Matthew Ota
Hmmm
Reged: 04/30/05
Loc: Los Angeles, California
Lens Pen
      #5946615 - 06/29/13 01:40 PM
I have been using the same regular size and mini lens pen since 1998. Do They have a shelf life limit or can I go on using them indefinitely?
Doc Willie
Reged: 03/31/10
Loc: Mid-Hudson Valley, NY, USA
Re: Lens Pen new [Re: Matthew Ota]
      #5946751 - 06/29/13 03:14 PM
I would think they accumulate a certain amount of crud in them after a while. How long? Who knows? I get a new one every year.
mikey cee
Reged: 01/18/07
Loc: bellevue ne.
Re: Lens Pen new [Re: Doc Willie]
      #5946969 - 06/29/13 05:51 PM
I've used mine equally that long. But I do have new ones. The sponge inside has enough black graphite to handle quite a bit of so called gunk. My eyepiece lenses put under a magnifier show no fine scraches either. I endorse their usage. Mike
johnnyha
Reged: 11/12/06
Loc: Sherman Oaks, CA
Re: Lens Pen new [Re: mikey cee]
      #5946977 - 06/29/13 05:59 PM
I use a brand new lens pen to clean my bino prisms which is only once every few years really, and to clean the edges of the objective on my FS152 which I clean about twice a year or less.
I believe a scratch in the coating of an 11T6 eyepiece I once owned was caused by a used lens pen.
Reged: 07/06/07
Re: Lens Pen new [Re: johnnyha]
      #5946982 - 06/29/13 06:01 PM
I've used mine for years, never had a problem, a scratch, etc. I am always careful to dust off the surface carefully with canned air, and the brush before using the cleaning tip, however. Since, in real terms, they are used very infrequently, they will last a long, long time. My experience is that the cleaning tip comes off long before there's a problem with dirt, running out of the cleaning stuff, etc.
tim57064
Reged: 08/23/12
Loc: Southeast South Dakota,USA
Re: Lens Pen new [Re: rmollise]
      #5948069 - 06/30/13 01:29 PM
I have a set of 3 of these and have yet to use them. Guess I have been afraid of scratching my eyepieces. Do they really work that well? I got them for my Dslr lenses and would like to use them on my eyepieces too, just too cautious maybe.
MAURITS
Reged: 09/22/09
Loc: Belgium
Re: Lens Pen new [Re: tim57064]
      #5948088 - 06/30/13 01:47 PM
Used when necessary and no problem at all!
Reged: 07/06/07
      #5948194 - 06/30/13 03:01 PM
Yes, they work well. No, they won't scratch anything if used properly. As above, just dust the surface with air or the brush before cleaning.
tim57064
Reged: 08/23/12
      #5948201 - 06/30/13 03:05 PM
Thanks MAURTIS and Rod. I will give them a try as a lot of my eyepieces could use a cleaning and have been afraid of using any cleaning solution for fear of moisture getting between the elements.
MAURITS
Reged: 09/22/09
Loc: Belgium
      #5948332 - 06/30/13 04:39 PM
Tim, read the instruction BEFORE you use them!
Works great, but I buy every year a new one.......
Binojunky
Reged: 12/25/10
Re: Lens Pen new [Re: MAURITS]
      #5951145 - 07/02/13 11:14 AM
I have used them for years, a couple of things though, their are counterfeight ones out there and like any cleaning system use common sense, if dust and grit is on the surface being cleaned then any cleaning tool will cause scratches. Lots of optical companies are selling these now and I can,t imagine these companies not checking them out thoroughly before endorsing.
Also check the end pad from time to time, if in doubt, chuck it out,DA.
TG
Reged: 11/02/06
Loc: Latitude 47
Re: Lens Pen new [Re: Binojunky]
      #5951186 - 07/02/13 11:37 AM
I love the lens pen but HOW DOES IT WORK???
Tanveer
Zamboni
Reged: 01/03/05
Loc: Colorado Springs
      #5951511 - 07/02/13 03:18 PM
Truth. I wound up with a "fake" lenspen from a big box sporting goods store. The pad was actually wool felt. The brush on the other end was extremely course.
Only buying ones that have the Lenspen brand name on them now.
8 registered and 14 anonymous users are browsing this forum.
Moderator:  zjc26138, tecmage, rflinn68
