amicus sidera
Reged: 10/14/11
Loc: East of the Sun, West of the M...
3-D printers: getting cheaper now... new
      #5937724 - 06/24/13 10:22 AM
Interesting article from Arstechnica.com regarding the continuing drop in the cost of 3-D printers:
Why basic 3-D printers are crazy cheap right now
I can see this being a boon to ATM'ers; while certainly not taking the place of the big stuff, such as mirror grinding and the machining of metal parts, lots of neat little appurtenances can be made to finish off an instrument via this method. Additionally, those attempting to restore classic telescopes to their original appearance can make up identical-looking parts for their projects without necessarily having to resort to metal-casting or machining, provided the plastic parts retained sufficient strength for the particular application. Libraries of part specifications for printing could be created and stored online, and a useful part that one ATM designs can be easily duplicated by others.
Fred
BoriSpider
Reged: 08/10/04
Loc: S.W.FLA
Re: 3-D printers: getting cheaper now... new [Re: amicus sidera]
      #5937943 - 06/24/13 12:34 PM
Yes they are dropping in price. I believe there is/will be
a kit for like $299.00 by PrintRbot called "Simple". It's
a little itty-bitty thing that you can use to print parts
for a larger printer. Then cannibalize the parts from the
"Simple" kit to make the larger printer.
Someone is working on a Mirror-Grinding Machine as we speak.
BoriSpider
Reged: 08/10/04
Loc: S.W.FLA
Re: 3-D printers: getting cheaper now... new [Re: BoriSpider]
      #5937945 - 06/24/13 12:35 PM
lol. Now that I look at the article they mentioned the "Simple" I was talking about.
don clement
Vendor (Clement Focuser)
Reged: 02/02/11
Loc: Running Springs, California
      #5939470 - 06/25/13 10:36 AM
http://www.industrytap.com/the-printer-that-can-print-a-house-in-20-hours/905...
BoriSpider
Reged: 08/10/04
Loc: S.W.FLA
Re: 3-D printers: getting cheaper now... new [Re: don clement]
      #5941785 - 06/26/13 05:19 PM
Now MS Win8.1 is jumping on the bandwagon.
BoriSpider
Reged: 08/10/04
Loc: S.W.FLA
Re: 3-D printers: getting cheaper now... [Re: BoriSpider]
      #5943554 - 06/27/13 06:10 PM
So the mUVe , a UV resin based 3d printer, was a successful KickStarter
that was fully backed and shipped. Now they have released
the documentation so you can build one yourself.
It's open source so hack-away. I don't know what the properties
are of resin plastics compared to the plastic I print
with but the detail should be much better on this one.
BoriSpider
Reged: 08/10/04
Loc: S.W.FLA
      #5946178 - 06/29/13 09:17 AM
Here is a video explaining how MS will support 3d printing.
AlphaGJohn
Reged: 06/12/13
Loc: Wasatch Front, Utah
      #5959825 - 07/07/13 11:31 PM
I had a perfect application for 3D printing: an adapter base for the AT Multi-reticle finder to attach to my Vixen-type finder holder on the refractor's focuser. There were none of the adapters available at any of the retail sites I checked. There was some info suggesting that future availability was uncertain too.
If I'd had a way to print it out, I'd have been set. This is a low stress part that does not have to be particularly precise (the adjustment is on the finder itself)--it just has to be rigid enough to keep the finder parallel to the optical train in multiple orientations (I have a GEM so this involves a pretty broad range of orientations), allow the laser-reticle finder to attach firmly to it, and attach firmly to the receiver on the scope itself. The real thing is aluminum, but a good hard plastic should be able to do that--let alone a UV-cured resin (which would presumably be tougher). Amazing stuff happening.
I did find a conventional adapter through the classifieds here on CN (very happy about that). If anyone into 3D printing wants the measurements, let me know--I think there's others who'd be glad to use the AT Multi-reticle finder if they had an adapter available.
John
Chriske
Kijkerbouw Urania
Reged: 08/15/04
Loc: Boechout, Belgium
      #5960026 - 07/08/13 04:59 AM
Hi guys,
We use (casted) resin for telescopeparts for nearly 10 years now. The only drawback resin has no 'memory'. For a few parts in our telescope setup it really is necessary. We've printed the same telescope part using ABS and the result was far better.
Compared with a printed part quality of a casted part is far better(not strength, that we don't know yet). A casted resin part is actually so good that a untrained eye cannot tell which one the original or the copy is..!
Let's hope quality of the 3D printers will improve soon.
On the other hand, if the quality of 3D printed objects will improve it will be the end of an area in our community...Pitty...!
Chris
BoriSpider
Reged: 08/10/04
Loc: S.W.FLA
Re: 3-D printers: getting cheaper now... new [Re: Chriske]
      #5960359 - 07/08/13 11:25 AM
AlphaGJohn: Are you talking about this type of finder and mounting rail?
Is the Mounting Rail the part you are talking about?
And is this for your 102GT?
AlphaGJohn
Reged: 06/12/13
      #5961040 - 07/08/13 06:39 PM
Maybe should take this to another thread, BoriSpider, but yes, it looks like that would have been just the ticket.
[Edit: On further review, no I don't think the OPT version would have fit my (I think--scope was 2nd hand) upgraded focuser's receiver . In fact the dovetail is substantially wider than the mentioned 5/8": the narrow part is 20mm, wide part 30mm. It fits into the focuser receiver with about 3mm of extra space when the locking screw is tightened up. Maybe I'm misunderstanding the measurements of the dovetail on the unit you pointed me to. In any case, the part I got is referred to as "Vixen-style".]
What I bought was this:
Multi-reticle finder w/ unhelpful base
So I also needed this widely unavailable part:
Mounting bracket to work w/ focuser's receiver
Which a CN subscriber sold me--so I'm all set. BTW, the focuser was upgraded before I bought the 102GT, so I don't know if this is the same bracket you'd need on the stock focuser.
It just seemed to me that the bracket (2nd link) could easily be made of plastic and still work just fine--perhaps fabricated on a 3D printer (or molded in ABS, certainly). And as I said, it's hard to find--I consider that I got lucky on the CN classifieds w/ my WTB request being filled so neatly.
John
Edited by AlphaGJohn (07/08/13 07:04 PM)
D.T.
Reged: 01/09/12
Loc: Oregon
Re: 3-D printers: getting cheaper now... new [Re: AlphaGJohn]
      #5966638 - 07/12/13 12:19 AM
Rather than buying my own 3D printer, I would rather just upload a CAD document to a company and then pick up the part at the local UPS store. The price on doing it that way is probably also coming down. Any 3D printer you buy will be obsolete in a year. And at that time, you might realize you had only used it twice.
I think another possible way to use the 3D printer, and keep the cost down, if your part had significant mass, would be to print a thin shell of what you want, and fill it with urethane casting material. Or, you could print a shape and strengthen it with carbon fiber.
Lot's of possible ways to play with this.
BoriSpider
Reged: 08/10/04
Loc: S.W.FLA
Re: 3-D printers: getting cheaper now... new [Re: D.T.]
      #5984607 - 07/22/13 02:59 PM
Looks like laser-sintering 3d printers are going to drop in price in early 2014.
This is 3ders.org's article on the subject.
Chriske
Kijkerbouw Urania
Reged: 08/15/04
      #6084832 - 09/16/13 09:53 PM
Just finished assembling a Prusa Mendel i2 printer.
This is our first print, a part of a crayford focuser.
BoriSpider
Reged: 08/10/04
Loc: S.W.FLA
      #6085336 - 09/17/13 06:41 AM
Gratz.
That is a nice print.
BoriSpider
Reged: 08/10/04
Loc: S.W.FLA
      #6093385 - 09/21/13 12:55 PM
Well not only are 3d printers getting cheaper, but smart people
are getting involved in there design. Here is a KickStarter
for the Peachy Printer. . You just got to watch the vids.
Genius, I say, Genius.
oh did I mention it's under $100?
Gary Fuchs
Reged: 05/22/06
Loc: Easton, PA, USA
      #6099574 - 09/24/13 11:50 PM
Nice work Chris, as usual...any more pieces?
Here's a lap mold mold Matt printed:
And the urethane mold:
And the lap:
Gary
Pinbout
Reged: 02/22/10
Loc: nj
Re: 3-D printers: getting cheaper now... new [Re: Gary Fuchs]
      #6099627 - 09/25/13 12:32 AM
I like that mold.
what size is it.
BoriSpider
Reged: 08/10/04
Loc: S.W.FLA
Re: 3-D printers: getting cheaper now... new [Re: Pinbout]
      #6100163 - 09/25/13 11:26 AM
Some VERY nice prints here.
Gary Fuchs
Reged: 05/22/06
      #6100259 - 09/25/13 12:17 PM
Thanks.
It's a 6", made in two parts so shouldn't be a problem to make larger sizes. Or different patterns/draft angle etc.
We thought the slight gap between the pieces might be a problem, but it wasn't--worked perfectly.
Gary
13 registered and 24 anonymous users are browsing this forum.
