lilfeet
journeyman
Reged: 06/29/13
Loc: Arky
Help with M-13 .
      #5948067 - 06/30/13 01:28 PM
Just getting back into stargazing after a few years off. I have an 8 inch dob and a 5 inch mak. Trying to find M-13 with the dob and I'm having no luck. I've seen M-57 and a few double stars while waiting for M 13. I've viewed it many times from this location before. For some reason I can't seem to find it anymore, I think it's still there. I can't make out the fourth star any where,so I don't really know if I'm looking in the right place. Someone please tell where to look,besides up Thanks .
David Knisely
Reged: 04/19/04
Loc: southeastern Nebraska
Re: Help with M-13 . new [Re: lilfeet]
      #5948084 - 06/30/13 01:46 PM
You need to find the "Keystone" of Hercules; a set of four widely-spaced stars that form a rhombus and the top of the body of the constellation. The western side stars of the Keystone is where you will need to look. About a third of the way from the top star of the west side of the keystone (Eta Herculis) to the bottom star (Zeta Herculis) is where M13 is located. In a finderscope, it is flanked by two 6th and 7th magnitude stars about half a degree apart, so that may help you in finding it. A good finder is helpful here, along with a good star atlas like the Sky and Telescope Pocket Sky Atlas. Good luck and clear skies to you.
kfiscus
Reged: 07/09/12
Loc: Albert Lea, MN, USA
      #5948086 - 06/30/13 01:46 PM
Are you able to identify the four corner stars of Hercules' torso (aka the keystone)? As you look at his body, M-13 is below his shoulder/armpit on the right side- from our perspective. The cluster is about 1/3 of the way down, right on the line between his shoulder and hip.
By the way, welcome!
tim57064
Reged: 08/23/12
Loc: Southeast South Dakota,USA
Re: Help with M-13 . new [Re: kfiscus]
      #5948129 - 06/30/13 02:16 PM
If you can see M57 and are waiting for M13? M13 being in the constellation Hercules is to the west of the Ring. I apologize if you are already aware of this,not trying to be a smart aleck. Do you have a smart phone and have google sky maps installed? That has helped me tremendously to remember the constellations and where and what things are.
Ed Wiley
Reged: 05/18/05
Loc: Kansas, USA
Re: Help with M-13 . new [Re: tim57064]
      #5948179 - 06/30/13 02:52 PM
One of the best resources for finding Messier objects is Pennington's "The Year-Round Messier Marathon." He explains the "geometric method" using a Telrad. I found this method invaluable when I did the Messier list where digital setting circles and go-to are not allowed and continue to use the geometric method on other targets.
Ed
tim57064
Reged: 08/23/12
      #5948189 - 06/30/13 02:59 PM
Another quick question for you. What eyepiece were you using? A much lower power eyepiece with a wide field ,32mm or a 40mm 60 degree or more will help with locating since they give a wider field of view. Just my 2 cents.
lilfeet
journeyman
Reged: 06/29/13
Loc: Arky
Re: Help with M-13 . new [Re: Ed Wiley]
      #5948221 - 06/30/13 03:18 PM
Hey,thanks for the quick tips and info. I have about one hour before and after zenith going east to west. So I don't have a lot of time trying to find things.About the same to the south.Good veiw to the north but that's the worst light pollution. Like I said just getting back into it and just having a hard time getting everything orientated in my limited veiwing range.
I use 25mm 32mm and 40mm when searching,32 mm most of the time.
Edited by lilfeet (06/30/13 03:22 PM)
FoggyEyes
Reged: 06/01/13
Loc: Columbus, Ohio
      #5950108 - 07/01/13 06:09 PM
Buy "Turn Left At Orion". The most recent edition is written around finding stuff with a Dob.
astroment
Reged: 06/25/13
Re: Help with M-13 . new [Re: FoggyEyes]
      #5950200 - 07/01/13 07:21 PM
Try to find Lyra Vega is the brightest star up then Hercules
I have been seeing it up high this year here's a map I found
doing a google search
http://earthsky.org/clusters-nebulae-galaxies/m13-finest-globular-cluster-in-...
I see you have found M57 in Lyra
M13 it's a stretch looking for it on the keystone just to let you know you will be looking straight up for it
Edited by astroment (07/01/13 07:33 PM)
lamplight
Reged: 09/18/12
Loc: western MA, U.S.
Re: Help with M-13 . new [Re: astroment]
      #5950368 - 07/01/13 09:21 PM
Hi
cant really add anything new but yes, its to the right and higher overhead than m57. Once you find it once its quite easy to return too, I can find it with just a telrad in light pollution. My method is to look at the object on a star chart and then point my scope to the same place in the sky.. for a relatively bright object like this it is visibke in the finder. Another approach is start at one of the twotop stars of the keystone and sweep your scope towards the opposite while refering to findersxope views and charts as you go -the starhop
if you only have a short window id go for that one soon after dark as its near zenith early in the night now. Good luck and have fun!
jerwin
Reged: 05/17/12
Loc: Romeoville IL
Re: Help with M-13 . new [Re: lamplight]
      #5950947 - 07/02/13 09:16 AM
I draw a line between Arcturus and Vega, that helps me position Hercules the right way. M13 is in that part of the quadrilateral closer to Arcturus.
Clear Skies,
uniondrone
Reged: 12/05/09
Loc: Streetlight Archipelago
Re: Help with M-13 . new [Re: jerwin]
      #5950970 - 07/02/13 09:30 AM
As others have said, learn to find the keystone of Hercules with your naked-eye first. Then learn where in the keystone to find M13. Then use your lowest power eyepiece when locating it. With an 8-inch dob and about 40x magnification, it should be almost point-and-find.
ffraley
Reged: 03/12/13
Loc: NE Ohio
Re: Help with M-13 . new [Re: uniondrone]
      #5951221 - 07/02/13 11:58 AM
I found it last week, it's the very first object I've ever looked for and found, other than planets and a couple of obvious doubles. I may not be much help, but I can describe what my problems were, and what worked. BTW, I used "Turn Left at Orion" and never took my smartphone out, it just confused things.
First, facing generally southeast, I found Arcturus and put it on my right. Then I put Vega on mt left to make a line I could work from. Then I stood still. Looked right to Corona Borealis, a big smile 1/3 of the way from Arcturus to Vega. Then left again to the Keystone shape half way between Corona Borealis and Vega. Then right to the star in the upper right corner.
Repeatedly making that line with back and forth was very helpful for me. Every time I turned or looked away I lost my orientation - since I was using a refractor and looking pretty high, I had to relax and look away often. Each time I redrew it was a little bit quicker and a bit more secure. I redrew it about a dozen times. I found it helped to stand up, keep my feet and body still, move mainly my eyes and head as little as possible to find things, then go to the finder while sort of keeping one eye on the spot in the sky.
Each time I started fresh by relocating that top right star in the finder and centering it. then moving about 1/3 of the way toward the bottom right star. And on about the dozenth try there was a fuzzy spot :-)
May sound crazy, disjointed, and simplistic; it worked for me.
My biggest problems were (are?)
-- getting the 6x30 finder on the right single star
-- getting and maintaining an orientation of what is where and which direction is which
-- realizing that if it's not there, it's not there. Start over from a known correct point.
Kraus
Reged: 03/10/12
Loc: Georgia.
Re: Help with M-13 . new [Re: ffraley]
      #5951313 - 07/02/13 12:58 PM
Sure are a lot of folks spend a lot of time finding objects then have to nudge the tube along to keep the object in view.
Go equatorial, go permanent.
ffraley
Reged: 03/12/13
Loc: NE Ohio
Re: Help with M-13 . new [Re: Kraus]
      #5951333 - 07/02/13 01:15 PM
That's why I used the refractor. Well, that and it was easier to haul for vacation. But really made no difference in finding the object, though.
I have both and it really seems to be a wash. That's probably another thread, though.
bob irvin
Reged: 03/22/11
Loc: Greater Los Angeles, CA
      #5951534 - 07/02/13 03:31 PM
Make sure you're looking at the (correct) 4 stars that make up the center of Hercules. I couldn't find M13 for the longest time because I was looking at the wrong 4 stars. Once you figure out which stars those are M13 is pretty straight forward to find given the advice already given.
bob
Dave Mitsky
Reged: 04/08/02
Loc: PA, USA, Planet Earth
      #5952492 - 07/03/13 03:21 AM
M13 forms a near right triangle with Pi and Eta Herculis at the "top" of the Keystone. There's a finder chart for M13 at http://freestarcharts.com/index.php/20-guides/messier/91-messier-13-m13-great... and a Telrad finder chart at http://www.atmob.org/library/member/skymaps/MAP9.PDF
Dave Mitsky
Illinois
Reged: 12/18/06
Loc: near Dixon, Illinois USA
Re: Help with M-13 . new [Re: Dave Mitsky]
      #5952661 - 07/03/13 08:15 AM
Maybe you are in light pollution that is not easy to see Hercules. If you can see 4 stars and use 7 or 10 X 50 binocular and you can find a fuzzy blob is M13. Then you know where is it then use your telescope! Good luck!
REC
Reged: 10/20/10
Loc: NC
      #5952804 - 07/03/13 09:58 AM
Yep, always found it looking just south of Eta. Easy to see in most finder scopes. Has the OP found it yet?
Seldom
Reged: 08/05/12
Loc: N of Cedar City Light Dome
Re: Help with M-13 . new [Re: REC]
      #5952960 - 07/03/13 11:43 AM
+1 on David Knisely's recommendation of the Pocket Sky Atlas, but his reference to a rhombus could cause some confusion if you expect to find M13 in one. The keystone is a trapezoid.
Note that the PSA has a list of Messier objects on the last page.
Fuzzyguy
Reged: 12/21/11
Loc: Colorado/Kansas
Re: Help with M-13 . new [Re: Seldom]
      #5953048 - 07/03/13 12:33 PM
If you are using an equatorial mount, M13 is a very easy hop once you find Eta Her. Just turn you DEC control so your scope moves straight south about 2.5 degrees and it will pop into view and form a flat triangle between two nice 7th mag stars. If you have at least a .75 degree FoV, you can't miss it.
bremms
Reged: 08/31/12
Loc: SC
Re: Help with M-13 . new [Re: Fuzzyguy]
      #5953071 - 07/03/13 12:51 PM
M13 is easily visible in a finder and a naked eye object from a dark site, Use some star charts and find it as other have described. Paper charts, not on a phone. If you have some binos get them out and scan the area. That way, you can become familiar with the star patterns around brighter objects.
David Knisely
Reged: 04/19/04
      #5953190 - 07/03/13 02:02 PM
Yea, it is a little more like a trapezoid than a rhombus.
lilfeet
journeyman
Reged: 06/29/13
Loc: Arky
Re: Help with M-13 . new [Re: David Knisely]
      #5954753 - 07/04/13 01:15 PM
Still haven't been able to find it. I can't make out the four stars. See a lot of three stars but not the fourth. That's what giving me fits. I've looked with 10x50 bino's till my necks stiff. I've took a few nights off and have been watching Saturn instead. I ain't gonna give up, I know it's up there just waiting for me to figure it out.
Again thanks for all the help and tips. I've really enjoyed being back out under the stars and feeding the bugs.
JasonBurry
Reged: 04/27/12
Loc: Cape Spencer, NB, Canada
      #5954791 - 07/04/13 01:43 PM
I've found, on occasion, Hercules to be less than the most obvious constellation.
My suggestion would be that you try a sky chart software for your computer. I like Cartes du Ciel myself, it's free and VERY configurable. The most basic catalogues would be plenty for this purpose. There are a number of other free software that will also work.
The advantage of using a sky chart software is it shows you where things are "now".
M13 will quickly become a favourite object, one you'll slew to from memory in no time, once you get to know the neighbourhood.
Good hunting.
J
Dave Mitsky
Reged: 04/08/02
Re: Help with M-13 . new [Re: JasonBurry]
      #5954800 - 07/04/13 01:48 PM
Here are links to the Stellarium and Cartes du Ciel sites:
http://www.stellarium.org/
http://www.ap-i.net/skychart/start
Dave Mitsky
SteveNH
Reged: 07/10/11
Loc: Millbrae, CA
      #5954830 - 07/04/13 02:10 PM
That's the 'key', so to speak, to finding M13. As others have mentioned, as soon as you find the Hercules keystone stars, you will find M13 with no problem at all. In my badly light polluted sky where even Polaris and the end star Kochab is barely visible in the Little Dipper, I have difficulty seeing the orientation of the keystone overhead. Using lower power wider-field binoculars or opera glasses (3x - 7x) will help brighten those dim stars so you can recognize the keystone. 10x is too much power for that.
Steve
galexand
Reged: 07/10/12
Loc: Bloomington Indiana
      #5954841 - 07/04/13 02:18 PM
I was just gonna recommend binocs. I'm not sure how you use them, but I have a pretty rigorous technique. First, I find some bright star I can spot naked-eye and make sure I can get to it in the binocs, and look at the star chart to make absolutely sure I've got the right one. Then I look for some little asterism on the star chart that is headed in the direction towards my target...then I set down the star chart and go back to the binocs and do the hop, starting at the bright star, and going to that asterism. I might do that a dozen times to make sure I'm able to do that hop reliably, and to make sure I really am looking at the same thing as in the charts. Then I'll look at the charts again and find another asterism that's even closer, and go back to the bins and do that again. I do that as many times as it takes until I'm at my destination. Each time I look through the bins, I start at the same bright star, so I am practicing one star hop sequence over and over again. By the time you find M13, you'll know the neighborhood pretty well from so much hopping around the vicinity. The important part is to check in between runs and make sure you are actually understanding how the view relates to the charts, or you aren't really learning anything. A lot of times, I get lost and realize after a while that I was looking at "the big triangle to the upper-left" when I should have been looking at "the little triangle way far to the upper-left" or whatever story you have to tell yourself to keep the star chart in your mind while looking through the bins.
I did that last night for M13, it took a while -- like others have said, Hercules is not a very obvious constellation so I started at Vega. Lyra happens to be my favorite for hopping, but if you managed ot find M57 then you've already conquered it.
I do roughly the same technique looking through the telescope but it is *so* much more convenient through binoculars, and M13 is luckily one of those objects that shows up pretty well in bins.
REC
Reged: 10/20/10
Loc: NC
      #5954906 - 07/04/13 03:19 PM Attachment (7 downloads)
Ok, enough of this already, It's frustrating me too that you can't find it yet. About an hour after sunset Hercules is just about overhead. From Saturn, straight above that is Arcturus in Bootes, hang a left from there, past the "C" for Coronas and then find the 4 stars that make up the keystone, just about 1/3 the way down from Eta you will find M13. Can't wait to hear your report on it:)
Gvs
Reged: 05/19/11
Loc: Texas
      #5955930 - 07/05/13 11:17 AM
Try and get a laser pointer aligned with your telescope, and then use your star map and point your scope with the laser on.
Use a 40mm eyepiece or larger. You should not have a problem finding M13.
Omega Centauri is a better candidate, and it looks great on any telescope if you are at a latitude to see it.
csrlice12
Reged: 05/22/12
Loc: Denver, CO
Re: Help with M-13 . new [Re: Gvs]
      #5955938 - 07/05/13 11:23 AM
I can actually see it thru the 9X50 finderscope with plenty of sky around it; shouldn't be too hard to find.
Seldom
Reged: 08/05/12
Re: Help with M-13 . new [Re: csrlice12]
      #5955948 - 07/05/13 11:29 AM
Hercules is practically at zenith after dark and my neck doesn't reach that far back. Try lying down and looking straight up for M13 using binoculars. I found M101 that way too.
astroment
Reged: 06/25/13
      #5956133 - 07/05/13 01:55 PM
+1 on Stellarium Here's some youtube video's on how to use it
Part 1 https://www.youtube.com/watch?v=hQtLH0FafrI
Part 2 https://www.youtube.com/watch?v=htJAzLMIkU0
Brett Carlson
Reged: 12/12/11
Loc: Rochester, NY
      #5956243 - 07/05/13 03:26 PM
What kind of finder are you using? If you are using a Telrad you should be able to download a chart to help you find it.
If you still can't find it....find a local Club and see if they are having a star party. Someone there should be able to help you easily.
maakhand
Reged: 09/15/09
Loc: florida, usa
Re: Help with M-13 . new [Re: Brett Carlson]
      #5956360 - 07/05/13 04:42 PM
Get a planisphere to help you . What it does is let you get a proper perspective and relative sizes/positions of neighboring constellations. Finding keystone will be a piece of cake.
astroment
Reged: 06/25/13
Re: Help with M-13 . new [Re: maakhand]
      #5956687 - 07/05/13 08:18 PM
I spotted some free sky map's
http://www.skymaps.com/downloads.html
Align the map easiest way to do this is raise the map up in the sky and try to match the angle in Ursa Major you will need a red led to read the map at night to keep your eyes adapted to the dark if you can't find hercules don't get discouraged I remember when I was first was looking for it was a tough one
try to see if you can make out other constellation's it's like a big jigsaw puzzle once you see one constellation to another then all the pieces will start to come together
Edited by astroment (07/05/13 11:09 PM)
Illinois
Reged: 12/18/06
      #5957184 - 07/06/13 08:20 AM
AGREE with REC! You seem don't know where is Hercules. You know very bright star far left is Vega in Lyra and you see other bright star far right is Arcfurus in Bootes. You see C or more like U shape of stars is Corona Borealis is left of Bootes. Then little left of stars shape like C or U is Hercules. Look until you can able to see a whole Hercules then look 4 stars and M13 is almost in between of 2 stars. If you find M13 then you will find it easy for rest of your life. I think you live in light pollution and go little darker sky to able to find Hercules.
Edited by Illinois (07/06/13 08:22 AM)
BrooksObs
Reged: 12/08/12
Re: Help with M-13 . new [Re: Illinois]
      #5957239 - 07/06/13 09:24 AM
To be honest, I've seen very little in these two pages of posts that in my opinion is truly helpful in the case of a beginner who seems unable to ID the constellations. I sometimes wonder what has become of the hobby when reading these threads. Does everyone now first run out and purchase their telescope and expect to quickly find celestial showpieces without knowing the basic outlines/star patterns of the constellations? Is it perhaps that folks today are attempting to observe under conditions so poor that only fragments of the constellations are apparent to them under their bright skies, rendering their observation worthless anyway? Or maybe it is a combination of both?
In my opinion the place to start is always to learn the constellations well first and have a paper atlas at hand. That allows you to always find things regardless of the scope you are using and under all but the worst of sky conditions. I meet so many would-be hobbyists these days that are totally lost without their GoTo scopes and this I regard as becoming an increasingly sad state of affairs.
So, my advice is to put the telescope aside for just a little while. Acquire a nice, medium-scale, book-type star atlas and perhaps a pair of inexpensive binoculars. Then go out and learn what the sky actually looks like and find your way around it to locate things. Only then come back to that telescope.
BrooksObs
Edited by BrooksObs (07/06/13 09:46 AM)
astroment
Reged: 06/25/13
Re: Help with M-13 . new [Re: BrooksObs]
      #5957536 - 07/06/13 01:29 PM
When I started learning the constellation's was using the sky chart's in Astronomy Magazine
I was 16 at the time now 40 That was back in 1989 I still have those magazine's try picking one up also here's a dark sky map that show's the light pollution
http://www.blue-marble.de/nightlights/2012
try to see if you can get out of the light zone
if you can see the milky way then you are in a good dark place
Edited by astroment (07/06/13 02:33 PM)
Sorny
Reged: 03/15/12
Loc: Southern MN
      #5958160 - 07/06/13 09:00 PM
The problem: light pollution.
The solution: GoTo. Also worth mentioning are various push-to systems. A smart phone and Sky Safari will also work wonders.
3 registered and 21 anonymous users are browsing this forum.
Moderator:  WOBentley, kkokkolis
