blueman
Photon Catcher
Reged: 07/20/07
Loc: California
IC-1316b & NGC-6910 new
      #5927802 - 06/18/13 03:49 PM Attachment (10 downloads)
This is my last image for June. It is half of the Butterfly and NGC-6910 an open cluster in Cygnus.
( large 1/2 Scale) http://www.astrophotogallery.org/showfull.php?photo=11501
(smaller image) http://www.astrophotogallery.org/floyd-s-pics/p11501-ic-1316b-rgb.html
20 x 10 minutes each filter RGB
TEC-140@ f/5.4
ML8300 Astrodon Gen2 Filters
AP900 mount
WhistleStop
Reged: 09/07/07
Loc: Grafton, Ontario
Re: IC-1316b & NGC-6910 [Re: blueman]
      #5927948 - 06/18/13 05:11 PM
Nice image and framing...well done.
BTW what reducer do you use on the TEC140 for f5.4 ??
Lynn
blueman
Photon Catcher
Reged: 07/20/07
Loc: California
Re: IC-1316b & NGC-6910 new [Re: WhistleStop]
      #5928263 - 06/18/13 09:08 PM
Lynn
HI Lynn, Thank you.
I use an AP-27TVPH reducer with the TEC-140 and it works very well.
Blueman
WhistleStop
Reged: 09/07/07
Re: IC-1316b & NGC-6910 new [Re: blueman]
      #5928295 - 06/18/13 09:30 PM
Thanks Blueman...do you also need a field flattner ?
Cheers
Lynn
Edited by WhistleStop (06/18/13 09:31 PM)
blueman
Photon Catcher
Reged: 07/20/07
Loc: California
      #5928490 - 06/19/13 12:14 AM
Cheers
Lynn
Hi Lynn,
I have the TEC flattener but it is not used with the reducer. The AP reducer does flatten some as well as reduce. If my chip was larger then it would not fit the circle and I would have to use the TEC Flattener instead.
Blueman
WhistleStop
Reged: 09/07/07
      #5928502 - 06/19/13 12:22 AM
Thanks for the input.... I have the same camera, wheel and scope so hence the interest.
Cheers
Lynn
blueman
Photon Catcher
Reged: 07/20/07
Loc: California
      #5928542 - 06/19/13 12:47 AM
Cheers
Lynn
I have a picture of the complete setup. It used off the shelf parts and adapters, Starlight (feathertouch) provided the focuser to reducer adapter. Then I used other parts from AP as I recall and some shims from McMaster Carr to set the distance. But the photo is labeled with all the parts. Send me a PM if you need more information or I could post the photo here.
Blueman
blueman
Photon Catcher
Reged: 07/20/07
Loc: California
      #5929256 - 06/19/13 01:33 PM Attachment (4 downloads)
Cheers
Lynn
Blueman
Here is a photo of the setup. This should help visualize it.
Blueman
17 registered and 23 anonymous users are browsing this forum.
Moderator:  Oldfield, Scott in NC, bilgebay, WOBentley
