robininni
Reged: 04/18/11
Loc: Stephenville, TX
What's on this secondary?
      #5921118 - 06/14/13 07:25 PM
I noticed that my old 4" secondary compared to my new 4.5" secondary reflects the laser collimator light differently. What I mean is the laser beam is very difficult to see on the new secondary where it hits it and it is VERY easy to see it on the old secondary.
I then noticed upon shining a flash light at the 4" secondary it is covered with an opaque like blue tint but this isn't visible without artificial light shining on it and it helps to show up if the light is shined and an angle other than perpendicular to the mirror.
I have included some pics of both mirrors: side by side, then up close with the flash light showing the blue on the 4" and the absence of it on the 4.5".
Is this cleaning residue? Is this a failing coating? What's going on here?
Rob
Edited by robininni (06/14/13 07:29 PM)
GlennLeDrew
Reged: 06/18/08
Loc: Ottawa, Ontario, Canada
Re: What's on this secondary? new [Re: robininni]
      #5921134 - 06/14/13 07:38 PM
There would seem to be more scattering from the older surface; the red of the laser and the blue from (I presume) your while LED flashlight. How do the surfaces vompare when sunlight falls on the surface?
robininni
Reged: 04/18/11
Re: What's on this secondary? new [Re: GlennLeDrew]
      #5921147 - 06/14/13 07:49 PM
Glenn,
The 4.5" is installed back in the scope so I couldn't take it into the sunlight but I did take the 4" outside just now and I don't notice anything unusual with sunlight on the mirror surface.
Also, yes, your presumption is correct about a white LED flashlight.
Rob
Edited by robininni (06/14/13 07:50 PM)
robininni
Reged: 04/18/11
      #5922534 - 06/15/13 04:50 PM
So does anyone really know? My first thought was cleaning residue (soap), but I didn't think that would be so uniformly distributed. I got the idea of soap because somewhere I read someone asking something similar of a primary, although it was only a spot here and there and cleaning residue was a given answer.
My primary, before getting refigured and recoated, had some areas and streaks that looked like this in white light from a flash light, and in one of these areas, I could see a weird honey comb like pattern. Again, I wasn't sure what it would be having no experience with reflector mirrors but now that I think about it it doesn't make sense that you cannot see this just looking at the mirror in daylight if it was on rather than 'in' the coating. What was the honey comb pattern? Is this a coating getting thin with time?
And so back to the secondary... A failing coat, a worn coating? What say you? This secondary is roughly 2 1/2 years old.
Rob
Darren Drake
Reged: 10/09/02
Loc: Chicagoland
      #5922581 - 06/15/13 05:28 PM
Did you clean the old secondary. Unseen residue could cause this.
Howie Glatter
Vendor
Reged: 07/04/06
      #5922593 - 06/15/13 05:38 PM
". . the laser beam is very difficult to see on the new secondary where it hits it and it is VERY easy to see it on the old secondary."
The dirtier the mirror, the easier to see the beam impact.
"I then noticed upon shining a flash light at the 4" secondary it is covered with an opaque like blue tint . . and it helps to show up if the light is shined and an angle other than perpendicular to the mirror."
I think that observation might indicate a multilayer dielectric reflective coating. Do you know what the coatings are on the mirrors ?
Jason D
Reged: 10/21/06
Loc: California
      #5922624 - 06/15/13 05:55 PM
Rob,
What is your concern? Are you concerned you did not get your money's worth with your recent secondary mirror purchase or are you concerned about the view at the eyepiece?
Most of us will see unpleasant views when shining a light on our mirrors yet that has little to no impact on our views.
With all the discussion in the other thread about star testing, yesterday I took out my StarBlast 6" which I have not used for years and which I knew did not have perfect optics. The outer defocus star was sharp and bright. The inner defocus star was dim and mushy -- a classic case of bad SA. Yet, when I pointed it at Saturn, I did get a nice view of Cassini division. Using my experienced eye, I did see differences when compared the view to my 10" premium optics but only an experienced eye can see the differences I am referring to. The point here is even for a scope with terrible star test result good views are attainable.
Jason
robininni
Reged: 04/18/11
Re: What's on this secondary? new [Re: Jason D]
      #5922648 - 06/15/13 06:09 PM
Rob,
With all the discussion in the other thread about star testing...
Jason
Whoa. Just asking a question. I thought this was a place to learn. I have no ulterior motive with my question here. No need to second guess me.
Rob
GlennLeDrew
Reged: 06/18/08
      #5922710 - 06/15/13 07:04 PM
Might a careful cleaning reduce the scatter?
Upon further rummaging through the memory banks, I recall seeing a blue reflection from one or two mirrors in high end 2" star diagonals... It might have to do with the overcoating characteristics?
robininni
Reged: 04/18/11
      #5922827 - 06/15/13 08:43 PM
Glenn,
I cleaned the secondary in question with a distilled water/soap concoction (very little dish soap) and then rinsed with distilled water. It didn't go away. I then cleaned with acetone and it didn't go away (although I was able to remove some crud that was on the edge which was hiding under the lip of the secondary housing). I then tried denatured alcohol. I didn't removed the hazy look seen when using a flashlight which my new secondary, freshly coated, does not have.
So having an extremely clean secondary mirror out of the housing, I decided to aim the flashlight at the rear of it and this is what I saw:
You can see the shadow of the dew heater and and basically see through the entire secondary. The 'haze' is also visible.
I assume the 'haze' is actually the surface of the mirror under the coating and is somewhat visible because the coating is old, worn, and needs to be redone.
Is this a fair deduction for this discovery? Should a flashlight be able to penetrate through the coating from the rear of the mirror? I assume not, as this is how folks check for failing coatings so I read.
The only thing left to do is see if my flashlight will penetrate through my new secondary. I didn't do this yet because it is installed in my scope and I wanted to see if what I have posted here is enough for you to confirm my suspicions.
Rob
GlennLeDrew
Reged: 06/18/08
      #5922846 - 06/15/13 08:58 PM
A good look-see with an inexpensive (plastic) 30X pocket microscope might prove instructive. I *slightly* wonder now if the surface had been fully polished out. This is only a germ of a suspicion, but worth allaying (or confirming.) It would be surprising if the diagonal was passed with sufficient pitting to generate a fine haze, but you never know...
robininni
Reged: 04/18/11
      #5922858 - 06/15/13 09:10 PM
I took a couple more pictures. I wanted to get a close up to see the haze detail better. The square you see is the secondary string attachment Obsession puts on mirrors as a fail safe for it dropping from the UTA.
I did shine the same flashlight at the back of the newly coated primary and I see no light at all shining through. Granted, it is 2" thick but I think that doesn't matter since it is glass. I believe it is the coating only that stops the light.
Rob
Edited by robininni (06/15/13 09:15 PM)
Jason D
Reged: 10/21/06
Loc: California
      #5922909 - 06/15/13 09:54 PM
Rob
Rob, you missed my point. You are driving yourself crazy with questioning every imperfection. I would argue every scope and optics will have some sort of imperfection. Let the views at the eyepiece be your final judge. The example I described in my last post based on my first hand experience with imperfect optics and terrible star test result yet the scope gave pleasing views. Are you seeing bluish haze at the eyepiece? If not and the views are good then I suggest you do not touch your secondary mirror. The more you touch it the greater the chance for a scratch or a drop. It is your scope and it is your money and you are free to do whatever you want. I am just providing a friendly advice.
Jason
robininni
Reged: 04/18/11
      #5922945 - 06/15/13 10:15 PM
Rob
Jason
Jason,
My point is that this has nothing to do with views or using it. I am just asking, as a matter of fact, why this secondary reflects light this way. I assume you read my further down posts in this thread with more pictures showing substantial light shining through from the backside of the mirror. Should this happen or does this signify a mirror needing a new coating? You said I am driving myself crazy with every imperfection, but I would say a failed coating is something one might want to bother themselves with, don't you think?
While not directed totally at you, I get amazed (and frustrated) that there are so many seemingly 'experienced' people who post many replies to all sorts of threads with great authority here on CN, and yet it seems no one can answer my seemingly simple question (for an experienced person) about the shape of this secondary's coating.
I answered for myself why I see the haze shining the flashlight at the mirror face and as I now know it can be seen from shining a light through the rear of the mirror. Obviously, the coating is super thin as you can't see any light shining through the freshly recoated primary I just got back. So now I am just asking a simple question, that again, I would think a great multitude of you should be able to answer based on being experience with reflectors: Does this mirror need a new coating? Is this a sign of a coating past its prime or a coating that for whatever reason was too thin? Don't any of you know? Sorry to rant, but I just find the lack of concise answers ironic with so many authoritarian types on here.
Rob
Edited by robininni (06/15/13 10:27 PM)
Pinbout
Reged: 02/22/10
Loc: nj
      #5922960 - 06/15/13 10:31 PM Attachment (16 downloads)
most coatings will show ugly stuff, doesn't matter if its new, old, when you shine flash lights on them and especially from behind.
what you show is normal, so you can chillax.
GlennLeDrew
Reged: 06/18/08
      #5922964 - 06/15/13 10:35 PM
That last close-up shows a very large number of bright specks, more readily seen in the transition between bright and dark. I find that a tad concerning. It would be worthwhile to examine them under magnification, to settle the question of their being on the sure tests or in the coating. The more I look at these pics, the more inclined I am to think a re-coating is in order--as long as the mirror is pit-free, of course.
robininni
Reged: 04/18/11
Re: What's on this secondary? new [Re: Pinbout]
      #5922975 - 06/15/13 10:42 PM
Thanks for your input. Although I have bad news for you and your secondary. I just heard back from an optician (Lockwood) whom I emailed my same question to as I was not getting any conclusive answer on here, and he looked at the pictures and said the secondary needs recoating.
Rob
okieav8rModerator
I'd rather be flying!
Reged: 03/01/09
Loc: Oklahoma!
      #5922989 - 06/15/13 10:52 PM
Rob, I'm no mirror expert, and won't pretend to be, but I do know that the thickness of mirror coatings are on the molecular level, only a few angstroms thick, and that being able to see the light of a flashlight shined through the back of a telescope mirror is pretty common. One thing you'll read in articles about telescope mirrors and cleaning them is, don't shine a flashlight on the mirror, because it will look dirtier than it really is, and don't shine it on the mirror through the back, because you will likely be able to see through it. In other words, it will just cause undue worry.
I was reading an article awhile back about one of the big observatory mirrors, and it said that it took something like only a cubic centimeters worth of aluminum oxide to coat the entire mirror. I wish I could remember where I read it.
Pinbout
Reged: 02/22/10
Loc: nj
      #5923000 - 06/15/13 10:59 PM
don't hate the player, hate the game.
at $10 an inch to get it recoated, its not going to cost you that much. and are you going to get enhanced coatings, I've heard them fail quickly, and that will be more than $10 an inch for only a couple of percentages of reflectivity.
and if you have it recoated you can have it tested to make sure you got what you wanted in regards to surface spec.
a friend just recently told me his story about antres optical and how they state they can gives all these different wave specs but what he got wasn't close to his desired spec, but then he knows how to test it with his own 1/20~ flat.
robininni
Reged: 04/18/11
      #5923017 - 06/15/13 11:11 PM
Well, since I was investigating mirror coatings and I do have that brand new 4.5" secondary just back from OMI coating chamber (along with the 25" primary) I decide to get unlazy and take it off the Obsession and do the same flashlight test to show that light does not shine through a good coating.
I got a little surprise in that it has lots of pin pricks where light DOES shine through. However, it is otherwise totally opaque to light. By the way, I'm not using some dinky flashlight either. I'm using a 630 Lumen LED Fenix TK30.
So here's the pic of the new secondary with said flashlight shining at its rear:
For reference, here is the same treatment of the 4" secondary in question:
I guess I now have to ask (you knew I would), should the brand new coating have the pin pricks of light shining through? Well, actually I already did ask the optician again, and he said this is normal for a new coating and as it wears, it starts to appear like the 4" secondary coating... or worse with more time and depending on what it has been put through.
So, I hope these posts will help others who may ask the same questions I have when discovering similar things with their primaries or secondaries.
Rob
Edited by robininni (06/15/13 11:31 PM)
8 registered and 26 anonymous users are browsing this forum.
