samm
Reged: 06/24/07
Switched mounts: will PHD Guiding still work? new
      #5943662 - 06/27/13 07:17 PM
I used PHD Guiding with my Meade LX200 GPS ... but I just I bought a Skywatcher HEQ5 mount ... do I need new drivers or ASCOM files or anything like that, or should the program still work with the different mount?Thanks
CA Stargazer
Reged: 01/27/12
Loc: Milpitas, California
Re: Switched mounts: will PHD Guiding still work? new [Re: samm]
      #5943820 - 06/27/13 09:05 PM
Which guider are you using?
If it has a built-in ST4 port, it should interface with the HEQ5's guider port.
Otherwise you'll need eqmod.
http://eq-mod.sourceforge.net/
Reged: 07/06/07
Re: Switched mounts: will PHD Guiding still work? new [Re: CA Stargazer]
      #5943906 - 06/27/13 10:19 PM
No he will not. At most, if he is guiding over the serial port rather than the autoguide port, he will need the Celestron ASCOM driver, which includes SynScan.
Coastal
Reged: 04/23/09
Loc: Vancouver island, Canada
Re: Switched mounts: will PHD Guiding still work? new [Re: rmollise]
      #5943999 - 06/27/13 11:23 PM
While he may not -need- EQMOD, he could certainly benefit from it. Better yet, with the proper cable (like Shoestring's USB2EQ5 or whatever its called) the hand controller becomes optional.
Reged: 07/06/07
Re: Switched mounts: will PHD Guiding still work? [Re: Coastal]
      #5944379 - 06/28/13 08:29 AM
"Need" and "benefit" are two different things...and not what he was asking.
20 registered and 41 anonymous users are browsing this forum.
