Ed Jones
Reged: 04/06/04
Loc: Sin-sin-atti
Making a 6 inch Chief new
      #5939837 - 06/25/13 01:51 PM Attachment (48 downloads)
I've been working on a 6 inch Chief. I'm trying Dave O's idea of mounting the upper OTA on a tripod in the corner. Shown here is the work in progress (two of the legs will be added later) to get a sense of what it will look like. Temporary Zip ties are holding the tube on the cradle.
kfrederick
Reged: 02/01/08
Re: Making a 6 inch Chief new [Re: Ed Jones]
      #5939899 - 06/25/13 02:33 PM
Looks nice! I had to use a green laser to find where mine was looking .It will not be centered an any axis . Setting circles will work but more setup is needed [I ask] There is a very large offaxis reflector mounted that way .See if I can find the link . over several meters diameter .
Jeff Morgan
Reged: 09/28/03
Loc: Prescott, AZ
      #5940024 - 06/25/13 03:45 PM
Interesting, and probably a lot more approachable for a potential first time Chief builder. What are the ranges of focal ratios at that aperture?
Ed Jones
Reged: 04/06/04
Loc: Sin-sin-atti
Re: Making a 6 inch Chief new [Re: Jeff Morgan]
      #5940117 - 06/25/13 04:41 PM Attachment (29 downloads)
This one is F/12 and uses COTS lenses which I still need to order. I had made a couple of primaries a few years back and thought I go ahead an build it even though I already have another 6 inch Chief. An awesome performer I might add. I picked up a nice painted 80 mm telescope off Ebay although nobody makes a focuser for it. This one is a reflector focuser without the base.
Ed Jones
Reged: 04/06/04
Loc: Sin-sin-atti
      #5941099 - 06/26/13 09:20 AM Attachment (17 downloads)
The lens holder is PVC doughnut machined slightly smaller than the lenses and cut to a 15 degree wedge (the angle between the lenses) on a table saw. The delrin clips were made on a lathe to have a step equal to the edge thickness of the lenses then drilled off center. These can be rotated to center each lens in X and Y measuring with calipers from the edge. Brass pins were placed on the diameter as a rotation axis held in place by a tight fitting ring. This ring was cut from the left over tubing with a key filed into the ends to act as a solid ring. This allow the holder to be placed anywhere in the tube or rotation. Pretty slick.
Dave O
Reged: 12/21/11
Loc: Sri Lanka
      #5941102 - 06/26/13 09:28 AM
"Pretty slick" is right! Wow! I particularly like your idea for adjusting the de-centers ... be sure to let us know how well that works (thinking it will be a bit of trial and error in adjusting these things?)!
I like 'simple' things, and this lens cell is getting simple enough to where even I may have to give it a go!
Cheers. Dave O
kfrederick
Reged: 02/01/08
Re: Making a 6 inch Chief new [Re: Dave O]
      #5941308 - 06/26/13 11:43 AM
The thing you showed me about tipping the lens 90deg to the optical axis to see if the laser reflects back on its self Cannot be done with this? I like that on the 20. as it get the one axis of each lens nailed. Square Very nice Is there a baffle at the secondary? Are you going to Stellafane??
Ed Jones
Reged: 04/06/04
Loc: Sin-sin-atti
      #5941335 - 06/26/13 12:03 PM
The centration ought to be straightforward. In the X direction (axis of pins) the centration is zero and I can measure from the edge to make them equal with calipers. In the Y direction (wedge direction) the concave lens should be .027 inch farther than the convex lens from the thin edge. I can set the perpendicularity by checking with a laser, (rotating the holder). Finally if the holder rotation axis is off the holder can be rotated in the tube or the tube can be rotated in the cradle if I see any non-orthogonal astigmatism. That's the plan anyway.
kfrederick
Reged: 02/01/08
      #5941349 - 06/26/13 12:19 PM
Only the laser target and holder rotation need to be in correct rotaional axis with each other And the distance to focus from the last surface . Nice Should be simpler to setup . Move the whole top up till the moon focuses at the correct distance .
Ed Jones
Reged: 04/06/04
Loc: Sin-sin-atti
Re: Making a 6 inch Chief new [Re: kfrederick]
      #5941385 - 06/26/13 12:44 PM
Stellafane?
I doubt it.
kfrederick
Reged: 02/01/08
      #5943521 - 06/27/13 05:50 PM Attachment (11 downloads)
Be nice some year For you and me to enter the 20 Chief as a joint build . Guess we should have done that 4 years back. Nice telescope .I guess you making a platform for it ?
Ed Jones
Reged: 04/06/04
Loc: Sin-sin-atti
      #5943673 - 06/27/13 07:26 PM Attachment (15 downloads)
I already have a platform for it. It should fit in my other 6 inch rocker box as well, at least temporarily. Here's the prescription BTW.
kfrederick
Reged: 02/01/08
      #5944418 - 06/28/13 09:06 AM
http://www.toweroptical.com/pdfs/Catalog11/2011TowerOptical27.pdf
kfrederick
Reged: 02/01/08
Re: Making a 6 inch Chief [Re: kfrederick]
      #5944425 - 06/28/13 09:08 AM
http://www.toweroptical.com/pdfs/Catalog11/2011TowerOptical25.pdf
5 registered and 19 anonymous users are browsing this forum.
