orlyandico
Reged: 08/10/09
Loc: Singapore
DIY tripod levelers
      #5941321 - 06/26/13 11:51 AM
I'm racking my brain trying to figure out how to produce tripod levelers for the usual 2" tripods.
I know TPI Astro sells some, but they are $350.
Teleskop Express sells a set made by Geoptik which is 160 EUR. Cheaper.
Levelers are a $200 option on Rob Miller's tripods, but one can't buy RM stuff right now.
Has anyone solved this problem? preferably cheaply?
gfeulner
Reged: 11/23/07
Loc: Bergen county, New Jersey
Re: DIY tripod levelers new [Re: orlyandico]
      #5941374 - 06/26/13 12:39 PM
http://www.alliance-express.com/tilting-adjustable-feet- you could try these. Also there was an article posted I believe on CN awhile back that showed how to make them using bolts, washers and rubber leg attachments used on furniture. Unfortunately I don't seem to be able to find it. Maybe another poster can help with that. I made mine using this method and it works fine Gerry.
hottr6
Reged: 06/28/09
      #5941391 - 06/26/13 12:50 PM
Probably not what you want to hear, but one approach would be to place the tripod on a buggy, and put the levelers on the buggy. A battery-operated drill can assist in lifting and lowering.
orlyandico
Reged: 08/10/09
Loc: Singapore
Re: DIY tripod levelers new [Re: hottr6]
      #5942562 - 06/27/13 06:06 AM
In order to use those leveling feet, I'll need threaded tube plugs. The OD of the Celestron Ultima lower leg is 35.xx millimeters, which is a non-standard size, so I can't find threaded tube plugs for it...
Looks like the simplest solution is to make a wooden platform which has levelers on it, then mount the tripod on top.
Mike E.
Reged: 01/26/10
Loc: Moonstone Observatory
      #5943396 - 06/27/13 04:35 PM
Consider buying several C-clamps, cutting off the lower part of the clamp, grinding or filing to shape as necessary, and drilling a hole in the side to bolt to your tripod feet; as with the TPI type.
n1wvet
Reged: 04/22/11
Loc: Northern Virginia, USA, Earth
Re: DIY tripod levelers new [Re: Mike E.]
      #5944039 - 06/27/13 11:53 PM Attachment (16 downloads)
I assembled a triangle leveler that fits under the SCT base. This is for visual use only. Material is 1" steel square tube stock and hardware is Stainless Steel. Leveling is now fast and easy with the knurled knobs and independent of the tripod.
orlyandico
Reged: 08/10/09
Loc: Singapore
Re: DIY tripod levelers new [Re: n1wvet]
      #5944069 - 06/28/13 12:18 AM
I did buy C clamps because they're cheaper than those industrial levelers. But I have no idea how to bolt them to my tripod legs.
17 registered and 32 anonymous users are browsing this forum.
