dragonslayer1
Reged: 02/25/12
Loc: SLC, UT
polar orfice 90* to scope?
      #5937764 - 06/24/13 10:45 AM
I have a CG-5 ASGT and was just checking the polar align on it. The question I have is that when polar scope tube is aligned for scope the mount for OTA is sitting 90* off from being in same alignment as polar scope would be? Is this normal? will try to attatch a picture, thank you
Kasey
DaveJ
Reged: 01/07/05
Loc: NE Ohio
Re: polar orfice 90* to scope? new [Re: dragonslayer1]
      #5937851 - 06/24/13 11:42 AM
Yup. Perfectly normal. All German equatorial mounts seem to be this way - at least the ones with polar finder capability. My old LXD650 and Losmandy G-11, my current CGE and CGEM DX are that way, too. Why? No idea!
Edit: Oops! My bad. The CGE is NOT polar finder capable and, hence, does NOT have the bore-hole.
Edited by DaveJ (06/24/13 11:44 AM)
jrcrillyAdministrator
Refractor wienie no more
Reged: 04/30/03
Loc: NE Ohio
Re: polar orfice 90* to scope? new [Re: DaveJ]
      #5937883 - 06/24/13 11:55 AM
Why? No idea!
That arrangement was adopted in pre-SCT days so everyone had long optical tubes. Picture trying to get to the polar scope with a long refractor in the way...
dragonslayer1
Reged: 02/25/12
Loc: SLC, UT
Re: polar orfice 90* to scope? new [Re: jrcrilly]
      #5937912 - 06/24/13 12:09 PM
I see, just wondered if my mount was assembled wrong ,, The long scope is a good explination thank you, Kasey
mclewis1
Thread Killer
Reged: 02/25/06
Loc: New Brunswick, Canada
      #5938088 - 06/24/13 02:05 PM
Dave, Actually there is/was a polar scope for the CGE. You're right there's no bore-hole but this polar scope fits on the outside. It was never a very popular option and is now completely unnecessary with the All Star polar alignment routine in the hand controller.
EFT
Vendor - Deep Space Products
Reged: 05/07/07
Loc: Phoenix, AZ
      #5939440 - 06/25/13 10:17 AM
The reason for this is actually so that you can rotate the RA axis to get the polar scope in the correct position without the OTA hitting the tripod. If the OTA is located parallel to the RA housing, then you can only rotate the RA to about 30 degrees below the horizontal position without contacting the tripod (further if you have a pier). If you have a rotating polar scope this is not an issue, but most polar scopes do not rotate without loosening them and then loosing their alignment. Thus, you turn the OTA 90 degrees so that in most cases you can rotate the RA and polar scope 360 degrees.
dragonslayer1
Reged: 02/25/12
Loc: SLC, UT
Re: polar orfice 90* to scope? new [Re: EFT]
      #5939587 - 06/25/13 11:46 AM
Yep got it now , am using a C9.25 on mine so length of scope never entered my mind,,, It just looked wierd, seemd to be at odds with one would think it should look like So much for thinking, LOL
Kasey
23 registered and 51 anonymous users are browsing this forum.
