Pages: 1 | 2 | 3 | (show all)
careysub
Reged: 02/18/11
Loc: Rancho Cucamonga, CA
Instrumenting a Dob with Temperature Probes
      #5942106 - 06/26/13 08:50 PM
The "visualizing airflow" thread got me to thinking about collecting data directly from Dobs about how temperatures are distributed internally and externally.
What you would like is a temperature readout mounted on the scope that can switch among at least three probes, and have the whole kit and caboodle neither weigh nor cost very much. One probe attached to the mirror and two for air temperatures at different locations (which could be moved around to investigate air flow) wouls be the minimum set up for collecting data.
I am not an electronics hobbyist and do not have a ready knowledge base of what is available these days for putting something like this together. A little Googling for kits, or ready-built monitors, turned up little or nothing for the first, and systems costing hundreds of dollars for the second.
The absolute temperature precision is not as important as accurately measuring the differentials between the probes. A low incremental per-probe cost would be good.
Any suggestions?
richard7Moderator
Not Quite
Reged: 11/02/07
Loc: Sacramento
Re: Instrumenting a Dob with Temperature Probes new [Re: careysub]
      #5942143 - 06/26/13 09:13 PM
1. Circuit Specialists.
2. Trailtech.
Or if you're up to some diy. Electronics DIY.
Meep_Esq
Reged: 01/02/07
Loc: Dunedin, New Zealand
      #5942144 - 06/26/13 09:13 PM
y'know I'm sure I read a website where a chappy found a cheap garden thermometer that had an inside and outside temperature probe which he used to compare tube temp with ambient.
highertheflyer
Reged: 07/08/05
Loc: Ft. Worth, Texas
Re: Instrumenting a Dob with Temperature Probes new [Re: Meep_Esq]
      #5942248 - 06/26/13 10:29 PM
Each of the home made reflectors here is equipped with this very simple setup and fun to monitor.
It's pretty easy to find small indoor/outdoor digital thermometers for this use.
With one registering in the cooling fan flow, and one attached/buried/surface glued against the back of the mirror.
The mirror monitor probe should be encased in a cotton lined plastic housing to insulate the mirror temp probe from the outside temperature affects.
careysub
Reged: 02/18/11
Re: Instrumenting a Dob with Temperature Probes new [Re: richard7]
      #5942451 - 06/27/13 02:34 AM
Thanks, this is exactly what I was looking for.
The first site has several interesting solutions.
Simply buying several of these LCD temp units (http://www.circuitspecialists.com/dtm0503.html), and making a simple switching mechanism to connect to different probes (patch panel maybe?) would be an inexpensive solution for a non-electronically adept individual.
(I build computers from parts, but have never become familiar with building circuits which requires considerably more expertise.)
don clement
Vendor (Clement Focuser)
Reged: 02/02/11
Loc: Running Springs, California
      #5942454 - 06/27/13 02:43 AM
I would suggest using an inexpensive temperature sensor such as the LM35 http://www.ti.com/lit/ds/symlink/lm35.pdf. Band gap temperature sensors such as the LM35 don't require much signal conditioning and have a linear voltage output proportional to temperature that can be read by a voltmeter. There are probably inexpensive temperature USB modules that would make it easy to collect data with a laptop PC and if one had Labview http://www.ni.com/labview/ would be, for me, really easy and quick to put a program together to collect and analyze the results.
Don Clement
derangedhermit
Reged: 10/07/09
Loc: USA
      #5942472 - 06/27/13 03:04 AM
That looks like one complete unit - temp probe and display. Buy as many as you need - I'm not sure what the patch panel would be for.
It doesn't give accuracy or precision, though, that I could find. It may not do better than 1 degC.
I'd like to do the same thing you're asking about - I want better than 1F accuracy.
don clement
Reged: 02/02/11
Re: Instrumenting a Dob with Temperature Probes new [Re: derangedhermit]
      #5942515 - 06/27/13 04:20 AM
Since we are looking for differential measurements wouldn't it be resolution less than a degree and not accuracy or precision? Also linearity.
Don Clement
freestar8n
Reged: 10/12/07
Re: Instrumenting a Dob with Temperature Probes new [Re: don clement]
      #5942535 - 06/27/13 05:08 AM
Here is my write up of measuring temperature at various points in an SCT exposed to the sky:
SCT Temperature measurements.
I used ds1820's and custom code in a microcontroller. These devices are simple and serially addressable individually - so you can have as many as you want on a single two-wire connection. The temperature precision and accuracy were adequate for this study - and could be improved by calibrating them carefully.
A key issue in studies like these is the actual thermal/radiative environment where the 'scope is used. The cooling behavior in a wide open field with very clear skies would be very different from a tree-shaded area, or in an observatory dome. The radiative losses don't just happen on the front lens, but on the entire system including the mount.
Frank
careysub
Reged: 02/18/11
      #5942707 - 06/27/13 09:11 AM
That looks like one complete unit - temp probe and display. Buy as many as you need - I'm not sure what the patch panel would be for.o do the same thing you're asking about - I want better than 1F accuracy.
To just have one readout mounted on the scope for multiple probes, not a whole collection of them. Yes, it would involve chopping off the probes and ending up with surplus LCD panels, but they are cheap.
Getting two units would allow direct comparison for consistency between the units - much more important than absolute accuracy since it is really the temperature differentials we are interested in.
careysub
Reged: 02/18/11
      #5942716 - 06/27/13 09:16 AM
Don Clement
Precision, but not accuracy (the absolute temperatures are really not of interest).
The LCD units I was looking at actually read-out to 0.1F, but testing would be required to show how reproducible the measurements are between units.
careysub
Reged: 02/18/11
      #5942765 - 06/27/13 09:42 AM
Don Clement
Thanks, this the sensor you recommend looks like a very good candidate for the sort of low cost of entry monitoring.
With the 0C + 10 mV per C output I would just need a millivolt meter reading to 400 mV or so (to reach 40 C, as high as I would be likely to ever measure). Unfortunately I note that inexpensive ubiquitous digital LCD panel voltmeters seem to be limited to 200 mV (must be a widely used chip spec).
For a really serious monitoring approach a digital system would clearly be best, but the total "cost of entry" (money plus learning time) is higher.
Would the trial version of Labview work? Otherwise a license is $999, a non-starter unless I was getting into really serious data collection for other projects.
don clement
Reged: 02/02/11
      #5942825 - 06/27/13 10:16 AM
Carry,
I mentioned the LM 35, http://www.amazon.com/microtivity-Precision-Centigrade-Temperature-Sensor/dp/... an analog temperature sensor that has a linear output of 10mV/*C . The LM35 is pretty easy to set up, even for the electronics challenged. All you need is an unregulated DC voltage source of 4V to 20V and a way to read the analog output voltage. A 9V battery would do fine. An inexpensive digital voltmeter can be used for readout such as http://www.harborfreight.com/7-function-multimeter-98025.html A simple analog switch would be used between sensors. Since you are interested in differences between sensors, the analog switch allows the same DAC (the digital voltmeter) to be used for all sensors. I believe this scheme has the simplicity, precision, and resolution you are looking for.
Don Clement
Pinbout
Reged: 02/22/10
Loc: nj
Re: Instrumenting a Dob with Temperature Probes [Re: careysub]
      #5942848 - 06/27/13 10:31 AM
on the spec sheet it states if there is a high difference in air temp and surface temp you have to epoxy the leads to the surface so the device won't read air temp.
also there is a way to turn it to F. they show a circuit for the change on the spec sheet.
careysub
Reged: 02/18/11
      #5943375 - 06/27/13 04:21 PM
I think this slightly more expensive multimeter from HF would be needed:
http://www.harborfreight.com/ac-dc-digital-multimeter-37772.html
It gives (says the manual) 0.1 mV accuracy in the 200 mV range (20C/68F) but is still 1 mV in the 2000 mV range (+/- 0.1C, taking the temp up the maximum of interest).
The 7-function one lists 1% accuracy in the 2000 mV range (i.e. 20 mV or 2C, or maybe 40 mV/4C).
Arjan
Reged: 01/21/09
Loc: Netherlands
Re: Instrumenting a Dob with Temperature Probes new [Re: Pinbout]
      #5943384 - 06/27/13 04:27 PM
Who would want this?
Pinbout
Reged: 02/22/10
Loc: nj
      #5943388 - 06/27/13 04:28 PM
couldn't you just shoot the mirror with IR thermometer that way you can measure the edge, the back middle, front middle... +/-2, do you really need to read more?
Pinbout
Reged: 02/22/10
Loc: nj
Re: Instrumenting a Dob with Temperature Probes new [Re: Arjan]
      #5943389 - 06/27/13 04:31 PM
you know who else would like to do that...My Mom
don clement
Reged: 02/02/11
      #5943454 - 06/27/13 05:11 PM
Carry,
There is always the old standard (and still is)HP3458 8.5 digit DMM.
http://www.youtube.com/watch?v=yBb24pCUDpk
When I was a teenager I built a Heathkit IM13 VTVM
http://www.ohio.edu/people/postr/bapix/vtvms.htm
Don Clement
careysub
Reged: 02/18/11
      #5943735 - 06/27/13 08:09 PM
You can do the back and side of the mirror with an IR thermometer, but you can't do the front unless you put an opaque patch on the mirror surface, and you can't take air temperatures. A patch stuck temporarily in the Newtonian central "blind spot" woud be an option for getting mirror front surface temperatures.
Putting a probe on the mirror front surface as similar issues - probe covered with a bit of foam or cork help down by a clip.
Consider the back exhaust fan in a closed mirror box with a front baffle, which has been recommended for all night cooling (ensuring mirror tracks ambient air, scrubbing boundary layers, preventing dew formation, etc.).
In a closed box taking IR measurements is difficult anyway, but we want to track the air flow, using the air temperature as a proxy, and a physical feature of primary interest which the IR thermometer cannot easily measure. A temperature probe above and outside of the mirror box gives ambient, a probe just inside the baffle where the air flows off the mirror surface, an insulated probe on the top side edge and on the center back of the mirror, and perhaps one just in front of the exhaust fan could give a pretty good view of the air circulation and cooling/warming that is going on.
16 registered and 37 anonymous users are browsing this forum.
