woolbrig
Reged: 02/01/13
Loc: Bethalto, Illinois
Guiding Issues
      #5929138 - 06/19/13 12:34 PM Attachment (28 downloads)
I'm still having problems when I try go guide.
My dec falls of the chart in PHD and I can't seem to get it to recover without stopping and restarting guiding. I've had this happen on both my attempts to guide
I've double checked by balance and it's real close.
I'm doing the All Star Polar Align
Guiding with an ST80 and the SSAG.
This is on a CGEM mount with a C9.25
Here is what my graph looks like. The jumps are where I stopped and started guiding again.
Any ideas what could be wrong?
Edited by woolbrig (06/19/13 12:38 PM)
woolbrig
Reged: 02/01/13
Re: Guiding Issues new [Re: woolbrig]
      #5929144 - 06/19/13 12:36 PM Attachment (16 downloads)
Here are my PHD Settings:
Mike7Mak
Reged: 12/07/11
Loc: New York
      #5929219 - 06/19/13 01:22 PM
Your 'Mx Dec' setting might be too low to overcome stiction/backlash in the dec axis. Increase it to 500 or even 1000 and see what happens. PHD only sends the correction pulse size needed so large set values don't really matter.
CounterWeight
Reged: 10/05/08
Loc: Palo alto, CA.
Re: Guiding Issues new [Re: Mike7Mak]
      #5929320 - 06/19/13 01:56 PM
Wow, that is pretty severe. looks like something is inhibiting the axis or the Dec guiding being stepped down or worse?.
My question is what does you calibration step(s) look like when you click the 'target' to start guiding. How many steps in each axis?
woolbrig
Reged: 02/01/13
Re: Guiding Issues new [Re: CounterWeight]
      #5929334 - 06/19/13 02:04 PM
I believe it took around 30 steps. to calibrate.
Madratter
Reged: 01/14/13
      #5929351 - 06/19/13 02:09 PM
Wow. That is a really bad graph. First, I suspect that you have your guide rate set to a low fraction of the sidereal rate, perhaps something like .25. For now, up that to 1x sidereal. That in combination with poor polar alignment and a small max declination setting is torching any chance of keeping up with the drift on the declination axis. Bump that max declination setting up to something like 1000. If that doesn't do it, bump it up even more. When you get this under control, you can start backing that max declination setting and tracking rate setting back down some.
Not the issue here, but I wouldn't run with the RA aggressiveness at 101. I would pull that back to something like 95 so you aren't overshooting and porpoising. There does look to be some of that going on in the graph on the RA axis.
Although they say you can use just about any star for ASPA, some are definitely better than others. You want something reasonably close to the Celestial Equator and reasonably near the Meridian. Currently Spica would be a good choice in the early evening.
Make sure when doing your ASPA that you either defocus the stars you use for alignment by a considerable amount or use an illuminated reticle eyepiece to do your initial alignment. Also make sure you do a full 2+4 initial alignment.
CounterWeight
Reged: 10/05/08
Loc: Palo alto, CA.
      #5929355 - 06/19/13 02:11 PM
Change that to where you are getting 12 to 16 steps, it will depend a little on where you are pointing your scope but that a good ballpark to try for.
jsines
Reged: 09/06/11
Loc: Berkley. Michigan
      #5929387 - 06/19/13 02:21 PM
Can you do this in the settings? I've just started autoguiding using PhD. I'm getting basically a flat graph, no problems from the start and nothing like the OP's graphs, but it's taking about 30 steps to calibrate. I'd like to shorten it to save on time if I could.
(sorry for the hijack)
woolbrig
Reged: 02/01/13
Re: Guiding Issues new [Re: Madratter]
      #5929396 - 06/19/13 02:24 PM
Is the guide rate you are referring to set on the hand controller? I see it listed as an option in the manual.
Madratter
Reged: 01/14/13
Re: Guiding Issues new [Re: jsines]
      #5929615 - 06/19/13 04:18 PM
Yes. Change your calibration step size. You can go much bigger than the default. Just make sure your step size is smaller than the # of seconds for your exposure (so if you expose for 4 seconds, you better not go above 4000ms). I do tend to expose for 4 seconds. I use a calibration step size of 2500ms with my 50mm guider.
Madratter
Reged: 01/14/13
      #5929616 - 06/19/13 04:19 PM
Yes it is. Or alternatively if you are running nexremote, you can change it in that as well (the value still gets stored in the controller).
CounterWeight
Reged: 10/05/08
Loc: Palo alto, CA.
      #5929626 - 06/19/13 04:24 PM
yes, increase or decrease the number in the 'calibration step' in the brain icon functions ( the settings table should look somewhat like in the graphic above). increasing the number should decrease the number of steps it requires in the calibration. Of course the right number is any that gives you round stars at your exposure length.
There is a second party guide to PHD here, that might be useful.
sparky123
Reged: 06/14/10
Loc: 41°N 96°W
      #5929669 - 06/19/13 04:51 PM
i battled PHD when i didnt have the most current MC firmware installed....my graphs were all over the place similar to yours. I upgraded MC and HC firmware and on my very next attempt i was guiding and taking 10 minute exposures with no streaking at all
Ron (Lubbock)
Reged: 08/17/12
Loc: West TX
Re: Guiding Issues new [Re: sparky123]
      #5930147 - 06/19/13 09:58 PM
What you appear to have is the "Dec. cogging" issue that plagues the CGEM. The characteristic sawtooth pattern is due to the Dec. motor ignoring small corrections from PhD. There is a bug in the motor control firmware that allows this problem to occur in the Dec. only. Celestron is working on a fix. Do a search on "CGEM motor cogging" on the mounts forum and you will find a long thread.
You can become a Celestron beta-tester and download a new version of the motor control firmware from the Celestron beta tester website (teamcelestron.com). Versions 31.15 and higher of the motor control firmware will eliminate the sawtooth. The bad news is that you will likely have to buy a couple of cables that run about $45 to update the software through the hand controller. I had the sawtooth problem as well, and it's gone now that I upgraded the MC firmware.
In the mean time, work on improving your polar alignment technique. With near-perfect polar alignment, the sawtooth will almost disappear. Also increase Max. Dec. to 1600 until you can upgrade the firmware. I recommend looking up drift alignment if you don't already know it. It's a good method to check if you did the All-Star correctly or not. I usually need to drift align even after All-Star. In order to get a sawtooth as bad as you are showing, polar alignment must have been off by quite a bit.
Good luck!
Raginar
Reged: 10/19/10
Loc: Rapid CIty, SD
Re: Guiding Issues new [Re: Ron (Lubbock)]
      #5930240 - 06/19/13 10:42 PM
Change your guide rate in the HC to 1.0x. Then, change your mx Dec to something high.. like 1-1500ms. Make sure your declination is balanced perfectly, cables attached, everything where it is gonna be when you image...
Finally, I was never happy with my CGEM and heavy weight. It performed really well when I got it below about <25#.
If you go to Craig Stark's website, go to his FAQ section. There is a tutorial in there called 'PHD for dummies' or something like that. Kind of explains everything.
Good luck!
Ron (Lubbock)
Reged: 08/17/12
Loc: West TX
Re: Guiding Issues new [Re: Raginar]
      #5930359 - 06/19/13 11:41 PM
I take it you got rid of your CGEM, Raginar? The Dec. cogging fix was just done about a month ago, and they suddenly work a lot better for guiding. I don't know about 25 pounds plus load though- I think my imaging train is like 24 pounds.
woolbrig
Reged: 02/01/13
      #5930816 - 06/20/13 08:48 AM
Thanks for all the great info! I'll try some of the settings tonight if it stays clear.
Sounds like I need to try the firmware upgrade too. I already have the cables necessary for the upgrade. I'll check into that after I get the settings a little closer.
My plan is to get an Sky-Watcher 80ed or 100ed for most of my imaging. That will make the load for the CGEM much lighter than it is now.
Raginar
Reged: 10/19/10
Loc: Rapid CIty, SD
      #5930920 - 06/20/13 09:41 AM
Ron,
Yea, I don't have a CGEM anymore. That's interesting that the fix is done. Is it out of beta testing? Either way, what he is seeing is more than just cogging. I never had it that bad, even when I was near 37#.
Joe,
Try a focal reducer to reduce your focal length and make things easy too. Alternatively, you could get a mini-guider setup. There are numerous examples of them working C9.25s on Astrobin. I had great success with my C5/mini-guider on a CGEM. I think an ED80 would work good too .
Edited by Raginar (06/20/13 09:44 AM)
Madratter
Reged: 01/14/13
      #5931094 - 06/20/13 11:13 AM
That sawtooth pattern was actually caused by him stopping and restarting guiding as stated in the original post.
CounterWeight
Reged: 10/05/08
Loc: Palo alto, CA.
      #5931180 - 06/20/13 12:10 PM
I think this can be an area of frustration. Guiding issues and then needing clear skies to try out remedy. IMO the good news is that you just need to learn your mount and guider setup one time 'all the way'. What matters where and how, and what the mount can do on a good night. The list of what can go wrong and how is huge, and if you are setting up from scratch each time there is that always possibility of human error(s) and batteries wearing out or connex wearing or cable issues. Patience and tenacity will win the day, this is the time in the saddle part where it starts getting clear all you don't know for certain. We all go through this with our gear and consider it one of those rights of passage.
17 registered and 21 anonymous users are browsing this forum.
Moderator:  Knuklhdastrnmr, fishonkevin, WOBentley, rflinn68
