shawnhar
Reged: 06/25/10
Loc: Knoxville, TN
Atlas/EQ6 Pier collision! Am I ok?
      #5921992 - 06/15/13 10:41 AM
Alarm did not go off, near as I can tell the OTA collided with the pier around 6:00am and continued to do so until 9:00am when I woke up in a panic.
The motors were pushing against an unmovable object for 3 hours.... My heart sank when I saw it. Batteries are dead so I can't try it out yet, will I be ok?
Reged: 07/06/07
Re: Atlas/EQ6 Pier collision! Am I ok? new [Re: shawnhar]
      #5921999 - 06/15/13 10:43 AM
You are likely fine. Stepper motors are pretty good about not burning out in conditions like these, and the clutches, even if tightened down firmly will usually prevent gear damage.
shawnhar
Reged: 06/25/10
Loc: Knoxville, TN
Re: Atlas/EQ6 Pier collision! Am I ok? new [Re: rmollise]
      #5922008 - 06/15/13 10:48 AM
Whew... Thanks Unk! That makes me feel much bettter. Pretty impressed with the strength of the motors, it bent the metal bracket that holds my diy electric focuser. That mount is a brute!
Reged: 07/06/07
      #5922031 - 06/15/13 10:56 AM
The only test, of course, is to fire it up and see what happens, of course. I am rooting for you.
EFT
Vendor - Deep Space Products
Reged: 05/07/07
Loc: Phoenix, AZ
      #5922215 - 06/15/13 12:40 PM
It's fairly difficult to do damage to the stepper mount gears so it's unlikely anything is a problem there. You will have to power up the mount to know whether and damage was done to the electronics or motors but even they are fairly tough.
shawnhar
Reged: 06/25/10
Loc: Knoxville, TN
Re: Atlas/EQ6 Pier collision! Am I ok? new [Re: EFT]
      #5922246 - 06/15/13 01:04 PM
Whoohoo!
Initial test indicates all is well, no weird sounds coming from the motors at least. Sure was scary though!
andysea
Reged: 09/03/10
Loc: Seattle, WA
      #5922301 - 06/15/13 01:31 PM
With my mount I don't tighten up the clutches too firm on purpose so that if something like this happens, I hope, It will help preventing damage. Do you guys ever do that?
EFT
Reged: 05/07/07
Loc: Phoenix, AZ
Re: Atlas/EQ6 Pier collision! Am I ok? new [Re: andysea]
      #5922389 - 06/15/13 02:30 PM
Most people actually overtighten the clutches on their mounts, particularly if they are unable to balance the mount well. In mounts like this that use ring gears, overtightening the clutch can actually deform the ring gear enough to cause error. The ideal tightness for clutches is enough to keep the axis from moving with a light tap but not so much that it will not move with a harder push (or a tripod collision).
23 registered and 39 anonymous users are browsing this forum.
