test before sending. Thanks for jogging my memory, Monadnok!
Monadnock
Reged: 04/24/12
Loc: SW NH
      #5910381 - 06/08/13 08:53 PM
No prob. I THINK they're the same controller, hardware wise. There are 2 different part #'s for the 2 different versions but I believe the fundamental diff is software. A quick flash and you should be all set.
If you can't find your other controller, PM me.
See what Celestron says on Monday. Gotta love how this stuff always happens on weekends. If it needs replacing, and the warranty is expired, who knows, Celestron may still hook you up. If they don't, and you don't want to leave your CGE without a controller, you can get one quickly from that "river" site. The new and improved + version too
btieman
Reged: 07/24/08
      #5910971 - 06/09/13 08:22 AM
You may also try a factory reset on the hand controller. Mine has gotten garbled up in the past to the point where it did very odd things until I factory reset it.
Monadnock
Reged: 04/24/12
Loc: SW NH
Re: No More Tracking new [Re: btieman]
      #5911038 - 06/09/13 09:38 AM
He tried that already. First post
I'm interested to hear what Celestron has to say regarding the issue. Again, I'm not a computer guy but it sure sounds like a software issue the more I think about it. I can't see how the controller being physically bad would cause this issue, though I hope he doesn't have to send the OTA in for service.
dragonslayer1
Reged: 02/25/12
Loc: SLC, UT
      #5911118 - 06/09/13 10:38 AM
Am folding, LOL,
Kasey
dwitek
Reged: 07/03/08
      #5911546 - 06/09/13 03:33 PM
I'll post the progress for future generations, LOL.
brucepech
Reged: 04/18/12
Loc: Colorado
      #5914116 - 06/10/13 09:45 PM
I have a similar but not identical problem with a fresh out of the box 11" CPC DeluxeHD. At first light last night, it was immediately apparent that the scope wasn't tracking in ALT-AZ mode during a non-auto, two star alignment. Like the OP, I did an on-the-fly alignment and a goto to Saturn. The goto was successful but Saturn rapidly drifted out of the eyepiece's FOV. To keep the planet in view I had to continually track it manually using the directional arrows. Judging by my Telrad, each subsequent goto was more and more off base -- probably because of my manually tracking the preceding target. Turning the scope off and on again, I noticed that the ALT-AZ tracking mode setting hadn't "stuck" although the tracking rate remained pegged to sidereal. Over the next five hours, turning the scope off and on coupled with successive, on-the-fly two star alignments resulted in acceptable gotos to the first object (M13, M91, M57, Albeiro, etc.) but subsequent failures because the scope wouldn't track without manual intervention.
This morning I did an indoor two star alignment with a planisphere. The scope appeared to track "Altair" for six hours, continually incrementing in both axes according to the Get Axis Positions utility and ending up pointing at the western horizon. However, checking the hand box afterward, it was immediately apparent that, after setting it to ALT-AZ, the mode immediately reverted to "Off" (Menu>Tracking>scroll to ALT-AZ>press Enter>press the Back button until I was at the introductory Alignment display>repeat until reaching Mode>LCD display reads "Off.") However, the North and South Eq modes remained on following the same series of steps.
So I'm well and truly baffled. This morning, the scope appeared to track my faux Altair indoors -- but wouldn't track outdoors yesterday evening. And, while the North and South EQ tracking mode settings remain on when set, the ALT-AZ mode immediately defaults to off. The Handbox is one of the new Nextstar+ models introduced in December which came with firmware version HC:NXS 5.26.2336 loaded. The motor control firmware is MC: 6.16 6.16. I haven't tried to load any other firmware versions -- and don't think newer ones have been issued by Celestron.
Has anyone (other than the OP)with the same Nexstar+ and firmware versions experienced similar issues? Is it possible that the firmware in some handboxes is corrupt while others are OK? Could it be a non-software problem? I've already looked at the other posts in this thread and none of the suggested fixes work -- although I don't have another handbox to try out.
Thanks for any insights or suggestions.
astrovienna
Reged: 12/04/06
Loc: The NoVa White Zone
Re: No More Tracking new [Re: brucepech]
      #5914370 - 06/11/13 12:29 AM
Do you guys get the same result when you use Nexremote instead of the hand control? That might narrow down the issues.
Kevin
brucepech
Reged: 04/18/12
Loc: Colorado
Re: No More Tracking new [Re: astrovienna]
      #5914484 - 06/11/13 03:13 AM
Since I just bought the CPC to complement my vintage 8" LX-90. I haven't explored Nexremote or other exotic options. I'm stuck with the handbox for the time being. But thanks for the suggestion.
Monadnock
Reged: 04/24/12
Loc: SW NH
      #5914703 - 06/11/13 09:32 AM
Now you guys got me going. I recently replaced my perfectly functioning stock controller (Loooong story) with a Nexstar + controller. Mine, before alignment always defaults to off as well! After a 1 star mock alignment, and accessing the mode via the menu button, it shows tracking in alt-az mode. I used Betelgeuse as the alignment star because it's to the south right now. While I have no idea if it's tracking accurately, it is audibly tracking using both motors.
Is it possible we're all having a "duh" moment here and any visually confirmed tracking errors are simply due to poor alignments? It seems logical that the tracking mode is set to "off" if the scope hasn't been aligned yet.
ETA- I'm still using the stock motor firmware version. Scope manufactured in '11 or '12.
Edited by Monadnock (06/11/13 09:35 AM)
brucepech
Reged: 04/18/12
Loc: Colorado
      #5914943 - 06/11/13 12:07 PM
I dunno Monadnock. I'm just familiarizing myself with Celestron handboxes. My old Meade Autostar 497 always tracked *during* a two star alignment. I set the "mount" (the same, or so I think, as Celestron's tracking mode) to ALT-AZ over a year ago and it's retained the setting ever since. When I align the Meade, the alignment stars remain in the eyepiece FOV while I center them; I don't have to keep chasing them with the Autostar's directional arrows. Since my Nexstar+ deletes the ALT-AZ tracking mode setting and reverts to off every time I set it, I'd have to do a mock alignment to get it to track before doing a real alignment -- which is counterintuitive since it'd have to be done every time the handbox is turned off and on between observing sessions. Moreover, unlike ALT-AZ, the EQ North and South tracking mode settings are retained by the handbox. Again, it seems coounterintuitive that ALT-AZ reverts to "Off" while the other modes don't. But, as I said, I'm new to Celestron products.
PS. I can hear the tracking motors whirring too after a mock alignment. I'm beginning to think that a non-sidereal tracking rate (even though the Handbox is set to and retains a sidereal setting) is the problem both in centering the alignment stars in the FOV during a real alignment and in the post-alignment drift of the goto target object.
Monadnock
Reged: 04/24/12
Loc: SW NH
      #5915053 - 06/11/13 01:11 PM
Hmm. I've never actually taken note as to when the scope starts tracking. I normally use the 3 star alignment, or whatever it's called, and I assume that after the 3rd star is centered and ALIGN is pressed, it starts tracking.
If I'm understanding everyone's previous posts, and my own recent discovery, the CPC defaults to alt-az mode and shows "off" before an alignment. After the alignment it may show as being off, though I haven't seen it, but still tracks in that mode. Perhaps it showing as off is some sort of trivial software glitch? Not even sure if that makes sense. I'll have to look into it further after work.
jchaller
Reged: 05/29/08
Loc: Tenino, WA.
      #5915073 - 06/11/13 01:32 PM
It shows off if not aligned and alt-az after alignment.
If it tracks, but tracking is off, make sure your time/site info is correct.
dragonslayer1
Reged: 02/25/12
Loc: SLC, UT
      #5915097 - 06/11/13 01:43 PM
This might apply to you, Prior page post,, and yes I have folded LOL
""Just a FYI, just before I deforked my 9.25 I had upgraded handset and seem to remember that for one mode to stay locked in (alt/az?) the scope has to be aligned. Put it into just a quick or fake align and see if it changes""
Kasey
And as previously posted, spent much time on phone with 3 people and third one said needed to be aligned for Alt/AZ to work
brucepech
Reged: 04/18/12
Loc: Colorado
      #5915115 - 06/11/13 01:54 PM
Once again, Monadnock, I dunno. I just replicated your result by doing a mock one-star alignment to Betelgeuse and tracking(?) a faux Jupiter. When I returned to tracking mode, ALT-AZ was, surprisingly, on (as you noted). However, the menu doesn't allow you to do a manual two star alignment w/o turning the scope off (I tried) -- and when you turn it off the ALT-AZ mode also reverts to off. Which means that the scope won't track during a manual two star alignment making it darned near impossible to center the alignment stars in the eyepiece and, therefore, extremely difficult to complete the alignment procedure.
Taking into account the near impossibility of doing a real, non-auto two star alignment, I remain persuaded that, unlike my LX-90, the scope doesn't track *during* a two star alignment or that the tracking rate isn't (even though it's set to it in the Nexstar+) sidereal. I'm basing my supposition on the serially more inaccurate gotos I experienced after each (imprecise) two star alignment.
Since most experienced observers say that the manual two star alignment is more accurate than other procedures (which was my experience with my LX-90) I ordered another Nexstar+ from "that river place" (at *half price*). I'll report back if it performs differently.
Edited by brucepech (06/12/13 12:31 AM)
brucepech
Reged: 04/18/12
Loc: Colorado
      #5916166 - 06/12/13 12:25 AM
Well, page 10 of the Celestron Manual explicitly says that tracking doesn't begin until the scope is aligned (at least when doing a manual two star alignment, but probably with all alignment procedures):
"Once the second star alignment is completed properly, the display will read Alignment Successful, and you should hear the tracking motors turn-on and begin to track."
How you're supposed to accurately center a star moving at 15 degrees/hour in a 12mm illuminated reticle eyepiece like Celestron's Crossaim (or any high or moderate power eyepiece for that matter) remains a mystery to me. In my experience, the star will traverse the non-tracking eyepiece's FOV pretty quickly making centering problematic,
The Manual suggests adjusting the directional arrow slew rate to facilitate centering, so I suppose you could adjust it to a sidereal or 2x sidereal rate by pressing the "Motor Speed" (or "Rate") button followed by buttons "2" or "3," chase the star across the sky until it appears centered, then quickly mash down the "Enter" and/or "Align" buttons. But this procedure is almost guaranteed to be inaccurate unless the direction of the star's motion and the direction of the slew are precisely aligned with one another. (See all the threads about the importance of accurate centering to proper alignment in the Cats and Casses Forum.)
C'est la vie I suppose. If that's the way Celestron designed the scope, that's the way Celestron designed the scope. (BTW Dragonslayer and Jchaller are correct: the handbox won't lock in "ALT-AZ" until the scope has been aligned.)
Edited by brucepech (06/12/13 12:38 AM)
cn register 5
Reged: 12/26/12
      #5916311 - 06/12/13 03:35 AM
How would the mount know what direction to move until it's aligned?
In practice it's quite easy to position the star just in front of the cross hairs and press the Align button as it passes them.
Chris
brucepech
Reged: 04/18/12
Loc: Colorado
Re: No More Tracking new [Re: cn register 5]
      #5916369 - 06/12/13 05:40 AM
cn, all I can say about my 2003 LX-90 is that it does -- perhaps because alignment begins in what Meade calls the "Home" position: w/ the OTA level and pointed at a reasonable approximation of celestial north.(Easily accomplihed by orienting the tripod so that the front two legs are at the 10:00 and 2:00 positions and the rear leg is at the 6:00 position in relatio to a N-S line, manually pointing the OTA at Polaris by loosening the AZ and ALT clutches, tightening the AZ clutch, leveling the scope, tightening the ALT clutch, and beginning the alignment procedure. I can't visualize the geometry, but I suspect that it then tracks at a sidereal rate roughly aligned with the celestial paths of the target alignment stars. (Perhaps this was the precursor to Meade's later, automated LNT technology and its successful patent infringement suit against Celestron.)
If my intuition about starting an alignment in Home position is incorrect (as well it might be), then I don't have the faintest idea why the target stars remain comparatively stationary in the LX-90's eyepieve's FOV while I center them.
In any event, I guess I was wrong when I initially said that I had a "problem." I think I'm just suffering from cognitive dissonance as I try to reconcile Meade's familiar alignment procedure w/ Celestron's.
Edited by brucepech (06/12/13 08:44 AM)
Reged: 07/06/07
      #5916516 - 06/12/13 08:49 AM
Not much of a problem IMHO. I've been doing it for over a decade without a problem, anyhow. The GPS series of scopes worked exactly the same way: tracking off till aligned, then alt-az tracking kicks in.
Alt-az tracking requires different motor speeds depending on _the position the scope is pointed to in the sky_, so until the alignment is done, there's not much point in starting tracking.
Edited by rmollise (06/12/13 08:51 AM)
KerryR
Reged: 12/05/07
Loc: SW Michigan
Re: No More Tracking new [Re: rmollise]
      #5916545 - 06/12/13 09:07 AM
I've had no issues aligning either. It's been pretty easy to slowly guide the star to the center, finishing movements in the same direction goto's finish to absorb any backlash, and hit "align".
I believe there's a bit of wiggle-room built in to the software-- things can be a LITTLE off and the computer can still figure out the alignment accurately.
This is just the price we 'pay' for not having to start in a 'home' position, as I must with my LX90.
Monadnock
Reged: 04/24/12
Loc: SW NH
Re: No More Tracking new [Re: KerryR]
      #5916630 - 06/12/13 10:04 AM
I agree with KerryR. I'm not even sure the scope cares if the first 1 or 2 stars, depending on your alignment method of choice, are centered in the FOV. I believe its just an identification thing for the scope to get it's bearings. The last star is the "money" star as far as centering goes, and it can be tweaked after alignment WHILE the scope is tracking. I believe what is far more important is choosing good alignment stars as described in the manual. These choices can make or break a successful alignment, or cause somewhat poor tracking.
Out of the 10 or so (ya, wow, that many) times I've used my CPC, I've never had an issues aligning the scope or tracking an object, providing I've chosen bright stars. Never actually left the scope on one object longer than a couple hours but it has always tracked virtually flawlessly.
brucepech
Reged: 04/18/12
Loc: Colorado
      #5916662 - 06/12/13 10:28 AM
Rod, Monadnock, and Kerry ... as I said in my post to cn, what I thought was a firmare issue appears instead to be cognitive dissonance after several years if experience aligning a Meade LX90 and no experience whatsoever in aligning Celestron scopes. At least I've learned a good deal about my new CPC from your explanations. I apologize for any confusion I've caused.
Bruce
dwitek
Reged: 07/03/08
      #5922416 - 06/15/13 02:55 PM
And I apologize, too, for starting this whole thing if it is in fact just a misunderstanding on my part. The CPC is a bit of an anomaly for me as I am used to using equatorial scopes. I just don't remember having any drift when doing an alignment with the CPC. I've reset the original hand controller and pushed the CPC software into another with the same results.
If I do a mock Two Star alignment I now get tracking in Alt-Az and I can do GoTos to anything in the sky. Perhaps I did have a software issue initially because after getting Align Success in the field it still wouldn't track. So, maybe the resets cleared that up but I was fixated on the Tracking Mode rather than going through the whole process.
I think the discussion was a good one and I thank everyone who stepped in. I'll move the scope back up to it's home next weekend and try it again weather permitting, of course.
Reged: 07/06/07
      #5925100 - 06/17/13 09:38 AM
No need to apologize...stuff happens. I have run into a scenario like this using an older version of Bisque's TheSky. Tracking would just freaking go OFF. I finally realized it was a hiccup with the program, but I was going koo-koo for a while.
Reged: 06/16/04
      #5928342 - 06/18/13 10:02 PM
Is this the case with all Nexstar mounts? The scope knows that it is hopefully close to the intended alignment star so it should be able to track with reasonable accuracy...
brucepech
Reged: 04/18/12
Loc: Colorado
Re: No More Tracking new [Re: Jon Isaacs]
      #5928584 - 06/19/13 01:26 AM
Jon, to quote from a post by cn register 5 on the Cats & Casses Forum where I raised the same question I raised here:
"Part of the reason that the Celestron AltAz mounts don't track before they have aligned on at least one star is because of the Meade patent on starting at a known terrestrial alignment. Without that the scope doesn't know which way to track. If it makes some assumption about which way to track it could be said to be infringing on the patent."
So, yes, it's probably true of all post-patent Nextar mounts.
Reged: 06/16/04
      #5928731 - 06/19/13 07:12 AM
Bruce:
Thanks for the info...
I better be careful when I align my non-GOTO mounts, make sure I align them on Polaris before turning on the drive.. My property and house are within in less than a degree of being aligned north-south/east-west so I can align very closely just by looking that the house or fence.
Of course maybe Meade doesn't have the patent on aligning to a building, fence or road...
It does seem like a strange patent, no creativity there, it's a no-brainer and people have been doing it forever, I would guess from the invention of the tracking drive. It's not GOTO but its alignment.
jon
mclewis1
Thread Killer
Reged: 02/25/06
Loc: New Brunswick, Canada
      #5929454 - 06/19/13 02:48 PM
Just a warning for those who are are trying out NexRemote and using an EQ oriented mount (gem or on a wedge). If you do your initial alignment from the real hand controller and then with NexRemote on your PC you just do something simple like adjust the settings (no initial alignment or anything like that) it will set the real hand controller tracking to OFF.
It would be interesting to see if the Alt Az oriented mounts with NexRemote do the same thing.
Since you're supposed to only use one or the other "controllers" in practice this situation shouldn't come up but if you happen to have NexRemote loaded on you PC and you're looking at this tracking On/Off issue it might get quite confusing.
Reged: 07/06/07
      #5931119 - 06/20/13 11:27 AM
Yes, this is the case with all the _fork_ mounts, Jon. Whether it knows where it is in the sky, roughly, depends on the alignment method. The old GPS north-level? Yes. The newer modes like Auto-two-star? Not at all. At any rate, tracking does not begin with the fork mounts until alignment is complete.
8 registered and 13 anonymous users are browsing this forum.
