Jmax
Reged: 09/28/10
Loc: Alabama
Anyone Use a Dehumidifier
      #5929553 - 06/19/13 03:42 PM
I have posted about my leaky Skyshed POD in the past. Well, after trying literally everything that has been suggested, I still have slight leaks at the pivot points. Only one is really bad. If it is just a normal rain, even if it is extended, there really isn't a problem. But who has normal rains in Alabama? We get downpours. After a downpour, the water forms a little puddle around the side of the wall where the problematic pivot point is. Also, if it is a real "flood" there appears to be some seepage from underneath the dome. It is on a concrete slab with sealant all the way around both the inside and outside bottom. I really don't know if it is seepage or just from the leak. Anyway, I have put a small fan inside and aimed to blow out the natural vent area under the dome. This pretty much dries things out in about a day or so. We had downpours yesterday and my puddle was there last night, but it is completely gone today. I am thinking about getting a continuous draining dehumidifier to keep inside the POD and was wondering if anybody here uses one and does it help?
MRNUTTY
Reged: 11/22/11
Loc: Mendon, MA
Re: Anyone Use a Dehumidifier new [Re: Jmax]
      #5929695 - 06/19/13 05:05 PM
Good question John, When I had chronic freeze-up with one of the AC units in the house, I would use a dehumidifier to sop up the water and dry out the concrete floor. I was thinking of putting one in my observatory; free-running, with the exhaust water draining outside into a french drain in the yard. This would keep the equipment dry. Unfortunately, it's so hard to find a quiet dehumidifier.
CharlesW
Reged: 11/02/12
Loc: Chula Vista & Indio, CA
Re: Anyone Use a Dehumidifier new [Re: MRNUTTY]
      #5930352 - 06/19/13 11:37 PM
This is a little off your direct question but if you're getting a lot of rain but not much wind, could you place a patio umbrella over the area of your obs that's getting pounded? It might help direct the deluge away.
Magellan
Reged: 01/26/06
Loc: Enfield, NS Canada
Re: Anyone Use a Dehumidifier new [Re: CharlesW]
      #5930791 - 06/20/13 08:32 AM
No, I wouldn't it would never stop running. I had the same issue. Except I also have snow issues up north but we also get hurricanes and pounding rains.
I wouldn't do this everytime in your climate only when its going to rain but I use backing rod, very similar to http://www.rona.ca/en/expanding-sealant-tape but I don't think it expands, I use to to winterize each year and helps with rain. You stuff it up the open part of the dome, but don't leave them there in the sun, its better to have the air circulation.
Jmax
Reged: 09/28/10
Loc: Alabama
Gonna Try It new [Re: Jmax]
      #5932733 - 06/21/13 10:10 AM
Well, I found a reconditioned 30 pint model on Ebay and made an offer. I got it, so I am going to try it. I've read elsewhere that others successfully use dehumidifiers in their PODs. This one has the benefit of being programmable so that I can have it cut on and off in two hour or four hour increments. I'll get it and try it for awhile and then report on how well it is doing, if folks are interested.
John
Magellan
Reged: 01/26/06
Re: Gonna Try It new [Re: Jmax]
      #5932915 - 06/21/13 12:27 PM
I am interested in this too as well. Once I get my pod on the deck I might look into it if it works. How many amps would one of those use?
Jmax
Reged: 09/28/10
Loc: Alabama
Re: Gonna Try It new [Re: Magellan]
      #5932931 - 06/21/13 12:40 PM
The one I got is small. It is rated at 405 watts and draws 3.8 amperes at 115 volts. I only plan to run it when rain is expected.
Magellan
Reged: 01/26/06
      #5933017 - 06/21/13 01:39 PM
Not bad.. I am using a 15 amp breaker. Shouldn't be an issue then. Are you planning on running the drain outside? I think some allow for this. I would drill a hole down or you can simply use the crack on the bottom of the door if its small enough.
Jmax
Reged: 09/28/10
Loc: Alabama
      #5933582 - 06/21/13 07:40 PM
I'm gonna try to run the hose out the bottom of the door, to begin with at least. Mine has a pretty big gap there, and the dehumidifier attaches to a standard garden hose, so it should be pretty easy. I may drill a hole in the back of the POD base in the future, but I really hate to. The floor is out, because I didn't allow for a drain when the concrete was poured. The dehumidifier should be here next week, so I'll keep you posted.
wolfman_4_ever
Reged: 07/15/11
Loc: El Segundo, Ca, So. Cal
      #5933910 - 06/21/13 11:21 PM
Yes, I run a dehumidifier in my pod as well as an AC unit. I go out the door with the hose but also have a hole drilled in a bay. And another hole for the AC exhaust.
mark379
Reged: 02/07/09
Loc: New Jersey
Re: Gonna Try It new [Re: wolfman_4_ever]
      #5945587 - 06/28/13 09:03 PM
Does anyone have pictures of their dehumidifier setup?
Hoe successful are they?
wolfman_4_ever
Reged: 07/15/11
Re: Gonna Try It new [Re: mark379]
      #5947214 - 06/29/13 09:39 PM
AC off since I have no equipment in the pod at the moment. Waiting on my AP1600.
Graph on the lower left is last 24hr of humidity. Last night and early AM humidity was in the 90%+ range. Inside pod stays at 40% or lower humidity level.
mark379
Reged: 02/07/09
Loc: New Jersey
      #5947260 - 06/29/13 10:17 PM
Excellent! How much do these units usually cost?
Enough to keep the inside of a sct moisture free?
wolfman_4_ever
Reged: 07/15/11
      #5947311 - 06/29/13 11:13 PM
$100-$200 depending on capacity and brand. Make sure it has a hose hook up.
When the dome is closed, yes. Once the dome is opened, all bets are off.
Edited by wolfman_4_ever (06/29/13 11:28 PM)
csa/montana
Den Mama
Reged: 05/14/05
Loc: montana
      #5947314 - 06/29/13 11:16 PM
Yes, otherwise one will be emptying a very full pan.
Jmax
Reged: 09/28/10
Loc: Alabama
Tentative Results new [Re: Jmax]
      #5947408 - 06/30/13 12:49 AM
It's been running now since Tuesday, and the results so far are excellent. Humidity here has been 80-90 and with it set for 50, the pod is staying between 40-50. It runs only maybe half the time. There hasn't been any major rain though. So far I haven't hooked up a hose because I'm using the collected water to water potted plants. I do have to empty it daily. For the one who asked about a pic, you can follow the link to my observatory site in my post about it being operational. You can see the dehumidifier in the pics of my equipment.
wolfman_4_ever
Reged: 07/15/11
Re: Tentative Results new [Re: Jmax]
      #5947470 - 06/30/13 02:33 AM
Now that you have reduced your chance for mold and rust, next on the list will be an AC unit.. Then you never have to wait for a scope to cool down!
mark379
Reged: 02/07/09
Loc: New Jersey
Re: Tentative Results new [Re: wolfman_4_ever]
      #5948231 - 06/30/13 03:22 PM
Excellent idea! Thank you!
wolfman_4_ever
Reged: 07/15/11
Re: Anyone Use a Dehumidifier new [Re: mark379]
      #5948285 - 06/30/13 04:09 PM
Hey Mark
I recommend one of the new AC units coming out from climate right air.
www.climaterightair.com
I'm waiting for the 8000btu version (can use unit for other uses/locations) but the 5000 should work great in the POD.
14 registered and 12 anonymous users are browsing this forum.
Moderator:  Christopher Erickson
