Mr Greybush
Reged: 05/16/13
Loc: Virginia
accessories suggestion new
      #5926950 - 06/18/13 07:50 AM
after a several weeks of buying new/used equipment here is the list of equipment I have so far and I wanted to know from you all if there is anything I'm missing
Telescopes: 10 dob and 8"sct. both are motor driven
ep's: plossl 20,20,25 differnt manufactures, celestrons x-cel Lx 9mm,25mm and a x2 shorty barlow
power tank, moon filter, dew shields for both- dew heathers( kendrick straps and controler) finder scope 9x50, dot finder
red lens flashlight, atlas sky map, star wheel
covers for both bags for both tubes
full aperture solar filter for the cat not using it on the dob
tools dont' worry about those I have way to many
Dont add any ep suggestions from this list please I'm sure in time I'll have more
before I forget 10x50 binoculars (not using for solar)
Let the suggestions begin CHARGE!!!!
Edited by Mr Greybush (06/18/13 07:58 AM)
Stargaz18
Reged: 01/04/11
Loc: Wichita Falls, TX
Re: accessories suggestion new [Re: Mr Greybush]
      #5926956 - 06/18/13 07:53 AM
How about an observing chair?
Mr Greybush
Reged: 05/16/13
Loc: Virginia
Re: accessories suggestion new [Re: Stargaz18]
      #5926959 - 06/18/13 08:01 AM
Stargaz I'm thinking of building one
Ed D
Reged: 04/30/10
Loc: Sunny South Florida
      #5926961 - 06/18/13 08:03 AM
+1 - It's the most used piece of astro equipment I have, and the comfort allows me to observe much longer and see much more detail.
Ed D
You posted as I was typing my response. Don't forget to post pics of your project.
Ed D
Edited by Ed D (06/18/13 08:05 AM)
csrlice12
Reged: 05/22/12
Loc: Denver, CO
Re: accessories suggestion new [Re: Ed D]
      #5927024 - 06/18/13 08:40 AM
What do you have to keep those scopes collimated? Both the Dob and the SCT require collimation...
SeattleScott
Reged: 10/14/11
Re: accessories suggestion new [Re: csrlice12]
      #5927049 - 06/18/13 08:52 AM
Nebula filter, either UHC or OIII.
GalaxyCollide
Reged: 03/23/13
Loc: NY, Long island
Re: accessories suggestion new [Re: SeattleScott]
      #5927062 - 06/18/13 09:05 AM
How about a JMI Wheely Bars? They are good for moving scopes like the 10"
Mr Greybush
Reged: 05/16/13
Loc: Virginia
      #5927088 - 06/18/13 09:26 AM
Nebula filters I know nothing about. So help would be appreciated.
Mr Greybush
Reged: 05/16/13
Loc: Virginia
      #5927119 - 06/18/13 09:46 AM
I have a lazer for collimation for the dob. The SCT on the other hand that issue has to be delt with
Seldom
Reged: 08/05/12
Loc: N of Cedar City Light Dome
      #5927263 - 06/18/13 11:02 AM
UHC, OIII, Hydrogen Beta are nebula filters. Many nebulae fluoresce from UV light in adjacent stars. UHC and OIII both make such nebulas much better defined in the EP. The Lagoon,and the Trifid really benefit from either UHC or OIII. H Beta application is I believe limited to a few nebulae.
Good explanation of filters in The Backyard Astronomer's Guide.
csrlice12
Reged: 05/22/12
Loc: Denver, CO
Re: accessories suggestion new [Re: Seldom]
      #5927278 - 06/18/13 11:11 AM
If you are viewing from light polluted skies, the UHC helps. At dark sites, the OIII shows its stuff.....
jerwin
Reged: 05/17/12
Loc: Romeoville IL
      #5927502 - 06/18/13 01:04 PM
Personally I like a headlamp with a red light on it so I can use both hands and not have the red flashlight hanging out of my mouth.
I went with this one
http://www.amazon.com/gp/product/B0009HAHFW/ref=oh_details_o08_s01_i00?ie=UTF...
it's a little more expensive, but the red lens flips down, so I can't accidentally turn on the white light. I did slap a few layers of red tail light repair tape on it to dim it further, as sometimes they are just WAY too bright when someone else is talking to you or just looking around.
I don't know how bad the dew is in Virginia. In the Chicago area it's pretty bad on my SCT, but I don't know that I've ever dew'd my 10" dob up. Outside is dripping, but the mirrors are both good. I know you said you've already bought that but you might try without it on the dob and if you don't need it, you could get some money back.
Also on the dob you might have trouble aiming it, with a straight through finder, so finder with a 90 degree diagonal might prevent you from reenacting a scene from Dr. Strangelove. Or that in addition to a 90 diagonal a mounted laser pointer help get you close. http://www.scopestuff.com/ss_sfind.htm
A JMI motofocus might cut back on vibrations when adjusting the focus of the 8" SCT. I'm assuming it's a single arm which can get a little shaky.
Actually, thinking about this again, I think what you need the most is a membership to your local astronomy club, and then go to a dark site weekend. Most people are friendly enough and proud enough of their equipment to tell you what they like and don't like, what they wish they would have done, or what not. If they are friendly enough, I'd guess most would let you have a look through your own scope with their filter or eyepiece, but this does make some nervous.
My annual membership is $20 and I think it was the BEST $20 I've spent.
One warning though is don't look through an eyepiece that is outside of your price range. I looked at a ES82 degree, and started buying them over the next few weeks, then I looked in an ES100 degree, and sold most of my 82 degrees off.
Good luck and clear skies,
spencerj
Reged: 11/17/04
Loc: Londonderry, NH
      #5927634 - 06/18/13 02:15 PM
Time under the stars. You have more than enough equipment (besides a chair) to get started. Start using the stuff you have and find out what works for you. Find out what you like and don't like. Don't add additional equipment until a need arises.
yepimanerd
Reged: 06/10/12
Loc: Tomball, TX
Re: accessories suggestion new [Re: spencerj]
      #5927664 - 06/18/13 02:32 PM
I'd suggest ditching the red-dot finder for a telrad. Handiest $45 I've spent so far... If you get an extra base, you can use it with both scopes.
Seldom
Reged: 08/05/12
Re: accessories suggestion new [Re: yepimanerd]
      #5927684 - 06/18/13 02:49 PM
True, but you'll need to realign it when you switch scopes unless the bases are perfectly aligned.
Mr Greybush
Reged: 05/16/13
Loc: Virginia
      #5927731 - 06/18/13 03:09 PM
No no extra base for both the scope. I'm just most needed and most used items for now anything else can wait. I'm just trying to cover the bases
Mr Greybush
Reged: 05/16/13
Loc: Virginia
      #5927742 - 06/18/13 03:13 PM
telrad I'm not fond of. I've used them most of the time I forgot to turn it off lol
TexasRed
Reged: 05/17/11
Loc: East Texas
      #5927794 - 06/18/13 03:45 PM
+1 on the UHC filter.
kfiscus
Reged: 07/09/12
Loc: Albert Lea, MN, USA
Re: accessories suggestion [Re: TexasRed]
      #5927862 - 06/18/13 04:19 PM
Some sort of fold up table for all of your stuff to keep it out of the dew, dust, and from under foot.
Filters are a tremendous boost to my viewing. Don't rush off to buy them- they're worth their price and can be gotten in very good shape here and elsewhere used. Dig deeper in the forums here for good filter buying advice. We have David Knisely here and he is recognized as a filter tester extraordinaire.
Usquebae
Reged: 06/11/13
Loc: 43 N, 73 W
Re: accessories suggestion new [Re: kfiscus]
      #5928550 - 06/19/13 12:52 AM
Glenfiddich 12
11 registered and 29 anonymous users are browsing this forum.
Moderator:  zjc26138, WOBentley, kkokkolis
