WRAK
Reged: 02/18/12
Loc: Vienna, Austria, Europe
Double Star Session in Boo with faint companions new
      #5945244 - 06/28/13 05:31 PM
Last night I got the present of a 2 hour window with clear sky with the bonus of fair Pickering ~7 seeing. Rising 3/4 moon made the sky rather bright with NEML ~2.8mag. I was at the beginning of the session not aware of the very good transparency thus I did not expect much but simply tried with my 140mm refractor besides some other doubles:
STT270 HIP 67275, WDS13473+1727 13h 47m 15,7s +17:27:24,8 2,7" +4,5/11,1mag: x280 egg pointing at noon = ~ position according to WDS 31. Must have been a lucky guess as this seems impossible with 140mm
HJ533 WDS13388+1926 13h 38m 44,0s +19:25:47,4 13,4" +10,29/12,29mag: x200 companion dedected at 7:30 with averted vision. If the magnitude for the companion is correct than this the faintest star I have ever seen with the 140mm refractor with this amount of light pollution
COU58 WDS13587+1711 13h 58m 39,3s +17:10:48,4 1,4" +10,27/11,64mag: x200 tiny rod pointing to 11 o'clock meaning the ~ right position of 2. This should require a much larger aperture - just another lucky hit?
A2064 WDS14034+1740 14h 03m 24,6s +17:40:00,1 1,1" +9,61/11mag: This one did not work - no resolution, not even a hint for a double
BU30 HIP 68237, WDS13581+1928 13h 58m 07,4s +19:27:29,8 8,1" +8,82/11,78mag: x75 very faint at 5 o'clock. Companion disappears with higher magnifications.
I got then a bit cocky and tried Theta CrB - should have been possible even with 140mm with this seeing conditions if the advertised parameters would be valid. No hint of a double but thin clouds have meanwhile appeare so this was it.
Wilfried
Nucleophile
Reged: 05/24/13
Loc: United States
Re: Double Star Session in Boo with faint companions new [Re: WRAK]
      #5945483 - 06/28/13 07:55 PM
Thank you for the fine report, Wilfried.
I checked my notes and I havent looked at any of these yet.
The following are of the most interest:
COU58 WDS13587+1711 13h 58m 39,3s +17:10:48,4 1,4" +10,27/11,64mag: x200 tiny rod pointing to 11 o'clock meaning the ~ right position of 2. This should require a much larger aperture - just another lucky hit?"
This is a pretty good result I would think--congrats!
"A2064 WDS14034+1740 14h 03m 24,6s +17:40:00,1 1,1" +9,61/11mag: This one did not work - no resolution, not even a hint for a double"
I want to take a peek at this one tonight with the 8 inch---the pA calculator gives a value of 169mm for this instrument---should be a good test. May even look at it with the stepped down 15 inch to 6 inch..........
Finally, I also have been viewing doubles with faint companions--mostly with negative results--I believe I have had the magnification cranked up too high.
I continue to take cracks at Epsilon CrB--just seems like I should be able to see it with the 15 inch---the latest version of my calculator for this instrument seems to think so as well. Negative results are of great interest, however, particularly if they are replicated over many nights.
I have to admit, I am becoming allergic to COU doubles as I have had severe trouble with many of them in the past week
Nucleophile
Reged: 05/24/13
Loc: United States
      #5947364 - 06/30/13 12:01 AM
I tried this one last night with several instruments on a night of good transparency and average seeing (Pickering 6-7):
A) 8 inch reflector: no hint of a companion up to 276x ( I should have tried other magnifications, but needed to move along).
B) 15 inch reflector fitted with off axis mask yielding 6 inch f/10-like refractor: no hint of companion at 398x; primary appears quite dim (probably should have looked at lower magnifications)
C) 15 inch reflector fitted with on axis mask yielding 11 inch f/7 reflector with CO = 0.25: companion suspected quite close to primary in correct position angle at 398x; increasing magnification to 569x shows the secondary as a faint speck that is resolved from the primary
D) 15 inch reflector: 569x: despite issues with seeing, companion clearly seen as resolved in same place as seen with the "11 inch"; going down in magnification to 398x only shows the secondary as a pointy extension.
The object seemed harder to split than a 1.1" variety with not too faint stars of modest delta magnitude (at least for the 15 inch instrument)---I wonder if it is actually a bit closer now?
The WRAK calculator gives it a value of 169 when using the 8 inch reflector---something is amiss. I should like to try this one again with the 8 inch.
WRAK
Reged: 02/18/12
Re: Double Star Session in Boo with faint companions [Re: Nucleophile]
      #5947533 - 06/30/13 04:07 AM
The change from 1.4" in 1909 to 1.1" in 2010 suggests a slow closing or simply more precision. +11mag for the secondary makes me cautious - these zero digit numbers are usually wrong.
AAVSO lists for the primary +9.418mag but there is no value for the secondary.
Wilfried
3 registered and 2 anonymous users are browsing this forum.
Moderator:  PJ Anway, Rich (RLTYS), rflinn68
