SuperSirLink
Reged: 06/02/13
Loc: S.Valley, Va.
.965 eyepiece extension
      #5946345 - 06/29/13 11:05 AM
I have an 8x50 finder that uses .965 18mm eyepiece with 90 deg. diagonal. If I take the diagonal off, then I can't extend the helical focuser out enough to achieve focus.
So I am looking for a way to extend the focus out so I can spot without the diagonal. Most barlows I have found for .965 are 3x and way too long.
Holding the eyepiece back, it looks like I wouldn't need more than 2 or 3 inchs. Does anything exist that would help here?
tubehead999
Reged: 11/25/08
Loc: Kennesaw, GA
Re: .965 eyepiece extension new [Re: SuperSirLink]
      #5946523 - 06/29/13 12:47 PM
You can try this....
http://www.ebay.com/itm/Tasco-2-3x-Barlow-lens-965-diameter-telescopes-/36067...
Should give you the two inches and more that removing the diagonal requires. Of course, you will have to probably punch the barlow out.
roscoe
curmudgeon
Reged: 02/04/09
Loc: NW Mass, inches from VT
Re: .965 eyepiece extension new [Re: tubehead999]
      #5947231 - 06/29/13 09:51 PM
I took apart one of those double-prism image-erecting EP adapters, and found that the two end-pieces screwed together..... an instant inch of extension!
Russ
SuperSirLink
Reged: 06/02/13
Loc: S.Valley, Va.
Re: .965 eyepiece extension new [Re: roscoe]
      #5947770 - 06/30/13 09:50 AM
Might give that barlow a try...
Roscoe, do you have a link so I can see?
SuperSirLink
Reged: 06/02/13
Loc: S.Valley, Va.
      #5948502 - 06/30/13 06:55 PM
Here is the back end of the finder...
Edited by SuperSirLink (06/30/13 07:04 PM)
tomharri
Reged: 09/19/08
Loc: USA
      #5948508 - 06/30/13 07:04 PM
Try this guy:
http://www.cloudynights.com/classifieds/showcat.php?cat=500&ppuser=25634
SuperSirLink
Reged: 06/02/13
Loc: S.Valley, Va.
Re: .965 eyepiece extension new [Re: tomharri]
      #5948540 - 06/30/13 07:26 PM
Hmm, he had one, but he sold it already... bummer
This is the same one I have, wonder if I can find that extension... :/
http://www.cloudynights.com/classifieds/showproduct.php?product=50951&sor...
Edited by SuperSirLink (06/30/13 08:14 PM)
roscoe
curmudgeon
Reged: 02/04/09
      #5948907 - 06/30/13 11:45 PM
I'll try hard to remember to take a photo of it tomorrow and post it for you....
R
SuperSirLink
Reged: 06/02/13
Loc: S.Valley, Va.
      #5950136 - 07/01/13 06:30 PM
Thanks much!!
roscoe
curmudgeon
Reged: 02/04/09
      #5950909 - 07/02/13 08:50 AM Attachment (4 downloads)
Here's a photo of my extension:
As I said, I took both the focuser-end tailpiece and the EP-holder out of one of those cylindrical image-erector adapters that came with lots of older 60mm scopes, and in my case, they screwed together. I looked at another one I have, and both ends screwed into the round prism-housing, so that one wouldn't work......
I also have a short 2x barlow that came with a newer 60mm that's around 3" total length, which would work as an extension if the lens was removed, but it's plastic, so might not be real durable.....
Unfortunately, I messed up the best photo of my adapter shrinking it to post here (my computer's a linux os, and the photo program is a bit more complicated than my mac was...) so here's the second-best view.....
SuperSirLink
Reged: 06/02/13
Loc: S.Valley, Va.
      #5951982 - 07/02/13 07:51 PM
Ahh ok, thanks for sharing that... I found someone here in the classifieds with an extension for sale. But if that doesn't work, I guess I will just get the vixen adapter and convert it to 1.25"...
23 registered and 25 anonymous users are browsing this forum.
Moderator:  ausastronomer, droid, Scott in NC
