PhilCo126
Reged: 01/14/05
Loc: coastline of Belgium
CGE mount upgrade new
      #5923778 - 06/16/13 01:20 PM
Did You upgrade Your CGE mount with Marty cables, or Gary Bennett's kits, or did You perform the Hypertune service?
Which upgrade did You go for... and how did it turn out?
RA-DEC Cable Replacement Kit
and/or
Hand Controller / AUX1 / AUX2 (GPS)
and/or
PC Port / Guide Port / Power Supply
Alph
Reged: 11/23/06
Loc: Melmac
Re: CGE mount upgrade new [Re: PhilCo126]
      #5923839 - 06/16/13 02:01 PM
and/or
and/or
What are you up to? Can you be more specific? I made quite a few changes/upgrades to my CGE. I am too lazy though to list them all. The cables are the easiest to fix for next to nothing. The worm/worm gear upgrade did not turn out well and I had to revert to the original gears.
Wmacky
Reged: 11/24/07
Loc: Florida
Re: CGE mount upgrade new [Re: Alph]
      #5924061 - 06/16/13 04:29 PM
I took mine completely apart and re-greased everything. Its much smoother now. My only issue were the unfixable stuff. I find both ring gears to be really non concentric. (Gear mesh really tight at one point, and quite loose 180 degrees out.) Have you guy's seen the same?
mclewis1
Thread Killer
Reged: 02/25/06
Loc: New Brunswick, Canada
Re: CGE mount upgrade new [Re: Wmacky]
      #5924112 - 06/16/13 05:02 PM
Cables only at this point. Initially used the Marty cables, and only had two runaways in 3 years. Did Gary's RA/DEC cable upgrade as extra insurance two years ago when my CGE was pier mounted. The mount has been absolutely solid since.
Power has always been from a Pyramid -9KX (13.8v 5amp).
Considering a cleaning, re lube, adjustment, and rebuild session this winter.
Good rebuild instructions are now posted on the Yahoo CGE-TelescopesUNCENSORED group.
PhilCo126
Reged: 01/14/05
Re: CGE mount upgrade [Re: mclewis1]
      #5927388 - 06/18/13 12:02 PM
@ Alph ... I'm looking to purchase a CGE mount
So I'll have to look for a mount which has at least the RA/DEC upgrade:
http://www.bendun.net/CGE-UPGRADE-KITS.html
22 registered and 33 anonymous users are browsing this forum.
